Old Feb 08, 2013, 05:15 PM
RobT01 is online now
Find More Posts by RobT01
United States, NY, Syosset
Joined Jun 2012
banana plug to usb adapter
Does anyone make a banana plug to usb adapter so you can charge USB devices from our chargers?
(as I sit and anticipate our third power outage in as many months I cannot help but think I could charge my flight packs and have power to charge usb powered devices like phones etc for some time.)
Rob
RobT01 is online now Find More Posts by RobT01
Old Feb 08, 2013, 06:07 PM
RedOctobyr is offline
Find More Posts by RedOctobyr
United States, MA
Joined Jan 2011
I don't know of one, sorry. But that's an interesting idea.
You might also be able to charge USB devices directly from the flight packs, using a BEC set to 5V, ideally, or maybe a standard 4.8V would be enough?
My Castle Ice's BEC can be set it 0.1V increments. Making a servo plug->USB adapter is probably doable.
HobbyKing actually sells a little device to take 2S input power, and provides a USB plug.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
I don't have any 2S packs. But if I was desperate, I could use the balance plug to pull 2S voltage from a 3S or greater pack. Balancing the pack afterwards would take longer, of course, and this is not a great way to do things.
You could also potentially use something like a cigarette lighter->USB adapter. I don't know if 12.6V 3S LiPo power would damage it. I doubt it, as your car can be 13.8V or so when running, I think.
That may touch on the simpler approach, to charge them from a car with a cigarette lighter adapter, if possible. I'm anticipating the same outage, so I get where you're coming from
RedOctobyr is offline Find More Posts by RedOctobyr
Old Feb 08, 2013, 06:54 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
There are numerious USB charging devices which are powered by 12V DC nonimal . Why not just purchase one for $5 or so from the WW Net ,plug into auto accesory and connect device or purchase an auto jump starter with bbattery and accesory socket so it can be used inside?
Charles
Old Feb 08, 2013, 08:12 PM
Joined Jun 2012
Remember seeing the gas lines on the news? You will never forget when you lived through them. I have power here, why not have a way to use it?
Old Feb 08, 2013, 08:15 PM
Joined Jun 2012
Not what I had in mind since I only have a few 2 cell packs, but it is a step in the right direction.
Old Feb 08, 2013, 09:37 PM
Southern Pride
First off charging your flight packs ahead of time just in case is a bad idea as it is not good to leave LiPolys fully charged for days or weeks on end.
Secondly if you have an auto then you can use the accosory outlet to power such a charger for a very long time without needing to run the engine and if you have to commuate then the car battery gets recharged anyway.
Third the 12V auto jump start unit will have a 7Ah to 12Ah range AGM battery in it that can and should be kept fully charged and will serve your charging needs for phones and such for a very long time and they can be recharged from the car as you drive and carried into the house.
Charles
Old Feb 09, 2013, 08:58 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
What about something like this?
http://www.hobbyking.com/hobbyking/s...g_Adapter.html
You gotta remember the usb device you are powering has its own charger inside. So powering it from your charger isn't really ideal I don't think.
grimbeaver is offline Find More Posts by grimbeaver
Old Feb 09, 2013, 01:04 PM
Joined Jun 2012
Good point. I didn't think about the fact they have a charger built in.
For Sale GWS USB Simulator Cable Futaba Square Plug Christian_C Aircraft - General - Radio Equipment (FS/W) 3 May 23, 2014 07:33 AM
Misc Banana Plugs Mikey 68 Non R/C Items (FS/W) 2 Jan 14, 2013 10:26 AM
Discussion keychain camera usb to banana plug charge lead pcnewman Aerial Photography 1 Apr 14, 2012 01:00 PM
Discussion Banana plug to Great Planes/Hobbico adapter? luftschiffe Batteries and Chargers 2 Jun 03, 2010 06:34 PM
Question banana plug to Alligator clip adapter... RCBABBEL Batteries and Chargers 10 May 04, 2009 11:30 PM
