Portland oregon
Joined Jan 2006
Then "washout" is still my best friend. I think. ......(I read your post four times)
FYI...However I made a discovery on this ARF. It seems that the left wings are built by one employee while the right by another. Resulting with a nice radius on one wing and a fairly blunt ( flat ) leading edge on the other. Sort of "built in disaster". I have always loved the building part of the hobby, but as kits become more rare and arfs cheaper, well you get the idea. I have always checked for incidence and washout but never paid much attention to the leading edge. This may be why I found so many posts warning of tip stall on this particular ARF. Just a note for ARF buyers to watch out for. |
From flying models built by student modelers that had bluntish and somewhat squared off leading edge I found that it really does mess up how a wing performs. If you're able to easily see the difference such as you indicate then be prepared for the worst. It will be especially bad with one wing looking like it has a proper leading edge and the other is poorly done.
I'd suggest that it would be time well spent to carefully slit and peel away the covering on the roughly done side and shape it to match the other then patch the covering. Or if you are careful perhaps you can slit it along the bottom behind the leading edge, fold it back and tape it out of the way and then fold it around and down and re-seal it. You may need to buy some Balsarite to allow doing this. |
Here's a graphic representation I just came across of potential stall speed relative to bank angle. It's for a full size aircraft but gets the idea across that when banked the aircraft's stall speed is potentially higher.
So flying slowly and then doing a banked turn the aircraft's speed should really be increased to reduce the risk of a stall. Probably one of the major factors for the 'dreaded down wind turn, fall out the sky' problems that some flyer seem to have. They slow too much on the down wind leg, (visually relating the models ground speed, not air speed), then turn and .......woops!. http://en.wikipedia.org/wiki/File:Accelerated_stall.gif |
Lansing, MI
Joined May 2002
At slow speeds keep the bank angle shallow
http://bellsouthpwp2.net/p/u/puddlz/images/18.gif |
I agree with you. That phrase, "downwind turn" got my attention. Most fliers/posters say there is no such thing as a spin due to the down wind turn. They say the plane does not know the wind is blowing....ha ,ha. They ignore the KineticEnergy factor. Also they ignore that wing loading is also a factor. This true of conventional as well a a Delta wing aircraft. Just last month I saw a new twin-engined scale ship drop that wing and auger in on turning on final. Pilot error contributed. Turning too tightly at too slow a speed. I also use a little neg. wingtip warp on planes weighing less than 5 pounds.
Portland oregon
Joined Jan 2006
Brandano
I see your point about the flaps. But while the covering was off the wing it was easy to warp in some washout and then fine tune it with heat after covering, so I do have abut 2 degrees in the tips. The photo shows "full" flaps(about 40 deg). Half flaps is about 25. I am using a Spectrum DX7S that allows two settings and a reduced servo speed. I will try some slow approach patterns at a higher altitude and see if all works out |
| Thread Tools | |
| Discussion washout at wing tips to avoid stall | phil alvirez | Scale Sailplanes | 36 | May 12, 2012 04:12 AM |
| Question Washout at tips = extra reflex at root? | wingnutt | Flying Wings | 4 | Sep 11, 2009 09:06 AM |
| can an esc, or other gadget limit amp draw on lithiums? | asjeep | Power Systems | 5 | May 14, 2004 02:17 PM |
| Foils, washout and tip stall - or Plouf, which foil? | Mafu | Slope | 13 | Nov 10, 2003 08:12 AM |
| Washout and stall strips | Sparky Paul | Modeling Science | 8 | Jun 06, 2003 04:57 AM |
