Old Feb 08, 2013, 01:00 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Originally Posted by jrb View Post
....also, more baldes give more watts out per watts in -- better efficiency.
Nope, it's the opposite. The general rule is more blades reduces propulsive efficiency. this is because you want to have the largest 'disk' size as possible and fewer blades means you can have larger diameter while absorbing the same input power.
quote Prof Martin Hepperle:
For a given power P, it is always desirable to use the largest possible propeller diameter D, which may be limited by mechanical restrictions (landing gear height) or aerodynamic constraints (tip Mach number). That's why most man or solar powered airplanes use large, slowly turning props. These catch a large volume of air and accelerate it only slightly to achieve the maximum efficiency.
http://www.mh-aerotools.de/airfoils/
Another good read: http://www.nar-associates.com/techni...ncy_screen.pdf
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Feb 08, 2013, 01:20 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
The prop thing has been raised so many times, (plenty of thread if searched for), often the conclusion is the counter-balanced single blade prop is the most efficient.
eflightray is online now Find More Posts by eflightray
Old Feb 08, 2013, 01:23 PM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Originally Posted by Lnagel View Post
That would be myth #5.
Larry
Originally Posted by Sparky Paul View Post
ALL planes climb when power is applied. It's what makes them go up.
Some planes pitch up badly with power because there's a problem with the wing incidence-tail incidence, or the c.g..
I understand that some high-lift airplanes will climb when power is applied but most airplanes are neutral in that they go straight and level whether they are at 50% power or 100% power. My experience has been that a neutral airplane which climbs severely under full power has a thrust angle issue. Just like a plane that dips severely when the throttle is released has too much up thrust (needs too much trim to maintain level flight under power).
Mike_Then is online now Find More Posts by Mike_Then
Old Feb 08, 2013, 01:33 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Actually Prof Martin Hepperle are in I agreement; have been since he editted his original document about multblade props!
Also his point about diameter is exactly why 1/2 CL speed uses a single blade prop!
They must ROG and need all the prop disk diameter possible.
If they could bungee or catapult launch they'd go back to two!
jrb is offline Find More Posts by jrb
Old Feb 08, 2013, 01:51 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
At a constant airspeed where the airplane is not descending or climbing, the trim is set to maintain that airspeed.
Adding or reducing power makes the trim setting incorrect, and the airplane will climb or descend. The pilot will adjust the trim to suit the condition.
Disturb the airplane from trimmed flight with an elevator pulse, and the airplane will oscillate but return to the initial trimmed condition.
Thrust offsets are usually only effective at low speeds.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Feb 08, 2013, 02:04 PM
Ron H is online now
Find More Posts by Ron H
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Originally Posted by eflightray View Post
Myth #7 Modelers always agree with each other as there is really only one correct answer.
(Problem seems to be, everyone has there own correct answer ).
I disagree, I think you are right.
Ron H is online now Find More Posts by Ron H
Old Feb 08, 2013, 02:08 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
[re: foamies having or not having spars...]
Originally Posted by Stick_01 View Post
I've built some that don't. Some planes have low enough wing loading and gentle enough flight characteristics that a spar is only extra weight.
I just checked -- my micro 4-Site doesn't have spars. As far as I know, every other foamie in my fleet has 'em, including a 24" Depron fella with about 6 oz. AUW.
rafe_b is offline Find More Posts by rafe_b
Old Feb 08, 2013, 02:26 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Myth #8: Pusher props are needed for pusher planes
Myth #8.1: The numbers on a prop are always on the front face
Myth #9: A brownout crashed your plane
Myth #10: Four-channel planes are always harder to fly
Myth #11: Models can't exceed calculated pitchspeed
Myth #12: Leaving lipos fully charged won't hurt them
Myth #13: 13 is an unlucky number
Myth #14: Balsa is better than foam
Myth #15: You can use throttle endpoints to limit ESC current and heat
Myth #16: A lipo will explode if you look at it funny
Myth #17: Foam is better than balsa
Myth #18: You can fly that jet since you play a lot of videogames
Myth #19: You can acquire leptospirosis from a Coke can
Myth #20: A brushless motor will burn out if you exceed its voltage rating
Myth #21: It can't happen to me
Myth #22: A brushless motor will burn out if you exceed its watt rating
Myth #23: Adding weight to your electric plane will make it go faster
Myth #24: Trims are a set-n-forget affair
Myth #25: I don't need mechanical setup. My radio does all that.
... I think this'll hold us for awhile
Piece is offline Find More Posts by Piece
Old Feb 08, 2013, 02:49 PM
compressor man is offline
Find More Posts by compressor man
Professional tree finder
compressor man's Avatar
GA,USA
Joined Jul 2010
HaHaHaaa
compressor man is offline Find More Posts by compressor man
Old Feb 08, 2013, 02:55 PM
mrittinger is online now
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Efficiency and thrust are not the same thing
Many full scale birds added blades to absorb the ever-increasing HP while maintaing ground clearances.....doesn't mean they were more efficient, they just absorbed more power while allowing for practical use on an aircraft...you can only fit so large a prop before hitting the ground
Google the Thunderscreech for supersonic prop tips.....
REPUBLIC XF-84H "Thunderscreech" (sound recording) (0 min 31 sec)
mrittinger is online now Find More Posts by mrittinger
Old Feb 08, 2013, 02:57 PM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Funny the things that stick in memory - my aerody prof put it this way: for perfect propulsive efficiency, accelerate an infinite amount of air an infinitesimal amount. Very much in the context of bigger disk area and less acceleration.
scirocco is offline Find More Posts by scirocco
Old Feb 08, 2013, 03:05 PM
Zagadka is offline
Find More Posts by Zagadka
Liverpool, UK
Joined Aug 2004
"Myth #19: You can acquire leptospirosis from a Coke can"
I'd never heard that one before but I guess it's safe calling it a myth unless it's a coke can full of rat pee?
Kev
Zagadka is offline Find More Posts by Zagadka
Old Feb 08, 2013, 03:11 PM
cmdl is offline
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
does 4s make you faster vs. 3s? allowing for prop changes of course.
cmdl is offline Find More Posts by cmdl
Old Feb 08, 2013, 03:25 PM
ChillPhatCat is offline
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
OK you got me interested... how's this work?
Obviously since a prop unloads in the air you can get more than the pitch speed calculated from static RPM on the ground...
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Feb 08, 2013, 03:35 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
If speed is the only goal and the battery and prop are the only changes then yes, switching to 4S from 3S with appropriate prop changes will normally make a plane faster... But you'll always be sacrificing something, and I think the negatives will tend to outweigh the positives.
Sold 3 electric props for sale (brand new) Parkzone, GWS 3 blade and 2 blade aquaanox Aircraft - Electric - Power Systems (FS/W) 3 Jan 31, 2013 10:36 PM
For Sale 3 Blade - Props, and More Props $1 each ($4 for a set of 2CW and 2 CCW) HoverThings Aircraft - Electric - Multirotor (FS/W) 1 Aug 08, 2012 09:44 PM
Are 3 blade props more efficient than 2 blades austinflyer Electric Plane Talk 23 Sep 26, 2010 02:43 AM
Discussion Why is 2 blade prop more efficient then 3 blade prop? butters149 Modeling Science 30 Sep 05, 2008 11:36 PM
GWS 10 x 4.7 prop gives more thrust than APC Red Baron 47 Power Systems 3 Sep 30, 2001 08:24 AM
