Old Feb 08, 2013, 08:01 AM
FyreSG is offline
Find More Posts by FyreSG
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
Idea
Improving flight experience with 9X
I had been fiddling with ER9X firmware on my Turnigy 9X transmitter, to tweak it to suit my preference when flying WLtoys V939. I'd like to share the highlights of my configurations (may work on the stock 9X firmware; may be adapted to suit flying other quads like the bigger V929, V949, or V959):
  • Asymmetric rates - Elevator more, Aileron less. This is because banked turns do not require a lot of banking. I have the tendency to apply too much aileron input, thus messing up my banked turns. This lets me pull off smooth banked turns easily.
  • Low rate - Elevator 25%, Aileron 15%. When lifting off the ground to commence flight, or when coming in to land, or to glide around gracefully.
  • Medium rate - Elevator 80%, Aileron 50%. High speed fun, but no accidental flips.
  • High rate - 90% for Elevator & Aileron. For flips.
  • Rudder Expo -20 (both left and right). Banked turns need quite a lot of yaw. This setting makes rudder input more sensitive at mid stick, requiring little rudder inputs to execute smooth banked turns.
  • Normal Throttle Curve as -100, -80, 20, 75, 100. Moving the curve to the right is to let the quad hover at around mid stick or perhaps 60% throttle, instead of 40%.
  • Low Batt Throttle Curve as -100, -30, 30, 75, 100. When the quad needs more throttle input (e.g. 75% to hover) that is the battery is running low on juice, switch to this curve to "boost" the quad.
  • Flight time set to 4:00.
Sample flight procedures
  1. Start with Throttle Hold engaged, Low Rate, and Normal Throttle Curve.
  2. Disengage Throttle Hold, increase Throttle to around 50% to 60% to lift the quad off the ground.
  3. Fly the quad at Low Rate to the actual flying area.
  4. Switch to Medium Rate, and fly the quad.
  5. At the around 2:30, switch to Low Batt Throttle Curve to keep the amount of throttle required to hover at mid stick.
  6. At 4:00, the count down timer sounds. Switch to Low Rate, and send the quad back for landing.
  7. When the quad has landed, engage Throttle Hold, and switch back to the Normal Throttle Curve.
  8. Unplug the battery and rest the quad, before beginning the next session.
If you have other interesting ideas to make flying quads with 9X more enjoyable, please share with us!
FyreSG is offline Find More Posts by FyreSG
Old Feb 09, 2013, 09:04 AM
Stephan81 is offline
Find More Posts by Stephan81
Joined Feb 2013
Sorry I don't mean to hijack your thread. I am new to this hobby. I've been looking into radios. I currently have a syma x1 and read it's much better and responsive with a turnigy x9 so I'm going to order one up.
Now, I have a V202, V939, LB V2, and Hubsan X4 on order. Will the Turnigy radio work for them all, from what I gather from what I have read it won't. What radio would work best for all the models I have.
Stephan81 is offline Find More Posts by Stephan81
Old Feb 09, 2013, 10:03 AM
scousethief is offline
Find More Posts by scousethief
scousethief's Avatar
United Kingdom, England, Redcar
Joined Jan 2006
Its going to be near impossible to find any radio that works with all quads , i have the 9x and cant fault it with er9x firmware.
Thanks for the settings fyre , mine are pretty similar.
scousethief is offline Find More Posts by scousethief
Old Feb 13, 2013, 07:11 PM
aka_TEKK is offline
Find More Posts by aka_TEKK
Canada, QC, Montreal
Joined Apr 2012
Hello FyreSG, could you share your eepe file. Thanks
aka_TEKK is offline Find More Posts by aka_TEKK
Old Feb 14, 2013, 07:07 AM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
My configurations for V939
I don't have the USB programmer with me right now, so here are ER9X settings:
Code:
Channel    Weight    Source  Switch
CH1        +100%     AIL
CH2        +100%     ELE
CH3        +100%     THR     ID0
      R    +100%     THR     !ID0
      R    -100%     HALF    GEA
CH4        +100%     RUD
Channel    Subtrim    From    To    Dir
CH1         0           0    100
CH2         0           0    100    INV
CH3         0           0    100
CH4         0           0    100
     Expo    Rates %    SW1  SW2
RUD  -20   100
THR    0   100
ELE    0   25, 80, 90   AIL  ELE
AIL    0   15, 50, 90   AIL  ELE
Throttle Points  ID0: -100    -80    +20    +75    +100
Throttle Points !ID0: -100    -30    +30    +75    +100
With this configuration I was able to do this :
WLtoys V939 Moving Pirouettes (4 min 41 sec)
Old Feb 14, 2013, 07:11 AM
bangkomit is offline
Find More Posts by bangkomit
Hubsan X4 - H36 - V911
bangkomit's Avatar
Indonesia, Jakarta
Joined Oct 2012
So you can't do pirouette with stock tx?
bangkomit is offline Find More Posts by bangkomit
Old Feb 14, 2013, 07:51 AM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
Can be done but the piros are painfully slow. And in this case it's not just piro at the same spot but during a banked turn. I can't do this with the stock TX without losing control of the quad.
Cool 1st FPV Flight with HQuad, great experience! tecdux Multirotor Talk 8 Feb 26, 2013 03:07 PM
Discussion experience with Axi 5330/20 Double? Jesbering Power Systems 32 Feb 16, 2013 03:12 PM
Discussion Anyone have experience with these batteries? electricrc68 Micro Ready-to-Fly 6 Jan 13, 2013 07:09 AM
Discussion JR 9x/9x2 with Spektrum Experience hoppie Radios 5 Jan 15, 2008 12:44 AM
Discussion Inverted flight - again, but with wierd improvements? turnbui Micro Helis 6 Oct 21, 2007 05:19 AM
