Old Feb 07, 2013, 04:55 AM
Flying Bougie is offline
Find More Posts by Flying Bougie
Canada, ON, Sharon
Joined Feb 2008
.40 Ultiimate Bipe questions
I'm not sure if this is the right place for these questions.
I have a 40 ultimate Bipe with a OS Max 46 AX. I have heard it may be underpowered, I have not flown it yet. I am still practicing on my 25 trainer. What do you figure ?
Speaking of figure, I will put a pilot on the canopy. What scale is the pilot for this 40 size ? 1/6" ?
Flying Bougie is offline Find More Posts by Flying Bougie
Old Feb 07, 2013, 05:22 AM
Canada, ON, Sharon
Joined Feb 2008
Originally Posted by Flying Bougie View Post
I
Actually just looking at dimensions, 1/6 looks big. Maybe 1/8 or 1/10 ?
Old Feb 07, 2013, 06:05 AM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
if you are talking bout the arf version, then yes I heard it was a lil on the heavy side, but I do believe that the 46ax should have plenty of power!
I have the kit built, with a webra speed 50, and it huals u know what! raraly ever use full throttle!
my memory along with my hips, left me long ago! I can't member what size pilot I used! sry no help there!
P.s. the right prop, would make a big diff. I would start with an 11x6!
whiskykid is offline Find More Posts by whiskykid
Old Feb 07, 2013, 09:35 AM
Canada, ON, Sharon
Joined Feb 2008
Thanks, good to know the 46 AX is probably ok. Only ran once, stil need to break-in and repair a small issue on the tail :-(
It is the ARF, I haven't balanced the CG yet, and will be curious to weigh it soon and will report.
About the little guy (the pilot), i just ordered on fleebay with basic measurements. Also just did a adhock cockpit on mspaint which i will print and laminate (better then black). Not pro scale stuff, but much better than current and i think it will be ok.
Old Feb 07, 2013, 10:28 AM
team sleprock
whiskykid's Avatar
Joined Dec 2009
other then being a lil heavier, I hear it is a great flying plane! I love mine, been told they will snap or stall if to slow on aproach!
mine snaps inverted, but I can drag the tail on landings! so you should do a coupla stall tests before any finnals!
Old Feb 16, 2013, 04:50 AM
Canada, ON, Sharon
Joined Feb 2008
just checked, 12 X 6 is my spare part, i assume that is also what is on it.
Seems pretty close to what you suggested
Old Feb 16, 2013, 08:26 AM
Kyler1 is offline
Find More Posts by Kyler1
United States, SD
Joined Aug 2010
No, a 12x6 and a 11x6 will make a pretty big difference!
Kyler1 is offline Find More Posts by Kyler1
Old Feb 16, 2013, 08:38 AM
jetmech05 is offline
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
Is this your first bipe? If so have someone that flies bipes stand out there with you on the first couple of flights....unlike a trainer you cant pull power off on the downwind leg and glide all the way to touchdown....instead with all the drag a bipe has your gonna have to keep a little power on and pull power off over the threshold
remember that elevator is speed control and throttle is altitude control.
I love my bipes but I'm done flying them for awhile...you're going to get a lot of comments from folks on your airplane. Good luck
jetmech05 is offline Find More Posts by jetmech05
Old Feb 16, 2013, 06:07 PM
Canada, ON, Sharon
Joined Feb 2008
Noted. As it is suggested to go to 11-6, I am on the lookout for it at the hobby shop asap. What would be the main difference on both ? Less "pull", slightly higher Rpm ? What different in flight characteristics ?
Anyway, no big rush, still nee to make a small tail repair that happened in transport, also need a wing pushrod (lost 1 in transport). I could start the engine break in though
Sold Great Planes "SPORTSTER BIPE 40" (nib) kit OriginalBilly Aircraft - Fuel - Airplanes (FS/W) 5 May 04, 2013 07:13 PM
Sold GP Sportster Bipe 40 (LPU) orbsah Aircraft - Fuel - Airplanes (FS/W) 1 Jan 26, 2013 08:08 PM
Help! PLEASE HELP Alpha 40 question mat3415 Fuel Plane Talk 8 Jan 25, 2013 10:45 PM
Question Thunder Tiger .40 glow to electric question bsfixit Glow to Electric Conversions 7 Jan 20, 2013 02:28 PM
