Old Dec 27, 2003, 06:45 PM
crashingagain is offline
Find More Posts by crashingagain
crashingagain's Avatar
Sacramento
Joined Nov 2003
will my lipos die on gws 350?
Hi, I have a lithium 1050 2s pack from lhs. Im not sure of the make but its from www.tperc.com and from their website I assume its an etech.
My question is can I run this with my gws 350c or my 300b in a 1p configuration without damaging the cells or will I have to get another pack to run in parrallel,Id rather not use 2p because the single pack balances the plane perfectly.
If I can run the pack should I still use the 10x8 on the c drive
and the 9x7 on the b drive.
crashingagain is offline Find More Posts by crashingagain
Old Dec 27, 2003, 10:54 PM
WJ Birmingham is offline
Find More Posts by WJ Birmingham
WJ Birmingham's Avatar
St. Louis Metro
Joined Apr 2003
E-Tec does not make a 1050 cell. It's probably a Kokam. If that's the case, I believe the Kokam 1050 cell was a 5C max cell.
C = mAh/1000
So, 1.05 * 5 = 5.25 Amp max discharge rate.
You'll want to get an amp meter that will allow you to check the amp draw of the motor. Going off of the gear ratios and props you're indicating you want to run, yes, you will ruin that pack.
WJ
WJ Birmingham is offline Find More Posts by WJ Birmingham
apc props on gws 350 gearbox schaubro GWS (Grand Wing Servo) 5 Jan 15, 2005 11:52 PM
3 Blade EP9070 on GWS 350-C Opinions Please! Dmerino Power Systems 3 Oct 09, 2004 12:15 PM
Best prop for speed on GWS 350? JIMA Power Systems 18 Jul 10, 2004 11:41 AM
anyonw know if i could move my top wing on the gws pt-17 to make the CG more aft? jeff262 Foamies (Kits) 4 Jan 08, 2004 09:54 PM
Will 8X720 NiMh Work On a GWS Pico Stick? vkmaynard Parkflyers 16 Oct 24, 2002 09:55 PM
