Old Feb 08, 2013, 08:01 AM
Dale 813 is offline
Find More Posts by Dale 813
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
Help!
Removing crank shaft OS 55 AX
Need help. Need to replace engine case. Got everything out except crank shaft. Not sure how to remove it.
Dale 813 is offline Find More Posts by Dale 813
Old Feb 08, 2013, 08:13 AM
Hemikiller is online now
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
If you haven't done it already, remove the prop drive washer and the thrust washer behind it. You should then be able to push the crankshaft straight back out of the case. If it's stuck, put the tip of the crankshaft on a block of wood and push down on the case, or rap gently with a rubber mallet or block of wood. Whatever you do, do not hammer on the end of the crankshaft without protecting it with a wood, aluminum or brass block.
Hemikiller is online now Find More Posts by Hemikiller
Old Feb 08, 2013, 09:17 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Besides what is mentioned above. What you do is heat the crankcase up good (I like to use a heat shrink gun, but many people use a oven or a propane torch too). Then using a brass hammer I tap the crankshaft out. The crankcase expands slightly when heated making it easier to remove the crank and bearings. Sometime the bearings can be in quite tight and you might need to reheat the crankcase to repeat the process to tap out the bearings too. I use a 1/4 thich brass rod to catch the inside race lip and tap the bearings out evenly by working the tool around the edge. The brass rod develops a lip on it making it easier to do too.
You should always replace the bearings whenever you remove the crankshaft for any reason. Do not try to reuse the bearings.
Here is a video that can give you a idea on how it is done
How to change model airplane engine bearings (part 1 of 2) (10 min 41 sec)
earlwb is offline Find More Posts by earlwb
Old Feb 08, 2013, 01:14 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Thanks guys. Awesome vid. Question about the bearing replacement. This motor is brand new. Was on a maiden flight for 25 seconds when the elevator failed and it crashed forcing the carb into the case cracking both. Being as new as it is, is it still necessary to replace the bearings ? I was going to junk the motor but I found a used carb for $40 and a new case for $60.
Old Feb 08, 2013, 01:36 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
You tend to invariably damage the bearings in removing them from the case. But in odd situations where the bearings fall out easily like shown in the video, then no you don't have to replace them. Usually the bearing balls get indented into the races, so if you reuse the bearings and reassemble it, you can feel the indentations as you carefully turn the crankshaft over.
Yeah it is a bummer to crash a engine on its maiden flight. But lots of us have been there and done that too.
Old Feb 08, 2013, 02:33 PM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Yep. No biggie. I learned a good lesson. I couldn't find my Radio south hinges and was in a hurry to get a plane together and used the crappy hinges that came with the model. I noticed that the CA didn't get sucked in like the radio south ones. I didn't think nothing of it till it took a Dirt Nap. Elevator came out on the down out of a dive. won't happen again. I just ordered more Radio south hinges. Ps I appreciate the help guys
Old Feb 09, 2013, 12:22 AM
gerryndennis is offline
Find More Posts by gerryndennis
gerryndennis's Avatar
New Zealand, Canterbury, Christchurch
Joined Jun 2008
G'day Dale,
Bad news about the crash but good that you are repairing your engine.
If it hit hard enough to break the carb off then you will probably need to check that your crankshaft isn't bent. A friend with a lathe and a dial test indicator is needed here. They are reasonably easy to straighten.
You will more than likely have damaged the front bearing so definitely change that. While you are at it it's probably worth changing the rear as well, I believe they are reasonably cheap from rcbearings (.com?) or boca bearings.
Just to clarify what Earlwb said, I prefer to push the crank out first cold then heat the case. If you heat first the rear bearing may come out with the crank, then it's a pain to get off the shaft. The video shows it correctly I think.
Searches here should give you all the info you need. Go carefully and you will be fine, if you get stuck ask here before getting out the vice grips and hammers. It's all fun and learning.
Dave H
gerryndennis is offline Find More Posts by gerryndennis
Old Feb 09, 2013, 12:27 AM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
Dale,
Whatever you do, never heat the crankcase in the rear bearing area, before the crankshaft has been removed from the engine.
If you do, it could come out together with the rear bearing (since they are both steel and expand at the same rate); and then it will be very difficult to separate them...
Also, I prefer to remove split drive-cone mounted prop-drive washers; using a suitable puller; not with a hammer.
After its removal, you will only need your fingers to push the crankshaft out.
DarZeelon is offline Find More Posts by DarZeelon
Old Feb 09, 2013, 12:37 AM
kbozarth is offline
Find More Posts by kbozarth
Joined Jun 2008
Originally Posted by DarZeelon View Post
Dale,
Never has been a problem for me, or those I learned from. Once the crank is out with the bearing, hitting the bearing with a little heat again allows the bearing to slide off.
Not a "never do" thing.
Kurt
kbozarth is offline Find More Posts by kbozarth
Old Feb 09, 2013, 12:58 AM
DarZeelon's Avatar
Joined Nov 2003
Kurt
No, it does not, Kurt.
It is a problem and many who did that needed to reinstall the crankshaft+bearing in the crankcase, in order to separate them.
Doing it that way is wrong.
And why would one need to solve this problem, if he can prevent it happening in the first place, by first removing the crankshaft and then heating the crankcase to remove the rear bearing?
Even if someone has the ingenuity to solve a problem he created, wisdom means not creating that problem in the first place; don't you think so?
Old Feb 09, 2013, 07:25 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I have had a bearing come out on the crankshaft a couple of times. No big deal. There was a layer of old varnish and or corrosion on the crank that had built up over time. A little cleaning and the bearing slid right on off. The rear bearing just fits onto the crankshaft, a almost perfect fit. So just a little bit of corrosion or castor oil residue can make it harder to get off. But usually a little judicious cleaning of the crank will let a new bearing slip right on OK.
Old Feb 09, 2013, 11:25 AM
Dale 813 is offline
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
All done. Only had to heat the case to remove the front bearing. But being only $5 for both front and back, I'll get new ones. The crank being bent is another story. If it were bent. Wouldn't it be very difficult to turn ? I'll try to find someone that can check it.
Old Feb 09, 2013, 12:55 PM
DarZeelon's Avatar
Joined Nov 2003
Dale,
Regarding the rear bearing, I'd recommend that you install one with a plastic cage (Phenolic or Polyamide).
If this metal cage 'goes' from corrosion, or excessive RPM, it will grenade and possible cause a lot of damage to the piston and/or the sleeve.
That's hefty damage...
Old Feb 09, 2013, 06:41 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
You can put the crank down on a piece of plate glass and slowly rotate it and watch the tip and see if it moves up and down any. A very tiny bit of movement is OK as there is a bit of runnout tolerances allowed during manufacture. But the runout is pretty miniscule though. I forget at the moment what the measurement would be. Anyway if the tip moves up and down then it got bent. You can straighten them if you want to. The worse that can happen is it breaks off the threaded portion. But if you got it to straighten out then you didn't have to get a new crank then.
Old Feb 12, 2013, 07:58 AM
Hemikiller's Avatar
Joined Dec 2005
Dale,
The 55AX has a D-drive for the prop washer, so it should slide right off. Regardless, that puller is a lifesaver.
http://www.amazon.com/Lisle-54150-Ba.../dp/B000I14RY6
Sold OS 55 AX bench ran only Bob Shultz Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 29, 2013 05:43 AM
Found Os 55 ax nib barkleyb Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 28, 2013 01:59 PM
Sold *** Price Reduced *** OS Power Box E-3010 Muffler for OS 46 AX, 55 AX and others modestmagi Aircraft - Fuel - Engines and Accessories (FS/W) 2 May 08, 2012 09:48 PM
Sold OS Power Box E-3010 Muffler for OS 46 AX, 55 AX and others modestmagi Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 05, 2012 04:40 PM
Discussion What is the tolerence on the crank of an OS .46 AX ? SKromfols Engines 7 Dec 10, 2006 09:37 AM
