Old Feb 08, 2013, 07:35 PM
rcmaverick is offline
Find More Posts by rcmaverick
rcmaverick's Avatar
Australia, NSW, Sydney
Joined Mar 2012
Originally Posted by C₄H₁₀ View Post
Myth #8: Pusher props are needed for pusher planes
Myth #16: A lipo will explode if you look at it funny
... I think this'll hold us for awhile
Well I did a search for pusher prop and lipo and this is what I found:
http://ecx.images-amazon.com/images/I/51HDkgRebQL.jpg
And I was looking at it funny..
so I will say it is CONFIRMED
But You can Also call it BUSTED?
Sorry Ladies.. (Its just a joke)
rcmaverick is offline Find More Posts by rcmaverick
Old Feb 08, 2013, 08:00 PM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Are we up to #19?
forward cg helps wind penetration, whatever that is.
scirocco is offline Find More Posts by scirocco
Old Feb 08, 2013, 11:19 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
Originally Posted by JetPlaneFlyer View Post
And another (Myth 4):
"The optimum CG position for any plane is 25-30% chord" (insert whatever % range you like, the myth has variations)
It's a decent rule, and has been for many decades for a maiden. I assume you are saying it's incorrect with unconventional aircraft.
eagle777 is offline Find More Posts by eagle777
Old Feb 08, 2013, 11:21 PM
Damnandblastit is offline
Find More Posts by Damnandblastit
A disaster in the making.
United Kingdom, England, Selby
Joined Jan 2013
Yep, they were wrong..
ALL AIRFOILS produce more lift as speed increases, cambered, symmetrical, flat plate.. it makes no difference. Lift increases in proportion to the square of airspeed, for any and all airfoils.
Think about it.... If symmetrical airfoils made the same lift regardless of airspeed then how come they need adequate airspeed to fly?
the only time lift would not increase is if the airfoil was at an angle of attack at which it made no lift in the firstplace, in that case lift is zero for all airspeeds (again this applies to all airfoils)
A symmetrical airfoil produces no lift at zero angle of attack whatever it's airspeed. It is neutral.
By your thinking a highly cambered wing should float off the ground from rest.
Naughty boy, I think you knew exactly what I meant all along and are being deliberately provocative in order for me to have to do battle again with the bloody awful predictive text on me kindle.
Damnandblastit is offline Find More Posts by Damnandblastit
Old Feb 08, 2013, 11:25 PM
eagle777 is offline
Closed Account
Joined Aug 2007
Heh, #20 - 100W/Lb is enough for scale flight (my idea of it anyway). Google says: 100 (watts per pound) = 220.462262 m^2 / s^3
Old Feb 09, 2013, 02:38 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Guilty to being provocative but i'd like to point out:
No.. by my thinking ALL airfoils have lift proportional to airspeed squared, therefore no airfoil will float off the ground at rest because the square of zero is zero. It's actually the thinking that symmetrical airfoil lift is not proportional to airspeed squared that leads you to thinking that a symmetrical airfoil will fly just as well at zero airspeed as it would at 100mph.
Also ALL airfoild have a zero lift angle of attack. For symmetrical airfoils it's zero degrees, for cembered airfoils its a negative value. This means nothing anyway because in flight airfoils all make lift, so the symmetrical airfoil must have some positive AoA while it's flying... Therefore it's lift WILL increase with speed exactly like any other airfoil.
Which leads me to myth #21
Flat bottom airfoils 'balloon' at high speed while symmetrical do not.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Feb 09, 2013, 02:42 AM
Aberdeen
Joined Mar 2006
Yes, but it also produces a sub-optimal CG for many aircraft that are not unconventional. The eFlite Apprentice for instance has a CG at 36% chord as per manual, and it's very stable, the 'rule' says it should be un-flyable.
Old Feb 09, 2013, 02:45 AM
Aberdeen
Joined Mar 2006
Originally Posted by scirocco View Post
Are we up to #19?
yeah good one.. I've never quite figured the difference between 'wind penetration' and airspeed But either way a forward CG doesnt help.
Old Feb 09, 2013, 03:03 AM
Aberdeen
Joined Mar 2006
I cant believe that no one has mentioned the best myth of all.
Myth #22 - Downwind turns are dangerous because the plane loses airspeed due to the wind blowing from behind.
This myth may even be supported by (flawed) math.
  1. Wind in from the North at 15mph. Plane is flying East at 25mph.
  2. Plane turns south, wind is now from behind so planes airspeed = 25mph - 15mph = 10mph.
  3. Plane stall and falls out of sky due to loss of airspeed.
Old Feb 09, 2013, 03:12 AM
Joined Jan 2013
I think we are at cross purposes. Of course all airfoils produce lift as a product of half rho v squared x s.
The symmetrical foil however produces it at top and bottom and they cancel each each other out therefore no overall lift. This is why they are used in all flying tails as they produce up or down force as a result of the angle of attack: only.
Damn this bloody kindle
Old Feb 09, 2013, 03:31 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
I was just checking in to see if we'd got to the downwind turn yet.
Of course as all sensible people know that isn't really a myth. I once had a crash and I'd just turned downwind so that's proof positive that downwind turns are dangerous. Plus it's simply obvious that if the wind is blowing the wrong way across the airfoil the plane is bound to fall out of the sky.
, just in case.
Steve
slipstick is offline Find More Posts by slipstick
Old Feb 09, 2013, 03:47 AM
Joined Jan 2013
, just in case.
Steve
Sorry this is a myth. Your relationship to a steady airstream does not alter, only your relationship to the ground.
Wind shear however is a different thing altogether and you may come a cropper if you are low and slow on a gusty day.
Old Feb 09, 2013, 03:53 AM
Aberdeen
Joined Mar 2006
I think I detected a tiny hint of sarcasm in Slipstick's post
PS.. Steve, check post # 69
Old Feb 09, 2013, 08:45 AM
Staffs, UK
Joined Nov 2003
It's amazing how people will reply in deadly seriousness, even to posts which carefully include the "wink, wink, I'm only joking" smiley .
Still I suppose if you're new round here and don't know anyone you can always convince yourself you're the only person in the world who understands anything , blast it .
Steve
Old Feb 09, 2013, 08:52 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Myth 23: The noisier they are, the faster they are!
Myth 24: Jets are the fastest model planes.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Sold 3 electric props for sale (brand new) Parkzone, GWS 3 blade and 2 blade aquaanox Aircraft - Electric - Power Systems (FS/W) 3 Jan 31, 2013 10:36 PM
For Sale 3 Blade - Props, and More Props $1 each ($4 for a set of 2CW and 2 CCW) HoverThings Aircraft - Electric - Multirotor (FS/W) 1 Aug 08, 2012 09:44 PM
Are 3 blade props more efficient than 2 blades austinflyer Electric Plane Talk 23 Sep 26, 2010 02:43 AM
Discussion Why is 2 blade prop more efficient then 3 blade prop? butters149 Modeling Science 30 Sep 05, 2008 11:36 PM
GWS 10 x 4.7 prop gives more thrust than APC Red Baron 47 Power Systems 3 Sep 30, 2001 08:24 AM
