Old Feb 08, 2013, 03:57 PM
topgearuk is offline
Find More Posts by topgearuk
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
Mini-Review
***DJI NAZA-H with GPS, Helicopter Auto Pilot, Flybarless Controller Mini-Review
UnBoxing and initial thoughts
Hello everyone, I'm going to be writing an independent review and share my experience with the DJi NAZA-H with optional GPS for helicopters. And hopefully answer questions along the way…
It's a helicopter Autopilot system, with built-in tail Gyro, Flybarless support, Auto Hover and Level Fail safe, 3 flight modes, Full Manual, Atti Mode and GPS with Atti Mode.
A little background information before I begin this review, My name is David and I have been in and out the model industry for almost 30 years, I don't claim to be a fantastic flyer.. But have over the years tried and flown most types whether it be Planes, Helicopters or more recently Multi-rotors… But the part that gives me the most enjoyment is helicopters and scale being the type of flying I prefer.
6 Months ago I had the pleasure in meeting up with SidneyW from on here (RCG), when I was over in Hong Kong, I spent a day at the DJi headquarters and factory in China..
Sidney asked me if I would be interested in writing a fully independent review on the NAZA-H, and offering technical assistance that I pick up a long the way, to which I jumped at the chance (I love gadgets! lol) … Sidney has asked me to write an honest review including waltz and all, Just as I find it. This is very important to get across… I would really like it if we could keep this a friendly thread, whatever the views.
I don't sell, supply or have any finical gain in DJI what so ever… I am a paying end user of there equipment..
Okay, so now I have the boring stuff out the way, let me start this review, it is going to be on going, as and when I have time so please check back for updates!! I hope to do the installation in the next 2-3weeks and flight test shortly after that.
Overview
The Naza-H autopilot system is a new platform designed for the helicopter model enthusiast. It inherits the Naza series’ All-in-One design with an inner damping and many other built-in high performance functions (tail gyro, flybarless, and multiple flight control modes) and it also supports D-BUS. With the optional GPS module, stability is no longer a problem. From novice to aggressive 3D, the Naza-H perfectly meets the needs of different flying styles. It is not just another FBL controller; it is the best choice for the discerning model helicopter pilot.
Features
All-in-One Design
Built-in Tail Gyro/Flybarless Supported
Support for Multiple Electric Helicopter Platforms
Advanced Attitude and Control Algorithm
Optional GPS Module
Multiple Flight Control Modes/Intelligent Switching
D-Bus Supported
Independent LED Module
Semi-auto Take-off & Landing (Will Be Available in The Following New Firmware)
All-in-One Design
Naza-H has inherited the All-in-One design of the Naza series of autopilot systems. With the innovative All-in-One design, it contains inner damping, controllers, a 3-axis gyroscope, a 3-axis accelerometer and a barometer in its light and small main controller. It simplifies installation and saves space and weight and its firmware can be upgraded over the internet.
The high-performance FBL (flybarless) system, with a linear and smooth control feeling, is specially designed for model enthusiasts, especially hard 3D flight. The system fully meets the requirements of the novice and professional pilots and more importantly you can also set different flight styles anytime you want. The system has plenty of advanced functions, such as the pirouette compensation and auto trim which make you can feel the ease of stabilization as well as experience the hard 3D flight.
This will be in 3 parts, unboxing and initial thoughts, Installation and set-up, Flight Report and set-up..
The Naza-H comes in 3 boxes, the 1st being the main box with the Main FC (Flight Computer) , independent LED Module with micro USB socket, cables to plug in to the RX, CAN Bus extension cable, USB Cable for linking to a computer for setting up and updating and double sided mounting tape..
2nd box has the optional GPS with built-in compass, CAN Bus Extension lead and mounting accessories.
3rd Box has the PMU (BEC)
The overall quality and finish is of a very high standard.. I will break down each competent individually.
The Main component is the FC (Flight Computer/controller) This is identical in size and shape to anyone familiar with the NAZA-M for Multi-rotor's it measures 45.5x31.5x18.5mm, 25g,
Consumption is around 300mA@5v input operating voltage is 4.8-8.4v. This unit connects between the RX using either standard male to male servo leads (supplied) PPM or Futaba S-Bus (this will need selecting in set-up, see part 2) This gets connected on the left hand side and on the Right Hand side plugs in the servo's and throttle/ESC. Also on the left hand side is 2 CAN Bus sockets, 1 for the flight status LED with USB and the 2nd for Optional GPS/Compass. This is orientation specific, more on this in part 2.
Servo's supported Analog 50HZ, Digital 145HZ (1520us center point)
Tail servo's Analog 50Hz(1520us center point),Digital 333Hz/560Hz(760us center point),Digital 125Hz/165Hz/270Hz/333Hz(1520us center point)
LED Module, this will display different flight conditions and will need mounting in a place easily visible from the ground, I.E near the back and underneath, This connects directly to the FC via Can Bus, Also it has a micro USB to connect to a computer so easily accessible would be ideal, there is also included an extension CAN BUS cable to extend the mounting distance. 25x25x7mm, 13.4g, powered through the CAN BUS, 4.8-8.4v, 60mA@5v
PMU/BEC, This is a very high powered BEC module, with heatsink.. It has excellent operating voltage taking an input battery from 11-52V.. It can supply a continuous 5A (Max 15A) output at a switchable 5.8v or 7.4v This has 2 leads running from it, 1 for the main battery or battery used for electronics (this will need your own type of plug fitting) the 2nd plugging in to the Main FC on port X1, to power unit and servo's.. This voltage can also be monitored on the computer.. 39x27.5x12.7mm, 37g
This unit is my only gripe so far, I think the input voltage is brilliant, however I would have liked to have seen the output voltage maybe fully adjustable in the software, as my donor helicopter (more on this later) has 5v servo's fitted though out.. Also I would have liked either 7.5A or 10A continuous output.. (However a separate BEC maybe used instead)
GPS/Compass, Optional unit.. 46(dia)x9mm 21.3g, 4.8-8.4v, 60mA @5v, it is powered though the CAN BUS and connects to the left hand side of the main FC, there is also included a 2nd CAN BUS extension.. This is orientation specific, more on this in part 2.
Once installed all the settings can be made on a computer and software and firmware can easily be updated, again I will go more in depth of this in part 2 over the coming next few weeks.
topgearuk is offline Find More Posts by topgearuk
Old Feb 08, 2013, 03:58 PM
topgearuk's Avatar
Joined Dec 2003
Installation and set-up.. Part 2 (to follow)
Small update 14th feb,
Added photo's of strip down and some Specs:
Donor heli is a Align Trex600ESP stretched using a cut down 700 tail boom and tail drive to fit a 50 sized body. The motor has been changed to an Align outrunner BL600M, Separate BEC Castle creations 20A Pro, 3 x JR DS8231 servo's for the head and a Futaba tail servo (These were already fitted).. Flight pack is 2 x 6s 3700mAh in parallel
I'm just waiting on a new ESC 100A YEP and Align Flybarless head.
This will be added to over the next couple of weeks, please feel free to ask questions and I will do my best to answer them.
topgearuk's Avatar
Joined Dec 2003
Flight Report and set-up, Part 3 (to Follow)
This is a flight in stock configuration, with components listed from above.. This will be a good before and after comparison.
Airwolf Align Trex 600, Flight in Garden (3 min 45 sec)
Old Feb 08, 2013, 03:59 PM
topgearuk's Avatar
Joined Dec 2003
Software downloads including manuals and set-up video's
http://www.dji-innovations.com/produ...a-h/downloads/
DJI Naza-H Setup Demo (7 min 0 sec)
DJI Naza-H Assistant Software Configuration (15 min 22 sec)
DJI Naza-H GPS Atti.Mode with position lock (2 min 38 sec)
Old Feb 08, 2013, 08:14 PM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
TG very nice start. There is another thread over here: http://www.rcgroups.com/forums/showthread.php?t=1774265. I will cross reference your build and review.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Old Feb 09, 2013, 12:56 AM
topgearuk's Avatar
Joined Dec 2003
Thanks Ed, I new the controller had been out a couple of months, but didn't dawn on me to check if there was a thread.. Doh!
Old Feb 09, 2013, 07:40 AM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
TG no problem, the more information the better.
Site Sponsor
Old Feb 10, 2013, 09:35 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Interesting. Surprised there was no mention of price in the first post.
Edit: Can it be made to bailout (self level), only if the heli goes below a certain altitude/height?
beenflying is offline Find More Posts by beenflying
Old Feb 10, 2013, 09:41 PM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
$459 including GPS. There is no bailout feature on the Naza, no hard deck, only self leveling in ATTI and GPs modes.
Site Sponsor
Old Feb 10, 2013, 10:49 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Thanks.
Old Feb 14, 2013, 09:11 AM
topgearuk's Avatar
Joined Dec 2003
Small update to posts 2 and 3.. While I'm waiting on the flybarless head and new ESC to arrive.
Just some strip down photo's and a before flying video..
Old Feb 22, 2013, 03:05 AM
spdrflyr is offline
Find More Posts by spdrflyr
Joined Mar 2008
HAZA-H and the NEWBEE
Hi guys...learned to hover tail and head-in and fly a right and left hand circuit 3 years ago...then gave it up. Now back to flying Helis again after retiring last Oct. 2012. I have a Raptor e720 I will be installing the unit in and am hopeful it will provide some buffer to my rough skills. I'm probably dreaming! I will be happy to post back here my impressions of the NAZA-H with GPS from a Newb's perspective!
Wish me luck!
spdrflyr is offline Find More Posts by spdrflyr
Old Feb 22, 2013, 12:54 PM
topgearuk's Avatar
Joined Dec 2003
Wish me luck!
Hey good luck, yes please feel free to post set-up, pics and your experience here..
I'm still waiting on one part, if it's not one thing it's another, lol.. Think it will be Monday before it's delivered although small chance it could turn up in the morning which would be great because I could get it fitted and fly it this weekend if it does!
Old Mar 03, 2013, 05:48 PM
topgearuk's Avatar
Joined Dec 2003
Started doing some more work today after the parts turned up in the week, but came to a halt, again, when I realised I needed different size balls links...
If it's not one thing it's another, 1st off as I'm converting an old 600esp this requires a different sized main shaft then the one supplied in the conversion kit, so that was another order and now as I'm using the original swash plate that requires different size ball links Arrr... Anyway ordered today..
I have managed to wire up the new ESC, installed Naza, Futaba RX and power module (which I'm going to use now)
I have plugged the Naza in to the computer just to look at settings, really like the new layout format and when I come to do the set-up it looks fairly straight forward!
One big disappointment is I really wanted to use S-Bus as 1 wire would be so much neater, but for some reason the NAZA-H does not recognise the R7008SB RX through S-BUS... This also happens to be the same for the WK-M and the Naza-M, so must be some kind of protocol, I hope DJi can sort this out in the very near future.
I wanted to use this particular RX as it has built-in telemetry.. So I have had to wire it up conventionally.. It does work with S-Bus on other Futaba RX's but not this one
Old Mar 03, 2013, 06:16 PM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
Topgear, I started down the same road upgrading my 500 to DFC. I found that I needed a new swash plate as well. I just went back to my old I2 flybarless head. It works well but I was looking forward to trying the DFC. Next time. Ready to start mount the electronics a finely get the 500 flying again. Looking forward to your build.
Site Sponsor
Article DJI Innovations Naza-H - Review CSpaced Electric Heli Talk 53 Oct 24, 2015 07:43 PM
Mini-Review ***DJI NAZA-H with GPS, Helicopter Auto Pilot, Flybarless Controller Mini-Review topgearuk Scale Helicopters 4 Feb 08, 2013 04:01 PM
Sold DJI Wookong H Heli auto pilot system Ifly101 Aircraft - Electric - Helis (FS/W) 0 Jan 20, 2013 09:43 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 08:47 PM
