Old Feb 07, 2013, 03:39 PM
MikeAnderson is offline
Find More Posts by MikeAnderson
ago involo ergo sum
MikeAnderson's Avatar
Kemptville, Ontario, Canada
Joined Dec 2000
PL8 balance charge TP packs with two balance leads
Guys - sorry if this has been asked & answered before, but what balance adapters should I get in order to charge the pack pictured below? (Is this what's called a 'split' pack?)
It's a ThunderPower 6S pack with one TP 3S connector & 1 TP 5S connector with only 4 cells wired in.
How do I use two (TP) safe parallel adapters when the pack only has 1 pair of main discharge leads? There doesn't seem to be a matching wiring diagram in either the PL8 or the Safe parallel Adapters guide.
MikeAnderson is offline Find More Posts by MikeAnderson
Old Feb 07, 2013, 06:35 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
You can daisy chain these together. One per pack you want to charge in parallel
http://www.usastore.revolectrix.com/...rallel-Adapter
Or you can purchase TP to JST-XH adapters and use the MPA. FMA doesn't sell these, but they are all over the place. The last batch I received was from HK.
Gregor99 is offline Find More Posts by Gregor99
Old Feb 07, 2013, 08:38 PM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
No, that's not a split pack. A split pack would have two sets of main leads coming from it.
Ohmic is offline Find More Posts by Ohmic
Discussion 3x 1S balanced charging lead: How to setup correctly? nr1 Batteries and Chargers 3 Jan 15, 2013 01:55 PM
Question TP balance lead ?? duker733 Batteries and Chargers 5 Jan 15, 2013 11:37 AM
Question Balance leads on Turnigy 1800mAh 2S Lipo Rx Pack rayonnair Batteries and Chargers 11 Jan 10, 2013 10:50 AM
Sold A123 packs with TP balance leads 10s and 4s Terkan Aircraft - Electric - Batteries & Chargers (FS/W) 5 Jul 09, 2007 08:48 PM
