Old Feb 07, 2013, 07:07 PM
Hoot is offline
Find More Posts by Hoot
United States, TX, Houston
Joined May 2003
Help!
Instructions to glass a center section
I bought a ZupAir flying wing and need to join the wing panels using fiberglass and epoxy. Can somebody point me to a pictorial that shows how to do it and get a smooth finish? I can glass it but it would look like crap.
S Gibson
Hoot is offline Find More Posts by Hoot
Old Feb 07, 2013, 07:35 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Where'nthaheck were you Saturday?!?! I missed you!
Lay on the glass, and mix the epoxy. Carefully brush on the epoxy so as not to move the glass. Lay on a paper towel and press it down with a piece of foam padding to absorb the excess. Carefully peal the paper towel off without lifting the glass. Lightly warm the epoxy with a heat gun so the epoxy will flatten. Let it harden and it will be pretty smooth...
See you next trip I make to Houston... or... If you come north, let me know...
Jack
schrederman is offline Find More Posts by schrederman
Old Feb 08, 2013, 07:50 AM
John Walter is offline
Find More Posts by John Walter
John Walter's Avatar
USA, IL, Naperville
Joined Feb 2003
Get some 3M Formula 77 at Home depot. Lightly spray the glass then cover it with waxed paper. Trim the glass/paper to size. Lightly spray the glass side of the glass/paper then apply it to the wing. The 77 will hold the glass in place while you remove the paper. Apply the epoxy per the post above.
John Walter is offline Find More Posts by John Walter
Old Feb 08, 2013, 08:53 AM
ultimatetwo is offline
Find More Posts by ultimatetwo
Fly to live- Live to fly
ultimatetwo's Avatar
ROTA-CADIZ-SPAIN
My two cents....
http://www.rcgroups.com/forums/showt...1758332&page=5
Manolo.
ultimatetwo is offline Find More Posts by ultimatetwo
Old Feb 08, 2013, 01:13 PM
RWCLOUD is offline
Find More Posts by RWCLOUD
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
Draw a rectangle on a piece of paper the size you want the glass . Tape the paper on work surface on one end. Lay a piece of wax paper over this and tape one end. Lay the glass on the wax paper that is a little larger then the rectangle you drew and tape one end,this holds everything in place while wetting out. Wet out the glass throughly then blot off excess epoxy. Using a rotary cutter or sharp knife cut out the rectangle . lift up the three layers, glass, wax paper and paper. Discard the plain paper. Lay the glass and wax paper on the seem then pull masking tape tightly over the wax paper. After the epoxy has cured, remove the masking tape and wax paper. You should have a nice shiny smooth surface!
I know this sounds like a lot of work, but its really not and the results look very nice. Plus you don't have excess epoxy in places where you don't want it.
I'm opposed to using 3M77 to hold glass in place, it creates a barrier that epoxy cannot penetrate, thus making a weak joint
Blue Skies........................Tim
RWCLOUD is offline Find More Posts by RWCLOUD
Old Feb 08, 2013, 02:15 PM
jtlsf5 is offline
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Not when done properly. A quick, light mist is enough to help keep glass in place without affecting the ability of resin to fully wet out the glass and bond to wood or whatever else is underneath.
A heavy soaking coat of 3M77 is a different story and undesirable.
JT
jtlsf5 is offline Find More Posts by jtlsf5
Old Feb 08, 2013, 03:57 PM
williamson is offline
Find More Posts by williamson
Joined Feb 2006
S Gibson
You may find this article useful:
http://charlesriverrc.org/articles/c...fiberglass.htm
williamson is offline Find More Posts by williamson
Old Feb 08, 2013, 05:44 PM
Hoot is offline
Joined May 2003
Thanks for the advice. My problem in the past was the fiberglass fraying on the edges as I brushed on the epoxy.
Jack,
I was in Indiana last weekend. Glad you are back in Texas ! See you this summer !
S Gibson
Old Feb 08, 2013, 05:52 PM
cityevader is online now
Find More Posts by cityevader
IT'S NOSE HEAVY!!!!!!!
cityevader's Avatar
United States, CA, San Jose
Joined Mar 2012
Cut the FG so that the strands are oriented at a 45 (or in an "x" fashion) rather than in a "+" fashion. This way, it won't start unraveling at the edges, and also all of the fibers are working when under load. Otherwise, the fibers running spanwise are doing most of the work.
cityevader is online now Find More Posts by cityevader
Old Feb 08, 2013, 09:20 PM
RWCLOUD is offline
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
Jack,
S Gibson
If you do it my way, you'll have perfectly straight edges, since you don't touch the glass after cutting it. I use 1 layer 0-90 and 1 layer 45 + - 45 of 1.60 ounce glass.
Blue Skies.....................Tim
Old Feb 08, 2013, 09:56 PM
cityevader's Avatar
Joined Mar 2012
I just re-read RWCLOUD's method, as the first time I glossed over it because it was mildly confusing so I merely skipped it. Upon closer reading, his is a superior method.
First benefit: the cutting is easier, as using scissors on "free-floating" fiberglass at a 45 is kinda difficult because the cloth moves all over the place away from the scissors, so cutting out the overall shape AFTER wetting it out, AND while laying flat on worktop, yields a much more uniform cut!!
Second: (could be benefit, could be drawback) with the wax paper, it'll yield a much smoother finish (at the expense of a mild amount of extra epoxy to fill the weave) in one single step.
Third: Most of the messy work is done AWAY from the plane, and then the "final product" is then brought TO the plane.
Perhaps some pics of the process to help those like me who get wrapped up in the wording?
Old Feb 08, 2013, 10:07 PM
RWCLOUD is offline
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
I'm sorry, but I've never taken pictures of the process and I didn't invent it either. Its common in DLG's, so maybe you could find pictures somewhere in the hand launch forum, thats where I learned myself some years ago.
As far as excess weight, once you blot the excess epoxy, there won't be any excess weight even though the top surface is smooth.
If your worried about the wax paper you can use a plastic shopping bag instead. But be for warned, wait until the epoxy is fully cured before removing it, otherwise it might stick forever!But if you wait at least 24 hours, no problem.
Old Feb 11, 2013, 09:57 PM
davidjensen is online now
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
I use the 3M 77 to tack the cloth to the wing. I wet it out and then blot out as much as possible with paper towels. I then use std. 2" clear packing tape and put strips over the wetted cloth and about 1/8" out from the edge of the cloth . I use a rubber roller on top of the tape to squeeze any epoxy to the edge of the tape and sop it up with paper towels. I will work the bottom and then the top side and it takes about 1 hour. After the cure remove the tape and sand the areas that need it and buff with 1200 and your done.
davidjensen is online now Find More Posts by davidjensen
Old Feb 12, 2013, 08:28 AM
karterjimm is offline
Find More Posts by karterjimm
In the heart of it all.
Joined Feb 2010
Cutting FG
For those of you who still cut fiber glass in a dry mode, it is a whole bunch easier when you dip your scissors in alcohol just before the cut. Also helps with the pizza style cutter , too. Cutco scissors are the best! Not the cheapest, but the best.
karterjimm is offline Find More Posts by karterjimm
For Sale AVA pro center section big jer Aircraft - Sailplanes (FS/W) 3 May 21, 2013 06:58 PM
Wanted Graphite 3.4m wing center section JoeSantora Aircraft - Sailplanes (FS/W) 0 Jan 24, 2013 09:51 AM
Wanted Aspire center section set or ST. Bowdie Aircraft - Sailplanes (FS/W) 0 Jan 22, 2013 10:50 PM
Question Glassing Center Sections Mode One The Builders Workshop 14 Jan 31, 2010 04:04 PM
FS: Eclipse 3.6m Glass Center Section wamdue Aircraft - Sailplanes (FS/W) 3 May 24, 2005 03:00 AM
