Old Feb 06, 2013, 07:12 PM
Oldog is offline
Find More Posts by Oldog
Portland oregon
Joined Jan 2006
washout, root stall and other gadgets
I favor a bit of wing tip wash out on my models to avoid those nasty
tip stalls when turning slow for landings. Or just gentle stalls.
I just assembled a ARF AT-6 and tried to warp the wings a litte with heat and overnite jigs but the thing just keeps coming back ... so....
I recall that several full scale airplanes I have seen over the years like the Globe Swift, used a small turbulance causing device riveted to the leading edge of the wing near the root. This would cause the root to stall ahead of the rest of the wing giving the pilot a nice warning before a wing might drop.
My question is , how might I arrive at a size and location to install such a device?
I am sure it will be trial and error but I need a starting point. All comments welcome.
Oldog is offline Find More Posts by Oldog
Old Feb 06, 2013, 08:41 PM
kcaldwel is offline
Find More Posts by kcaldwel
The post-truth world
kcaldwel's Avatar
Joined Jan 2007
I think you are looking for root stall strips. They are basically just a small 90 degree triagle added to the leading edge of the root airfoil.
From this paper, it looks like having the point of the triangle right on the chord line is probably close to optimum, or perhaps just slightly above (upper most position shown). The triangle should be about 1.2% of the wing chord on each side of the triangle.
"CFD Study of a NACA 63-415 Aerofoil
Fitted with Stall Strips"
http://130.226.56.153/rispubl/VEA/veapdf/ris-r-1370.pdf
(right click and save as...)
Note that the stall strips work by reducing the max lift coefficient of the airfoil. This means you don't want to make them too long, or the stall speed of the airplane will increase substantially.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Feb 07, 2013, 12:22 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Some big planes have them also.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Feb 07, 2013, 04:40 AM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
How about raising the ailerons slightly for a little reflex, that could give a similar affect to washout.
But, the real answer is don't slow it down too much. A model prone to dropping a wing tip, (tip stall), often in that dreaded 'down wind turn', just need to be flown faster and further out on the down wind turn. Once lined up and flying straight with the runway, then start to slow down, (flaps etc ? ).
The higher the wind speed, the easier it is to start relating ground speed to the model, and slow down too much on the down wind leg.
eflightray is online now Find More Posts by eflightray
Old Feb 07, 2013, 04:42 AM
Brandano is online now
Find More Posts by Brandano
That taxiing dolly on the Dragon Lady had me confused for a bit.
Brandano is online now Find More Posts by Brandano
Old Feb 07, 2013, 11:09 AM
Ascended Master
Palmdale, CA
Joined Oct 2000
That's the ground handling dolly.. they're towed backwards...
Old Feb 07, 2013, 01:31 PM
Yes. For a bit I thought that it was a main landing gear, but I know that the U2 doesn't have that gear configuration. so I thought it could have been this one instead:
but the wing is mounted differently, the intakes are bigger, and it has two fins and a high tail, so it didn't fit anyway. I know the U2 has outrigger pods it drops once airborne, but I don't think it can use those to actually taxi to the head of the runway, so I assumed they fitted some sort of taxing dolly and that was what I was seeing in the picture. I presume it is towed to the starting position instead, which makes sense since taxiing would be a waste of fuel. Actually, I wonder if they ever thought about aerotowing it to altitude to extend the mission range.
Old Feb 07, 2013, 01:35 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Some U-2 pilots eschew ground handling to position themselves on the runway for takeoff, and will taxi out... and after the pogos are reinstalled after landing, taxi back.
NASA has been flying an ER-2 out of here every day this week. Noisy thing!
Old Feb 07, 2013, 09:50 PM
Oldog is offline
Portland oregon
Joined Jan 2006
Thanks to All of you for the replies.
I am now convinced that the best approach is ..... find a way to warp that wing and get the
washout I really want.
Wish me luck and listen for cracking sounds.
Old Feb 07, 2013, 10:07 PM
ChrisS is offline
Find More Posts by ChrisS
Really?!?
ChrisS's Avatar
Lost ...on the 3rd rock out
Joined Sep 2001
How about some simple turbulator strips further out on the wing? A piece of tape cut in a zig-zag and adhered just in front of the high point of the wing for the last 1/3 of the wing span may work wonders.
Just a thought
Chris
ChrisS is offline Find More Posts by ChrisS
Old Feb 07, 2013, 10:25 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
1960 I was flying a PAA Load 1/2A free flight at the Dallas Nats... I'd test flown it several times back home in VA.
On its first circle over the runway at Dallas after takeoff, the warp I'd doped out of the wing came back... Short flight...
I have warmed some MonoKote wings on both sides and held them just past the unwarped position until the wing cooled.
Old Feb 08, 2013, 03:01 PM
Oldog is offline
Portland oregon
Joined Jan 2006
Just a thought
Chris
Expand on that a litle, How does that work?
Old Feb 08, 2013, 04:03 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Any rough edge that generates some skin turbulence downstream from the trip point is called a turbulator or invigorator or any of the other buzz words you've read about.
The tape method is a pretty common method of making a turbulator for a model. In fact there's really no need to make it a zig zag shape either. BUT.... it does need to be tall enough to produce the desired effect. The times I've done a tape turbulator I've used a double or triple layer of 1/8 wide automotive pinstriping tape. It needed the two layers in one case and three on the other to be thick enough to produce the turbulation and perk up the low speed flying. I can't say if it aided in delaying the stall or not as I was more concerned about draggy low speed performance and a glide slope that looked like a duck with a belly of birdshot. In both cases adding the turbulator strips perked things up and made these two sailplanes into great low speed performers.
There's another way to make the center stall first. A stall strip or shaping the leading edge so the inner area has a sharp small radius shape and the tips set up with a relatively generous radius will work to some extent similarly to washout in the tips.
Keep in mind too that you're also ASSUMING that the model will encounter trouble. You haven't even flown it yet. It may be just fine.
BMatthews is online now Find More Posts by BMatthews
Old Feb 08, 2013, 07:11 PM
Oldog is offline
Portland oregon
Joined Jan 2006
Correct, I have not flown it yet. It is a world models AT-6 44 inspan ep.
I have read several reports and they all say its its a fun to fly model but has a habit of tip stalling in slow turns.
I had a larger model of the same plane World models puts out with a 91 four stroke on it.
I suspect it was the same but only larger design.
I lost that one in a low turning tip stall turning finel. That is why I am so suspect of this bird.
Most of my flying fun come from shooting landings.
So..... like they say "an ounce of prevention....
I like the tape idea. Thanks all
Old Feb 08, 2013, 07:35 PM
ChrisS is offline
Really?!?
ChrisS's Avatar
Joined Sep 2001
Nearly any tapered wing will do that. The lesson is to keep the speed up a bit...especially on downwind turns. Learning to use rudder for downwind turns will help too.
Chris
Discussion washout at wing tips to avoid stall phil alvirez Scale Sailplanes 36 May 12, 2012 04:12 AM
Question Washout at tips = extra reflex at root? wingnutt Flying Wings 4 Sep 11, 2009 09:06 AM
can an esc, or other gadget limit amp draw on lithiums? asjeep Power Systems 5 May 14, 2004 02:17 PM
Foils, washout and tip stall - or Plouf, which foil? Mafu Slope 13 Nov 10, 2003 08:12 AM
Washout and stall strips Sparky Paul Modeling Science 8 Jun 06, 2003 04:57 AM
