Old Feb 08, 2013, 03:48 AM
rcmaverick is offline
Find More Posts by rcmaverick
rcmaverick's Avatar
Australia, NSW, Sydney
Joined Mar 2012
Myth #1 - 3 bladed props give more thrust than 2 bladed ones
I am going to start this mini series of myths - TV series mythbuster style. We find a myth - Confirm the myth then verify/ bust/ plausible it.
This is an easy one - but anyone who has verified it through practical tests using any means is more than welcome to post their findings. You can even propose an accepted engineering formulae from a scientific journal or wiki (?)
Feel free to add your own myth but for the sake of continuity please number them sequentially.
rcmaverick is offline Find More Posts by rcmaverick
Old Feb 08, 2013, 07:09 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Busted!
jrb is offline Find More Posts by jrb
Old Feb 08, 2013, 07:25 AM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
MYTH 2 - The tip of a wing can stall and not the whole wing.
1320fastback is offline Find More Posts by 1320fastback
Old Feb 08, 2013, 07:27 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Originally Posted by jrb View Post
Busted!
I'm not so sure. It all depends what other variables you want to hold constant.
For instance if you take an electric set up with a two blade prop and you swap the prop for a three blade (same diameter, pitch and blade shape) thrust will indeed increase (along with watts). So in that respect three blades do give more thrust than two, so ‘myth’ is verified.
If the question was re-phrased to say:
“'Watt for Watt' do three blades make more thrust” the answer would be “No”.. In fact the opposite is true, as your thrust/power graphs show.
Morale of the story is:
Ask woolly ambiguous questions - get woolly ambiguous answers
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Feb 08, 2013, 07:29 AM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
I've always heard that multi-bladed props give less thrust than 2-blade props. That has also been my findings as well with some models. I had a 3-blade prop on a .60-sized P-40 and a 4-blade prop on a .60-sized Spitfire. Both looked awesome on the ground and in still photos while in flight but they were definitely slower than their 2-bladed glow-powered counterparts (even though mine were electric and superior in every other way ) I kid... I kid... don't anyone get their knickers in a twist.
Performance went up significantly in both cases after switching to a 2-blade prop.
So is that to say that if WWII fighters such as the F-4U, P-51. etc., had 2-bladed props they would have been even faster? Assuming ground clearance for the prop wasn't an issue of course.
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Feb 08, 2013, 07:30 AM
Aberdeen
Joined Mar 2006
Thats perfecty possible and in fact occurs very often on wings with high taper.
http://naca.central.cranfield.ac.uk/...aca-tn-713.pdf
Old Feb 08, 2013, 07:39 AM
Mark Wolf is offline
Find More Posts by Mark Wolf
Flying electric since 1986
Mark Wolf's Avatar
USA, IN, Brownsburg
Joined Oct 2000
The only thing that needs to be "busted" are blanket statements. Some 3 bladed props give more thrust than a two blade, others less. Some wings can tip stall, some won't. There are very few absolutes in this world, it's all shades of grey.
Mark Wolf is offline Find More Posts by Mark Wolf
Old Feb 08, 2013, 07:44 AM
Aberdeen
Joined Mar 2006
No, because RPM and diameter are limited due to need to prevent the prop tips going supersonic. So the only option once you get to a certain power level is more blades, even though less blades are more efficient in terms of basic momentum theory.
This is not an issue on models due to much smaller props.
Old Feb 08, 2013, 07:45 AM
Aberdeen
Joined Mar 2006
Originally Posted by mark wolf View Post
the only thing that needs to be "busted" are blanket statements.
+1 ...
Old Feb 08, 2013, 08:02 AM
Aberdeen
Joined Mar 2006
Here's one that I think is a real 'Myth' (Myth 3 on the list)
"If your plane climbs too much when you open the throttle, it needs more nose weight"
I've lost track of how often i've seen people advise to do this when it's possibly the very opposite of what's needed.
Old Feb 08, 2013, 08:03 AM
Mike_Then's Avatar
Joined Apr 2001
If a plane climbs when power is applied, I would think it's a thrust angle issue, not a balance issue.
Old Feb 08, 2013, 08:05 AM
Aberdeen
Joined Mar 2006
And another (Myth 4):
"The optimum CG position for any plane is 25-30% chord" (insert whatever % range you like, the myth has variations)
Old Feb 08, 2013, 08:06 AM
Aberdeen
Joined Mar 2006
Yes, possibly, but counter intuitivly it could also mean that it's nose heavy (i.e. you need to remove nose weight)
Old Feb 08, 2013, 08:24 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Out runners are similar to IC in that you simply can't blame the prop when it's simply swapped!
Will performance be increased going to 2 blades from the stock 3 of the micro Corsair?
Back in the day when we used gear boxes you could actually get equal performance at the same watts from the motor with various props by changing the gear ratio.
Though they key point here is w/too many parameters it's just babble.
Old Feb 08, 2013, 09:34 AM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
The Myth of Sisyphus is one of my favorites.
rafe_b is offline Find More Posts by rafe_b
Sold 3 electric props for sale (brand new) Parkzone, GWS 3 blade and 2 blade aquaanox Aircraft - Electric - Power Systems (FS/W) 3 Jan 31, 2013 10:36 PM
For Sale 3 Blade - Props, and More Props $1 each ($4 for a set of 2CW and 2 CCW) HoverThings Aircraft - Electric - Multirotor (FS/W) 1 Aug 08, 2012 09:44 PM
Are 3 blade props more efficient than 2 blades austinflyer Electric Plane Talk 23 Sep 26, 2010 02:43 AM
Discussion Why is 2 blade prop more efficient then 3 blade prop? butters149 Modeling Science 30 Sep 05, 2008 11:36 PM
GWS 10 x 4.7 prop gives more thrust than APC Red Baron 47 Power Systems 3 Sep 30, 2001 08:24 AM
