Feb 06, 2013, 02:47 PM
USA, OK, Oklahoma City
Joined Mar 2001
Wiring question
If this isn't the best place for this, let me know, but I figured some of you who have expensive scale slopers know the answer.
I'm setting up a 5M plane that will use a separate battery for the servos and the RX. While setting things up and trying them out, I have the following:
RX powered up with a 2400mah battery
Servos powered up with a 5000mah battery
I have a plug in channel 1 of an old RC Direct 72mHz rx that I can check each wire harness and individual servo. (I also tried a Hitec SS and it didn't change anything)
Now, when I attach the signal wire of any servo to plug I get nothing.
If I hook the servo power wires up to the plug the servo functions.
What gives?
All help is appreciated.
