Old Feb 06, 2013, 01:50 PM
madaboutjets is offline
Find More Posts by madaboutjets
Joined Apr 2009
Video
A319 scale flaps and spoilers
hi all
thought id post some videos of the work so far on my A319 jet
id welcome your thoughts
madaboutjets is offline Find More Posts by madaboutjets
Old Feb 06, 2013, 02:15 PM
Hollywood2979 is offline
Find More Posts by Hollywood2979
Hollywood2979's Avatar
United States, TX, Cibolo
Joined Nov 2011
Pretty crazy cool looking, love the hinging out and down, then the up and in, what is the wingspan going to be, it looks like it may be heavy.
Hollywood2979 is offline Find More Posts by Hollywood2979
Old Feb 06, 2013, 02:18 PM
Joined Apr 2009
wingspan is 2.5m and yes its not light i have not weighed it yet i dont think i want too!
Old Feb 06, 2013, 02:20 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Looks simply amazing Sir! I would weigh it, that way you'll know what kind of power you will need to get her airborne & also determine how long her takeoff run will be.
demondriver is offline Find More Posts by demondriver
Latest blog entry: Joe Nall 2016
Old Feb 06, 2013, 02:49 PM
Joined Apr 2009
cheers demon!
yes i will weigh it once the other wing is complete along with the landing gear its my first scale project so a lot of things are still in experimentation!
Old Feb 06, 2013, 04:38 PM
Rookie2008 is offline
Find More Posts by Rookie2008
Rookie2008's Avatar
Southern California
Joined Mar 2010
Nice work.
Rookie2008 is offline Find More Posts by Rookie2008
Old Feb 06, 2013, 04:49 PM
redodedo is online now
Find More Posts by redodedo
HD FPV on a 4m glider
Canada, BC, Richmond
Joined Dec 2012
thats amazing
redodedo is online now Find More Posts by redodedo
Old Feb 06, 2013, 05:38 PM
fly2bob is offline
Find More Posts by fly2bob
fly2bob's Avatar
United States, CA, San Diego
Joined Nov 2005
VERY cool, but you already knew that. Question; are you going to combine use of the flaps and spoilers w/ the ailerons for roll authority? I'm thinking you might need to in order to control an expected heavy model. Although I'm not sure how you would do that. I believe that real airliners do this but for example the spoilers move at a much smaller amount than the aileron defection so not to create too much drag during roll. One idea to reduce some weight is to connect the four outer spoilers together using .10 mil mylar on the back side of them so you can reduce the number of servos per wing half by three.
fly2bob is offline Find More Posts by fly2bob
Old Feb 06, 2013, 09:18 PM
jmpdgs is offline
Find More Posts by jmpdgs
A Global Force For Good
jmpdgs's Avatar
USA, OH, Cincinnati
Joined Jun 2009
Impressive fabrication. Now I need to figure out a way to do that in foam at half the size and a quarter of the weight.
Thanks for sharing that, I'm inspired.
Cheers
Joe
jmpdgs is offline Find More Posts by jmpdgs
Old Feb 06, 2013, 10:28 PM
joegermano1 is offline
Find More Posts by joegermano1
casinojoe1203
United States, PA, Boalsburg
Joined Mar 2012
Great Job man, Looks unbeleivable
joegermano1 is offline Find More Posts by joegermano1
Old Feb 06, 2013, 11:10 PM
badpilotto is offline
Find More Posts by badpilotto
BadPilot
badpilotto's Avatar
United States, IL, Custer Park
Joined Nov 2007
WOW very impressive!!!! It really doesn't look too heavy too me, two 40hp motors should work (JK). Very nice design, to lighten it, if it is really too heavy, could you make the hinging out of plastic or CF?
John
badpilotto is offline Find More Posts by badpilotto
Old Feb 07, 2013, 02:11 AM
Joined Apr 2009
On the full size aircraft roll is controlled with the outer 4 spoilers how much I'm not sure yet but max deflection for the spoilers is 35degrees according to the manual obviously that would be way too much as it would just kill the lift that's only used on the ground when the inner flap is also actuated
Yes I'm tempted to bind the four spoilers together to save on weight and complexity !
Also on the full size the ailerons droop 5degrees when full flap is deployed this shouldn't be a problem if I can get the right gear
Old Feb 07, 2013, 02:14 AM
Joined Apr 2009
Using plastic for the mechanism would have been possible except for the main linkage which is bent to fit on the end of the flap bracket
Old Feb 07, 2013, 04:13 AM
fly2bob is offline
fly2bob's Avatar
Joined Nov 2005
Now that I think about it more, it should be possible to link the outer four spoilers (o4s) to the ailerons and have them deflect at a lesser amount than the ailerons. You said the roll is controlled by the o4s, but I would think that so do the ailerons. Anyway, if you connect the o4s together, use one servo for them, y-harness them and put them in a rx ch, then do a prog mix and slave the o4s to the ailerons and 30% or so for up and zero for down. What do you think?
Old Feb 07, 2013, 04:56 AM
Joined Apr 2009
Yes your right forgot to mention ailerons for roll of course!
That's a good idea not sure if connecting the spoilers and aileron with a y harness would work as I'm planning on using the spoilers for ground brakes as full size
Build Log Depron A319 1:22 scale project SergioFMMI RC Airliners (Commercial, Cargo, Troop Carrier) 231 Jan 30, 2015 08:25 PM
Sold REDUCED - 40N Giant Scale 6s w/flaps, lights & retracts 1700mm EPO - $SOLD shipped ross_badger Aircraft - Electric - Airplanes (FS/W) 9 Jan 14, 2013 11:18 AM
Sold P-40N Giant Scale 6s w/flaps, lights & retracts 1700mm EPO (PNF) ross_badger Aircraft - Electric - Airplanes (FS/W) 5 Jan 11, 2013 11:20 AM
Build Log Airbus A319 | 1:20 Scale | EDF | Dollar Tree Foam preelude RC Airliners (Commercial, Cargo, Troop Carrier) 23 Dec 22, 2012 02:36 PM
Discussion scale A319 need help madaboutjets Electric Ducted Fan Jet Talk 5 Mar 09, 2011 07:08 PM
