Old Feb 06, 2013, 03:36 PM
gavoss is offline
Find More Posts by gavoss
gavoss's Avatar
USA, OK, Oklahoma City
Joined Mar 2001
Servo Wiring question
I'm setting up a 5M plane that will use a separate battery for the servos and the RX. While setting things up and trying them out, I have the following:
RX powered up with a 2400mah battery
Servos powered up with a 5000mah battery
I have a plug into channel 1 of an old RC Direct 72mHz rx that I can check each wire harness and individual servo. (I also tried a Hitec SS and it didn't change the results)
Now, when I attach the signal wire of any servo to plug I get nothing.
If I hook the servo power wires up to the plug the servo functions.
What gives?
All help is appreciated.
gavoss is offline Find More Posts by gavoss
Old Feb 06, 2013, 05:15 PM
Bearded Flyer is offline
Find More Posts by Bearded Flyer
United Kingdom, England, Manchester
Joined Apr 2005
Can you post a diagram that makes it easier to visualise?
The servo will need positive and negative from the 5000mah battery (via a 5v BEC). It also needs its signal wire and negative connected to the Rx. It would make good practice to connect the negative from each battery together as well forming a common ground
Richard
Bearded Flyer is offline Find More Posts by Bearded Flyer
Old Feb 06, 2013, 09:45 PM
gavoss is offline
gavoss's Avatar
Joined Mar 2001
That's what I found out. I had to connect a wire from the 5000mah battery to the negative on the plug, thus creating a common ground. I'll draw a picture up and maybe someone else can be helped.
Old Feb 07, 2013, 02:57 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
That's exactly what you'd expect. You can't use a signal connection without anything to reference it to. One wire signal connections have never really worked that well .
Steve
slipstick is offline Find More Posts by slipstick
Old Feb 07, 2013, 08:10 AM
dmccormick001 is offline
Find More Posts by dmccormick001
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
If you look at the circuit board of any R/C receiver, you'll see that the (+) and (-) connections for every servo plug, including the one where the battery plugs in, are all common. Sometimes they are called "rails", and all they do is distribute power to all the plugs uniformly. The receiver is able to control each servo individually via the signal wire, and the signal wire's reference voltage in relation to ground (-). So at the very least, you need the signal and (-) wires from the receiver going to each servo, the (+) and (-) from the second battery going to the servos, and both (-) connected together.
But the big question I have is "Why?" The receiver draws very little current itself, most of your battery usage is because of the servos, it seems kinda "overkill" to employ a separate battery for Rx and servos. I'd recommend just using the bigger battery to power both, the extra current used by the Rx will almost certainly be so little that you'll never be able to tell any difference, and not carrying the extra weight of the 2400mAh battery should improve performance.
dmccormick001 is offline Find More Posts by dmccormick001
Old Feb 07, 2013, 08:33 AM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
If 5m is the span, the plane is rather large (15ft) - the servos might see some pretty heavy loads and drag voltage down enough to cause brownout. If the rx has its own power supply that is independent of any servo activity, probability of brownout could be less. Whether separate rx/servo power supplies are really necessary, I can't prove one way or another, but I do understand the logic behind this. Ymmv.
Oh, btw, while it is true that all grounds need to be tied together, there shouldn't be any closed loops in ground wiring (just a remainder, I know you all knew that).
jkettu is offline Find More Posts by jkettu
Old Feb 07, 2013, 09:56 AM
gavoss is offline
gavoss's Avatar
Joined Mar 2001
It's a customers plane and he wants 5 cells for the servos and 4 for the rx. Also, the power wires are much larger than the signal wire, 20g vs 26.
Old Feb 07, 2013, 12:32 PM
gavoss is offline
gavoss's Avatar
Joined Mar 2001
Photos attached.
Old Feb 07, 2013, 03:08 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Your diagram with common ground is correct.
When I use separate power sources -- e.g. for retracts or swing-wings -- I achieve the same thing a different way: I splice in another black wire to the existing black wire on the servo that's going to get the external power supply, then one black wire and the white go to the receiver for the signal, and the other black wire and the red go to the separate power source. Makes it simple for me to follow, and a servo plug with two pins in it is less likely to fall out of the receiver socket than one with only one pin
If you don't wan't to mess with the servo wires themselves, you can make a separate harness that splits the wires the same way.
abenn is offline Find More Posts by abenn
Discussion Wiring question gavoss Slope 4 Feb 06, 2013 09:42 PM
Wanted Servos for a Mini Vec & Wiring harness scones007 Aircraft - General - Radio Equipment (FS/W) 0 Jan 26, 2013 02:14 PM
Discussion Novice wiring questions In-Flight Multirotor Talk 12 Jan 14, 2013 05:25 PM
RE: servo wiring question RCDad Radios 2 Jun 28, 2004 10:28 PM
