United States, SC, Pelion
Joined Feb 2013
You should have two settings in your transmitter that can be adjusted to get different behaviors of "RPM" (I usually see it called "head speed" or "rotor speed"). There is usually a throttle curve setting and a pitch curve setting. These two settings will tell the transmitter how calm or wild the collective will behave at different stick positions.
Here's a good link to a forum topic on that subject: http://www.rcgroups.com/forums/showthread.php?t=1651066 If I understand it correctly, on a collective pitch heli, the rotor speed is usually set so that it spins up to operational speed before you actually lift off, with the pitch still at a slightly negative or zero angle. Then it should stay at that speed and just use the angle of the rotors to go up and down in flight (though agressive 3d is probably not like that). |
| Thread Tools | |
| Discussion Blade Nano CP X vs Walkera Super CP - First CP heli | brad24 | Micro Helis | 24 | May 16, 2013 03:26 AM |
| Sold Walkera Master CP, Devo7, Scorpion | mike3488 | Aircraft - Electric - Helis (FS/W) | 1 | Jan 31, 2013 03:41 PM |
| For Sale deleted | billnj2002 | Aircraft - Electric - Helis (FS/W) | 0 | Jan 10, 2013 08:28 AM |
| Help! Walkera Master CP | skhayallee | Beginner Training Area (Heli-Electric) | 2 | Jan 08, 2013 12:36 AM |
