Old Feb 08, 2013, 09:26 AM
jb86 is offline
Find More Posts by jb86
United States, MA, Fitchburg
Joined May 2005
kevlar thread wrap spars info
i wrapped the spars/joiner box on my oly ii with kevlar
what do i coat with?
epoxy or CA or polycrylic?
jon
jb86 is offline Find More Posts by jb86
Old Feb 08, 2013, 09:31 AM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
Any of those will do. The purpose of the adhesive is only to prevent the thread sliding along the spar. Epoxy will be heaviest, ca quickest.
jkettu is offline Find More Posts by jkettu
Old Feb 08, 2013, 10:07 AM
kzimmerm is offline
Find More Posts by kzimmerm
Kurt Zimmerman ≡LSF 4461≡
kzimmerm's Avatar
Montrose, NY
Joined May 2003
I would thin down epoxy with alcohol, coat the kevlar then blot it with paper towels... As jkettu stated, the idea is to lock it into place. The coating does little to nothing in adding strength. I just don't like using ca on a spar with the chance it wicks into the wood. I learned my lesson long ago that ca and spars don't mix. The wood becomes too brittle and looses it's flexibility which could result in failure.
Kurt
kzimmerm is offline Find More Posts by kzimmerm
Old Feb 08, 2013, 11:39 AM
jtlsf5 is offline
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Use thick CA. Apply liberally, wipe excess off with a tissue or paper towel, then hit it with accelerator. Minimal wicking (per KZ) and will effectively lock the thread in place.
JT
jtlsf5 is offline Find More Posts by jtlsf5
Old Feb 08, 2013, 12:23 PM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
why not just use laminating epoxy?
Fly2High is offline Find More Posts by Fly2High
Old Feb 08, 2013, 02:13 PM
jtlsf5 is offline
jtlsf5's Avatar
Joined Jul 2007
Lots of extra hassle for no structural value. All one needs to do is keep the thread whipping in place, and epoxy won't do that any more efficiently than CA, though it will likely add more weight.
JT
Old Feb 08, 2013, 06:50 PM
1967250s is offline
Find More Posts by 1967250s
1967250s's Avatar
United States, VA, Alexandria
Joined Sep 2008
Just use Weldwood or polyurethane, light + cheap!
1967250s is offline Find More Posts by 1967250s
Old Feb 10, 2013, 01:30 AM
ozmo01 is online now
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
ozmo01 is online now Find More Posts by ozmo01
Old Feb 11, 2013, 11:20 AM
Mark Miller is offline
Find More Posts by Mark Miller
Mark Miller's Avatar
United States, WI, Waunakee
Joined Oct 2002
I agree with JT....I see no need to add anything except at the ends of the wrap. Look at an Ava spar. The wrapping is not bonded down except where the wrap starts and ends and where the D-tube is attached to the spar. Whatever you use will not add anything to the strength of the wrap since the wrap is being stressed in tension only. Also, remember to round the corners of the spar cap so that the wrap is not running over a sharp corner.
Mark Miller is offline Find More Posts by Mark Miller
Old Feb 14, 2013, 10:41 PM
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Hi Mark,
I thought the instructions for the BD called for wetting the Kevlar?
It wouldn't be the first time I was wrong.
I went back and reviewed the Allegro light files and they talk about wetting the tow out AFTER wrapping the spar then blotting down well. I should not post when I have just come off a long work shift! I think I confused the method of wetting cloth to bag a wing here, MY BAD.
Old Feb 16, 2013, 12:03 AM
Dennis Everett is offline
Find More Posts by Dennis Everett
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
I would totally wet it out with thin ca
Dennis Everett is offline Find More Posts by Dennis Everett
For Sale Carbon and Kevlar thread spinandfly Aircraft - General - Miscellaneous (FS/W) 1 Jan 05, 2013 07:07 AM
For Sale Carbon and Kevlar thread spinandfly Aircraft - Electric - Airplanes (FS/W) 0 Jan 04, 2013 06:28 AM
Discussion Kevlar wrapped Oly 3 spar SHVentus Thermal 37 May 01, 2012 09:23 PM
Discussion Spar Wrapping Kevlar Thread vs. CF Tow atjurhs Thermal 12 Jul 25, 2007 11:42 AM
