Old Feb 07, 2013, 12:28 AM
GeorgeG97322 is offline
Find More Posts by GeorgeG97322
Power Upward
GeorgeG97322's Avatar
United States, OR, Albany
Joined Jun 2007
Indoor Bostonian
Okay,
Who's got all the indoor bostonian plans and info?
George
GeorgeG97322 is offline Find More Posts by GeorgeG97322
Old Feb 07, 2013, 09:39 AM
DuPageJoe is offline
Find More Posts by DuPageJoe
USA, IL, Wheaton
Joined Oct 2010
How light do you want to build?
Basic question on indoor Bostonians concerns the weight. If you want to build to AMA minimum of 9 grams you need to find plans for Bostonian Patriot by Larry Coslick. It's a lightly built lifting body type. I've found a set, but don't recall where I got it. If you can stand losing some time, but want something more robust, there are lots of 14 gram planes around that can be flown indoors.
I've posted some stuff about Bostonians lately on this forum, as has YAK52 from the UK, but the planes weighed closer to 14 grams. I described one of my planes derived from Typond's "Beancraft Banana" in Model Builder on a thread here.
http://www.rcgroups.com/forums/showp...81&postcount=1
I also started a thread on airfoils for Bostonians that attracted a fair amount of technical info.
http://www.rcgroups.com/forums/showp...71&postcount=1
I fly with the Bong Eagles, who've always had fun indoors with Bostonians in their category II site. I started with a Peck Bostonian Pup some time back.
Have fun flying
Joe
DuPageJoe is offline Find More Posts by DuPageJoe
Old Feb 07, 2013, 11:27 AM
Power Upward
Joined Jun 2007
Thanks Joe,
I have been lurking on your airfoil thread. I have located plans for Don DeLoach's Bostonian Celtic, which I have begun building. I will be building to meet the 7 gram minimum weight. We'll see how it comes out...
George
Old Feb 07, 2013, 12:48 PM
USA, IL, Wheaton
Joined Oct 2010
Bostonian Patriot Plans
You're Welcome George
You might find that the Celtic will be hard to build that light. The plans indicate some tricks to lighten it.
I found the reference to the Bostonian Patriot plans by Coslick. They are in INAV # 87 1996.
You can get to them from the new INAV web site.
http://indoornewsandviews.wordpress.com/downloads
Click on INAV 1990ís
http://indoornewsandviews.files.word...90_inav_r2.pdf
Issue # 87 May 1996
pp 336-339 of 706
Scrolling to the exact pages is a little tough but the plans are there. I also passed by a "Blue Moon" light Bostonian in that giant file.
I added pictures of my Celtic. I've had better luck flying my more basic type.
Enjoy
Joe
Old Feb 07, 2013, 01:36 PM
Power Upward
Joined Jun 2007
Wow...
Thanks very much...
I've flown indoor for a while. Not that I'm good at it, I just don't build enough and fly enough to get more experience. Something I should do, however I haven't taken the time.
George
Old Feb 07, 2013, 04:14 PM
aeronca52 is offline
Find More Posts by aeronca52
Culper Junior
eastern pa
Joined Feb 2007
A bit more info....
http://www.hippocketaeronautics.com/...php?board=31.0
aeronca52 is offline Find More Posts by aeronca52
Old Feb 07, 2013, 06:20 PM
Yak 52 is offline
Find More Posts by Yak 52
Yak 52's Avatar
UK
Joined Jan 2009
Hi George, as Joe said I've been building (and drawing) to suit the 14g rules as that's what we compete with indoors. It's seen more as a beginner's competition so the 14g makes it buildable by most people.
There was a website run by Bernard Guest of CMAC with a lot of bostonian plans hosted but it has disappeared. I'm sure if you got hold of him via this page he'd be able to help.
There are a few in the Hippocket plan gallery too. The Boston Observer looks like a nice one to do as a 7 grammer if you lightened it a bit. My last one, the Beagle, came out at 11g but that was with a heavy prop and no special effort to build light. I'm sure you could get it close to 7g with decent indoor wood.
Jon
Yak 52 is offline Find More Posts by Yak 52
Old Feb 07, 2013, 09:10 PM
USA, IL, Wheaton
Joined Oct 2010
Couple more INAV Bostonians
That file on the INAV site with '90's issues I referenced above has a few more candidates for a good light Bostonian. The "Bean Machine" by Lindley has a conventional fuselage, but uses sliced ribs. It is at pp.48-49 of the '90's file in the April '92 edition (#56,57,58). The "Boston Scrod" by Dave Linstrum is a lifting body type. It is at p. 72 out of 706 of the '90's file in the Oct.'92 edition (#62,63,64).
Old Feb 07, 2013, 09:19 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
I seem to recall that the smaller Garami sport biplane is almost a Bostonian, though I won't guarantee it:
http://www.outerzone.co.uk/plan_details.asp?ID=856
Not sure what the 7 gram rules say about biplanes. You'd have to get rid of some of the sheet wood, I think, and shorten the top wing. Maybe widen the fuselage a tad.
Other than shrinking it, I don't think you'd have to massage Keith Laumer's famous Twin Lizzie very much to turn it into an attractive Bostonian:
http://www.outerzone.co.uk/plan_details.asp?ID=210
Maybe John Oldencamp's Silver Schtick design is simple enough to get down to 7 grams:
http://www.outerzone.co.uk/plan_details.asp?ID=3214
There are a few other Bostonians there, but not sure they're simple enough to get that light.
http://www.outerzone.co.uk/search/re...&Submit=Search
Apparently, it's possible to make a scalish Bostonian that only weighs 7 grams. At least, if your name is Jack McGillivary. I have the 1987 thru 1989 edition of Winning Indoor Designs. His winning Bostonian was patterned after the Pilatus PC-6 and the color scheme (!) is from the second airplane on this page:
http://www.pc-6.com/history/337.htm
The nose on the model is smaller and shorter, though. The airfoil isn't scale at all, very thin with concave lower surface. If that tickles your fancy, I could scan the page and send it to you.
If that's possible, I wonder if anyone could adapt Walt Mooney's attractive "Old Howard" bostonian to 7 grams.
http://www.hippocketaeronautics.com/...4c6e6f6dd6bd99
There are some other Bostonians in the Mooney collection on Hip Pocket:
http://www.hippocketaeronautics.com/...?image_id=1011
This one doesn't show up in a search on "Bostonian", so recommend you also search on "Boston":
http://www.hippocketaeronautics.com/...p?image_id=968
There is a Bostonian called the DeHalibut Bosty Moth which was in Model Builder. If you like it, I could send you the plan. I feel funny posting it on the site, because it isn't that old. See the picture attached to this message.
I've collected some others people have come up with:
-The Flohp, based on the Floh (!) biplane! (probably not good for high times or low weights!) The plan claims it's very close to scale except with a narrower chord.
-Gee Whiz based on the big fat Gee Bee
-Stagger Wink Not sure if this one is legal or just Bostonian sized, as the plans say.
-Mass General Based on General Aristocrat. Rather attractive. I think it is also on Hip Pocket or Outerzone, so check there first.
-Another one based on the turbo version of the Porter.
-Fat Cat based on Nesmith Cougar
lincoln is offline Find More Posts by lincoln
Old Feb 07, 2013, 11:15 PM
USA, IL, Wheaton
Joined Oct 2010
Of these, I think Oldenkamp's Silver Schtick ( Model Builder November 1992) might be the easiest to lighten, even though it was originally a 14 grammer. The Bosty Moth has even more wood. Both would be nice robust starter planes, easier to trim and keep from warping, than the "flounders" with their big lightly built tails.
Old Feb 09, 2013, 09:28 PM
Power Upward
Joined Jun 2007
Here's what I have so far... 1.8 grams total for what you see here...
George
Old Feb 09, 2013, 10:26 PM
USA, IL, Wheaton
Joined Oct 2010
George
Your Celtic fuselage is looking good. You may want to repeat the tail surfaces with just the diagonals and the center rib for the stab. These parts can move the CG a lot. The more wood in the tail, you need three times as much in the noseblock. The wing in the plans has probably too many ribs. Weight adds up fast in these things. The covering will add nearly 2 grams. Are you planning on a regular plastic 6 inch prop, or will you build one like the one in the plans?
Good luck
Joe
Old Feb 09, 2013, 11:22 PM
Power Upward
Joined Jun 2007
The stab and rudder ribs are 1/16x1/32 4 lbs stock. Not too much there. I'm more worried about the covering and which method I use to attach the covering with. I probabl;y should use condenser paper, but that has no character to it.
Anyone have any ideas???
George
Old Feb 11, 2013, 10:43 PM
lincoln is offline
Joined Dec 2001
For tissue, I find a good, fresh glue stick works well for indoor planes.
Seems to me that, using 4 lb wood, any of these designs might be made light enough! I have a 5 gram dime scale plane that has a 16 inch wing span, and includes wing struts, cylinders made from bond paper, and a couple of other things you wouldn't need in a Bostonian. I think I used 5 lb wood. I definitely used Esaki tissue. It's single covered and has a narrower wing, but still. BTW, I had to put on a big chunk of tail weight.
They say Gampi is significantly lighter than Esaki, but I don't know where to get it. Don't use "domestic" tissue, it's heavier. But if you can handle 4 lb wood, you probably already know that! Maybe if you finish the entire airframe, you'll find you can afford the weight of the Esaki. Whatever you use, weigh it first. At least if it's paper. Seems like not all batches are exactly the same. Good Esaki can be 10 grams per square meter.
Can you print (with a computer printer), use a marker, or spray paint condenser tissue? (Obviously for spraying you'd need to use a decent airbrush with decent paint instead of a spray can)
Some produce bags from the supermarket are very light, but I bet they're even harder to paint than condenser paper. And they need to be stuck down with contact cement. Shrinks ok with an iron if you get the temperature just right. I found the crinkly, slightly foggy type was best, but that was a while ago.
I wonder if you can get some kind of marking to stick to Ultrafilm. That stuff is REALLY light.
Old Feb 11, 2013, 11:31 PM
Power Upward
Joined Jun 2007
Lincoln,
I have some good esaki tissue, but not sure how I want to stick it down. In my old peanut days, we just used thinned down elmer's white glue.
I have tried glue stick thinned with water or was that alcohol. Anyway, I'm not big on that method. Are you suggesting that I apply glue stick to the frame then apply the tissue?
George
Help! Gee Whiz Bostonian Racer By B Matthews kevin matthews Free Flight 4 Apr 26, 2007 11:19 PM
Rant Boston Bomb Scare thing..... Hoax or just... really dumb Bostonians? Accu157 Life, The Universe, and Politics 21 Feb 02, 2007 07:01 AM
Discussion Peck Bostonian Pup Conversion Letcraft Scratchbuilt Indoor and Micro Models 20 Jun 14, 2006 08:25 AM
Enlarged Bostonian (Pup/Prairie Bird) for S400 houdini Parkflyers 1 Dec 05, 2002 01:09 PM
