Old Feb 11, 2013, 12:25 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
The problem with catching snowflakes is that they always seem to slip through the holes in my butterfly net.
Oh, well. I suppose some mysteries aren't meant to be solved by science.
Piece is offline Find More Posts by Piece
Old Feb 11, 2013, 12:39 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Originally Posted by Ron H View Post
It rarely snows here, but I have noticed that when it does, some flakes fall right to the ground while others seem to stay aloft indefinitely. If someone could catch one of each and examine the airfoils we may all learn something.
Well, I'm certainly not going out in that cold stuff to experiment.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Feb 11, 2013, 02:52 PM
rcmaverick is offline
Find More Posts by rcmaverick
rcmaverick's Avatar
Australia, NSW, Sydney
Joined Mar 2012
Originally Posted by JetPlaneFlyer View Post
ALL airfoils make lift in EXACTLY the same way. There is not one theory for 'curved' airfoils and one for flat or symmetrical airfoils. Newton and Bernoulli are not competing theories, one describes the laws of motion the other the relationship between velocity and pressure in fluid flow. Both are true when it comes to describing how a wing makes lift, it's not a case of one or the other.
Simply put; wings produce lift by turning airflow (regardless of what the shape of the airfoil is).
http://www.grc.nasa.gov/WWW/k-12/airplane/right2.html
Steve
With all control surfaces in a neutral position and symmetrical wings what makes the plane go up and not down?
rcmaverick is offline Find More Posts by rcmaverick
Old Feb 11, 2013, 02:56 PM
3rd Try is offline
Find More Posts by 3rd Try
United States, NY, Champlain
Joined Jul 2012
Angle of attack combined with apparent wind speed.
Dennis
3rd Try is offline Find More Posts by 3rd Try
Old Feb 11, 2013, 03:02 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
It can go up, down or fly level. The 'thing' that decides which is the 'longitudinal dihedral' (the difference in incidence between wing and tail) combined with the CG position. Otherwise known as 'trim'.
Basically the force generated by the tail in balance with the moment produced by the CG hold the wing at an AoA to the airflow, which makes the wing lift. This is exactly the same as it works with any other airfoil, with the possible exception of some reflexed airfoils (and I guess swept and twisted wings) that don't need tails.
There is really nothing fundamentally different in how a symmetrical airfoil plane flies compared to any other, except it can fly upside down just as well as upright.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Feb 11, 2013, 03:14 PM
Damnandblastit is offline
Find More Posts by Damnandblastit
A disaster in the making.
United Kingdom, England, Selby
Joined Jan 2013
That is determined by the mainplanes centre of pressure at that particular trim.
Damnandblastit is offline Find More Posts by Damnandblastit
Old Feb 11, 2013, 03:24 PM
Lnagel is offline
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
I believe you are working under a misconception. It sounds as if you think that because all control surfaces are neutal that the wing's symmetrical airfoil will be at 0 degrees angle of attack. That just ain't so. It is as JetPlaneFlyer said, the wing's angle of attack is determined by the incidence angle between the wing's chord line and the horizontal stab's chord line. Most planes are set up so that the wing's incident angle is from 1 to 2 degrees more positive than the horizontal stab's incidence angle with the elevator at neutral. Also, don't confuse incidence angle with angle of attack. They are not the same thing. The incidence angles of the wing and stab are constant, but the angle of attack the airplane assumes from that decalage is dependent upon the fore and aft position of the CG.
Larry
Old Feb 11, 2013, 03:30 PM
Lnagel is offline
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Oh goody, another myth.
Larry
Old Feb 11, 2013, 03:37 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Here's one that I think is a real 'Myth' (Myth 3 on the list)
"If your plane climbs too much when you open the throttle, it needs more nose weight"
I've lost track of how often i've seen people advise to do this when it's possibly the very opposite of what's needed.
can you elaborate on this one ? my power glider diamond 2500 was tail heavy and i had to put four 7G lead weights in the nose. Tail heavy when balancing from CG as per manual. and it was like flying a porpoise on crack
fastfwd is offline Find More Posts by fastfwd
Ron H is offline
Find More Posts by Ron H
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Well, no rain after all. But I was able to experiment with a balloon. Believe it or don't, a balloon will fall to the ground every time if you hold it upside down the release it. It even appears to accelerate, so thick symmetrical wings may have an edge when it comes to speed.
Ron H is offline Find More Posts by Ron H
Old Feb 11, 2013, 03:48 PM
Joined Jan 2013
Larry
No myth. You yourself stated that AofA was the reason why planes climbed or descended. Since they are both irrevocably linked you cannot alter one without the other.
Just seeing if you are awake and being a little provocative myself.
Does anyone know how to turn the useless predictive text off on a kindle fire? It is really doing my head in.
Old Feb 11, 2013, 03:58 PM
Lnagel is offline
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
No myth.
'tis so.
Larry
Old Feb 11, 2013, 04:04 PM
Lnagel is offline
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Well, I tried it and my balloon just turned rightside up and went up. I don't know if it has anything to do with it, but my lungs are too weak from years of smoking to inflate the balloon so I inflated it with my pressurized helium bottle. It did, however move in the direction of the more rounded side, so mayber there is something to this.
Larry
Old Feb 11, 2013, 04:05 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
If the plane is excessively nose-heavy, it'll take more up-elevator trim to fly level at a given "comfy" speed. When you start bumping the speed up past there, the CG position obviously remains the same but the force acting on the stab increases, which drives the tail down, points the nose up, and induces the excessive climbing condition. Moving the CG back will allow you to reduce that trim, which will keep the pitch changes less severe with increasing speed.
Old Feb 11, 2013, 04:06 PM
Aberdeen
Joined Mar 2006
No myth.
If it's only the centre of pressure that determines if the wing lifts or not then take the tail off and see how it flies
FWIW the centre of pressure on a symmetrical airfoil is static at (near enough) 25% chord for all angles of attach below stall. (assuming sub sonic flight)
Sold 3 electric props for sale (brand new) Parkzone, GWS 3 blade and 2 blade aquaanox Aircraft - Electric - Power Systems (FS/W) 3 Jan 31, 2013 10:36 PM
For Sale 3 Blade - Props, and More Props $1 each ($4 for a set of 2CW and 2 CCW) HoverThings Aircraft - Electric - Multirotor (FS/W) 1 Aug 08, 2012 09:44 PM
Are 3 blade props more efficient than 2 blades austinflyer Electric Plane Talk 23 Sep 26, 2010 02:43 AM
Discussion Why is 2 blade prop more efficient then 3 blade prop? butters149 Modeling Science 30 Sep 05, 2008 11:36 PM
GWS 10 x 4.7 prop gives more thrust than APC Red Baron 47 Power Systems 3 Sep 30, 2001 08:24 AM
