Old Feb 08, 2013, 08:08 AM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Ask for "L" hooks ...
tkallev is offline Find More Posts by tkallev
Old Feb 08, 2013, 09:33 AM
prodjx is offline
Find More Posts by prodjx
prodjx's Avatar
United States, AZ, Tucson
Joined Jan 2007
Thank's Tom. And please don't forget to use the lubricant when cutting the thread's and blow the chip's out too.
prodjx is offline Find More Posts by prodjx
Old Feb 08, 2013, 01:01 PM
kostuk is offline
Find More Posts by kostuk
Joined Nov 2003
Thanks guys!
Dave I'll see you on Sunday at Maxwell.
Ray
kostuk is offline Find More Posts by kostuk
Old Feb 08, 2013, 02:09 PM
harlequin is offline
Find More Posts by harlequin
Larry
harlequin's Avatar
Massachusetts, USA
I've made my own tow hooks from 1/8 steel rod, cut with a 4-40 die, and some 4-40 hardware. The die cost about $5 at my local hardware store. A 3-foot steel rod will make lots of tow hooks!
Larry
Update: The thread was cut for 6-32 (not 4-40). Subsequent inflight operation shows that the 1/8" material is bending out of shape during launch. I am considering 3/16" rod, and an 8-32 thread.
harlequin is offline Find More Posts by harlequin
Old Mar 31, 2013, 04:51 AM
Desert flier is offline
Find More Posts by Desert flier
Desert flier's Avatar
Australia, SA, Morphett Vale
I wave towed lots of small gliders up with nothing but a small velcro patch stuck onto the glider and a small patch on a pice of ply atatched to the tow line when i want to release or get to far out of station it just weleases when i want to get off its just back stick
Desert flier is offline Find More Posts by Desert flier
Old Apr 05, 2013, 11:44 AM
burke757 is offline
Find More Posts by burke757
United States, VA, Norfolk
Joined Sep 2007
JT, how do you keep your hooks from twisting or turning on launch, resulting in a pop off?
burke757 is offline Find More Posts by burke757
Old Apr 06, 2013, 12:54 AM
prodjx is offline
prodjx's Avatar
Joined Jan 2007
A lock washer would help keep it tight. You just have to check it once in a while. I've never tried Loc-Tite.
Old Apr 06, 2013, 08:47 AM
vintagesailplnr is offline
Find More Posts by vintagesailplnr
United States, PA, Nesquehoning
Joined Dec 2003
3 sizes of SS towhooks
Hi:
I only make and carry stainless steel tow hooks. Won't rust when landing on the early morning dew!
5, 6 and 8 -32 thread, that way you can epoxy the T-nut in place and still remove tow hook later.
1/8",5/32", and 3/16" Each come with two T-nuts.
$4.50ea shipped for $0.50 no matter the quantity.
Jim
Originally Posted by kostuk View Post
Hi
Does anyone know an inexpensive source for tow hooks or something that can be modified from Home Depot to make one?
Ray
vintagesailplnr is offline Find More Posts by vintagesailplnr
Old Apr 07, 2013, 12:04 AM
harborflyer is offline
Find More Posts by harborflyer
harborflyer's Avatar
United States, CA, Santa Ana
Joined Jul 2010
If you use a "T nut", and have access, use a regular nut on inside to "jam nut" the tow hook.
Ross
harborflyer is offline Find More Posts by harborflyer
Old Apr 07, 2013, 01:26 AM
OldSchool676 is offline
Find More Posts by OldSchool676
Joined Apr 2013
Thx
Great info, thanks!
OldSchool676 is offline Find More Posts by OldSchool676
Old Apr 20, 2013, 12:37 AM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
I just bend a long shouldered allen head bolt then Dremmel off the head.
ozmo01 is offline Find More Posts by ozmo01
Old Apr 20, 2013, 10:35 PM
kzimmerm is offline
Find More Posts by kzimmerm
Kurt Zimmerman ≡LSF 4461≡
kzimmerm's Avatar
Montrose, NY
Joined May 2003
Originally Posted by tkallev View Post
I just put one of these in my Miles.
Kurt
kzimmerm is offline Find More Posts by kzimmerm
Old Apr 22, 2013, 05:25 PM
Windependence is offline
Find More Posts by Windependence
The King Moonracer of balsa.
Windependence's Avatar
USA, MN, Rochester
Joined Mar 2008
Kurt, Am is correct in assuming you placed a hardwood block in the fuselage of your Miles for this to bite into? I'm guessing probably 3/4 of an inch thick? I thinking about doing the same this for my current woody build and am just wondering how deep you anchor that hook into the fuselage.
Wayne
Windependence is offline Find More Posts by Windependence
Old Apr 22, 2013, 07:54 PM
kzimmerm is offline
kzimmerm's Avatar
Montrose, NY
Joined May 2003
Wayne
Exactly.. see the picture enclosed.
Kurt
Hangar 9 Tow Hook TGKconnectors Non R/C Items (FS/W) 2 Jan 26, 2013 07:11 PM
For Sale Rocket City Pro-Tow Tow hook. ronrange Aircraft - Sailplanes (FS/W) 1 Jan 24, 2013 10:15 PM
Wanted Adjustable tow hook for flat bottom fuse ak79 Aircraft - Sailplanes (FS/W) 6 Jan 15, 2013 09:36 PM
Sold Airtronics Metal hook releasable tow hook gavoss Aircraft - Sailplanes (FS/W) 1 Mar 09, 2012 04:14 PM
