Old Feb 08, 2013, 03:56 AM
annimaus is offline
Find More Posts by annimaus
Germany
Joined Feb 2013
Help!
Slow Servo Moves
I have an Eagle Tree Guardian 2D/3D and installed in my Graupner Rookie QR. All servos are in the right direction. The gain Cannel is not connect because I lack a channel for it. Mode Channel is connected. In 2D mode the servos are moving in the right direction, but very slowly, when I move the plane around his axes. If The Guardian is off, Servos move is normaly speed
Two ailerons are connected with a Y-cable. The software on the PC, I drop everything to factory settings. I've seen your video tutorial. Here, all the servos move much faster. What did I do wrong, or is it the Guardian? The controls on the Guardian is turned to maximum. Also, it changes nothing.
annimaus is offline Find More Posts by annimaus
Old Feb 11, 2013, 02:34 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi, if you connect the Guardian to the PC, does the "AHI" display move very rapidly as you move the guardian around? Or, does it move very slowly and lag the movement of the guardian?
billpa is offline Find More Posts by billpa
Site Sponsor
Old Feb 12, 2013, 06:07 AM
annimaus is offline
Germany
Joined Feb 2013
Old Feb 14, 2013, 01:57 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi, we're discussing this here and I'll get back ASAP!
Site Sponsor
Old Feb 14, 2013, 02:29 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi, we have a couple more questions for you, if you don't mind:
• Could you describe the results from when you move the sticks in 2D Mode, 3D Mode and Disabled? Do the servos move quickly with the stick movements, or do they lag and catch up? Is the movement smooth, or jerky?
• When you pitch/roll the airplane while in 2D Mode without touching the control sticks, you say that the servos move “slowly.” Could you please elaborate? Does it seem like the servos are not moving as far, or they are going slowly and then catching up? Would you be able to post a short youtube video of the behavior?
Thanks!
Site Sponsor
Discussion Servos slow to return thintz Micro Helis 5 Jan 10, 2013 01:15 PM
Help! Moving the throttle moves the servos ! flylowfast Radios 1 Jul 24, 2012 06:33 PM
Help! when i move the aileron stick,my ele servos move slowly and twitch guitaramp68 Radios 14 Aug 07, 2009 08:21 PM
Discussion moving CX2 an a direction - why does it only move for a short while , then slow down? vwattindc Coaxial Helicopters 39 Sep 10, 2008 01:59 AM
Throttle servo moves when elevator servo is moved chris8105 Fuel Plane Talk 22 Jan 10, 2007 02:53 PM
