Old Feb 08, 2013, 07:20 AM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
Build Log
Super Simple Test Bench for motors and props
I wanted to test a motor and a prop quickly and easily.
That's why I have done this super simple test bench.
There are better designs and constructions, but this one works perfectly and is light, strong, cheap, quickly made, convenient to use and easy to store.
Needed:
Three pieces of wood (100x60x20mm in my case), only 7 holes to drill,
4 woodscrews, two 3mm screws for the motor, single sided adhesive foam tape,
Turnigy Servo Tester, Wattmeter, ESC, battery and scale.
Demonstration:
Turnigy Park480 850KV, 3S 3300mAh battery and 5kg scale,
4 props: APC 10x4.7 SF, GF 10x4.5, Graupner 10x5 and Graupner 11x5.
2 levels: half throttle (1.5ms pulse width), generally used to hover, and full throttle (2ms) for max thrust.
Half throttle thrust and efficiency are the most interesting values for multicopters.
Tare is automatically done when switching on scale.
Props are positioned upside down on motor.
APC 10x4.7 SF
50%: 12V, 4.4A, 53W, thrust 444g, efficiency 8.4g/W
100%: 11.6V, 18.4A, 213.9W, thrust 1134g, efficiency 5.3g/W
GF 10x4.5
50%: 12.2V, 4.4A, 53.5W, thrust 433g, efficiency 8.1g/W
100%: 11.8V, 17.8A, 210.3W, thrust 1141g, efficiency 5.4g/W
Graupner 10x5
50%: 12.1V, 3.7A, 45.2W, thrust 381g, efficiency 8.4g/W
100%: 11.9V, 12A, 142.5W, thrust 885g, efficiency 6.2g/W
Graupner 11x5
50%: 12.3V, 4.2A, 51.8W, thrust 456g, efficiency 8.8g/W
100%: 11.9V, 15.5A, 183.9W, thrust 1189g, efficiency 6.5g/W
Among the 4 props tested with this motor at this voltage, Graupner 11x5 is the best, APC and GF being not far behind.
These combos are suitable for 1400-1600g quad, 2100-2400g hexa or 2800-3200g octo.
That's what I wanted to know.
This simple test bench might help you choose motors and props or solve problems.
Any improvement suggestion would be appreciated.
Mortimer is offline Find More Posts by Mortimer
Old Feb 09, 2013, 09:57 AM
Mortimer is offline
Mortimer's Avatar
Joined Apr 2010
Graupner 11x5 has been added to the previous test.
Park480 850KV and Graupner 11x5:
Old Feb 10, 2013, 03:00 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Could be simple but not relevant results, too close to the bench.
My take about really useful and simple has been posted here:
http://www.rcgroups.com/forums/showp...&postcount=261
renatoa is offline Find More Posts by renatoa
Old Feb 10, 2013, 03:41 PM
Mortimer is offline
Mortimer's Avatar
Joined Apr 2010
I have used for more than one year a conventional test bench with a vertical propeller.
Advantage: absence of ground effect.
Drawback: volume of the device and horizontal air flow, everything is blown away on a two meters distance.
Super Simple Test Bench has none of these disadvantages.
It's small, air flow is vertical and air speed below the prop is insignificant.
That means it can be used instantly on your desk surrounded by sheets of paper, nothing fly around it.
There is also no ground effect, ceiling being 2 meters above the prop, and no drag due to arm supporting the motor.
Values recorded with the two devices are practically the same.
Build one, it's easy, you will compare with what you have got before.
Old Feb 10, 2013, 05:06 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
I like it!
I'm gonna have to try this. I just bought this wattmeter for testing.
TheFernMan is offline Find More Posts by TheFernMan
Old Feb 10, 2013, 05:32 PM
Mortimer is offline
Mortimer's Avatar
Joined Apr 2010
Nice ! When it will be working, give us your impressions.
Leave some distance between prop and table, at least 13-15cm.
@ renatoa
I have also made the test bench below.
I have been disappointed, not accurate enough.
Old Feb 11, 2013, 12:20 AM
renatoa is offline
Joined Sep 2007
Which way not accurate? compared to what ?
For me it seems to describe very well the horizontal thrust in a real plane.
Conversely, the bellcrank direction change mechanism is the one not inspiring confidence to me.
Discussion Simple Load Test for DLG Wing BavarianCharles Hand Launch 43 Feb 08, 2013 10:44 AM
Discussion Very Simple Motor Test Bench ivgarcia Power Systems 8 Oct 10, 2011 05:17 PM
Question Bench testing motors, props and batteries Andrew u.k. Power Systems 3 Dec 13, 2006 05:27 AM
motor/prop test bench txzagi Power Systems 9 May 08, 2002 04:36 PM
motor/prop test bench txzagi Fuel Plane Talk 1 May 06, 2002 06:48 PM
