Old Feb 06, 2013, 09:49 AM
bulesz is offline
Find More Posts by bulesz
bulesz's Avatar
Hungary EU
Joined May 2007
New Product
HK Q-BOT Micro 6 axis BNF - Spektrum, 9X, Walkera, Futaba comp. (read the first post)
Hey Guys,
Just started a thread for this promising micro quad, the first 6 axis (gyro + accelerometer) which supports 9X.
Description from HK:
The Q-BOT Micro is the first micro quadcopter on the market today that includes a 2.4gHz RF module allowing it to be used with your own transmitter. This means it can be flown with Spektrum, JR, Futaba, Hitec, Turnigy, Walkera and other transmitters*. The transmitter will simply need to have a trainer port (JR style 3.5mm or Futaba style 6-pin) and be capable of outputting PPM signal.
This micro quad features leading edge technology including a highly precise 6-axis gyro stabilization system making it ultra stable. Normally, building and setting up of multi-rotor aircraft requires lots of time, tuning and having to choose your own power system/components. The Q-BOT Micro takes away all of the complicated setup and makes it as easy as opening the box, charging the batteries, connecting the RF module to your own transmitter and flying!
The included 2.4gHz RF module can be powered several different ways. It has its own rechargeable 3.7V lipoly battery pre-installed but can also be powered directly from the transmitter via the transmitter's charging jack (DC power plug included), or by the Futaba style 6-pin trainer port.
The Q-BOT Micro is very capable with plenty of power to spare. In normal mode, its stable flight characteristics make it stress-free for the less experienced quad pilot. Switch it to aerobatic mode (via your transmitter's GEAR channel) and it's very responsive for those looking to push it to the limits. When in aerobatic mode, the responsiveness is greatly increased which allows for flips, rolls and loops to be performed!
Features:
2.4gHz RF module allowing for use with your own transmitter*
Ultra stable flight characteristics
Aerobatic flight mode allowing for flips, rolls and loops
Compact and lightweight design
Quadcopter Specs:
Width: 125mm
Height: 35mm
Weight: 26g (w/out battery)
RF Module Specs:
Battery Specification: 3.7V Li-Po battery 120mAh
Operating Voltage: 3.7~12V DC
Operating Current: ≤ 100 mA
Operating Frequency: 2.4gHz
Spread Spectrum Mode: FHSS
Number of Frequency Channels: 20
Hopping Rate: 240 Jump/s
Included in box:
Q-BOT Micro Quadcopter
2.4gHz RF module
3.7V 20C 250mAh lipoly battery x 2
USB dual battery charger
Spare propellers (2 x black, 2 x orange)
Screwdriver
Required:
Your own 4CH (5CH or more required for aerobatic mode) transmitter with trainer port (JR style 3.5mm or Futaba style 6-pin)
Price: USD 34.99 (44.99 shipped to EU)
HK url: http://www.hobbyking.com/hobbyking/s...dProduct=29595
Any experiences, questions are welcome!
Parts:
From Throttlestore for the "twin" HiSky FF120:
http://www.throttlestore.com/search.aspx?q=ff120
Troubleshoot:
Problem:
After binding, the quad hits the ceiling, the throttle seems to be working as ON/OFF cant control....
Solution:
Set the MODELVAT to PPM and bind with trims zero + throttle down
Problem:
When plug the TX module to the Radio, both LEDs are solid red, and doesn't bind, can't switch between modes...
Solution:
Before plug in the TX module, unplug the existing TX module...
Review:
by ruzam: http://www.rcgroups.com/forums/showp...&postcount=912
Tips:
By maexx
1. For 9X radio: mode LED shall be green (Futaba channel order on stock firmware (NO light/blank LED))
2. For 9X radio: It is much easier to make module connector than try to use trainer port and some external power source (I have HiSky module w/out battery).
Binding with DX6i by Swilson50:
1. Set up a NEW airplane in your transmitter. Be sure to reset everything to default. Then, set 1,2,3,5 REVERSE. Leave only 4 normal
2. DO NOT set throttle trim to the lowest position. Leave it ad mid-point...read about my flywawy Qbot to know why.
3. Plug in both cables from the black box to your transmitter.
4. Within 10 seconds, plug in a charged battery to the Qbot.
5. Quickly,Put your thumb on top of the Qbot....flyaways Qbots are not fun.
The lights should flash and the motors should do a little dance, and then the solid green light should come on your qbot.
MOST IMPORTANT..BEFORE you move the throttle stick, leave your thumb on top of the Qbot and slowly move the throttle stick. Observe that off is at the lowest point and full up is full up. Hold the Qbot in one hand and verify that all controls are in the proper direction.
Direct link with servo cable by limmacslim:
http://www.rcgroups.com/forums/showp...&postcount=224
When you power the TX from the radio remove the TX battery!!!
Very important! When you direct link the TX with servo cable keep the LiPo inside AND keep the TX always OFF to avoid the lags!!! The radio will turn the TX module on when you turn on your radio so you don't have to turn the TX module ON with the switch on it!!!
Straw motor saver mod to help prevent damage to the motors when they are accidentally used as landing gear by MassiveOverKll:
http://www.rcgroups.com/forums/showp...3&postcount=49
Review and tips from jesolins:
http://www.rcgroups.com/forums/showp...&postcount=315
bulesz is offline Find More Posts by bulesz
Old Feb 06, 2013, 09:54 AM
bangkomit is offline
Find More Posts by bangkomit
Hubsan X4 - H36 - V911
bangkomit's Avatar
Indonesia, Jakarta
Joined Oct 2012
we need buddy code. please post here once you buy it
bangkomit is offline Find More Posts by bangkomit
Old Feb 06, 2013, 09:56 AM
bulesz is offline
bulesz's Avatar
Hungary EU
Joined May 2007
Guys, does the RX board look familiar to anyone? I have checked the HeliMax 1SQ and it looks different...
Old Feb 06, 2013, 09:58 AM
bulesz is offline
bulesz's Avatar
Hungary EU
Joined May 2007
I know, I would share it if it would be one, but I have only a "7 Day Lowest Price Rebate!" icon there..
Old Feb 06, 2013, 10:51 AM
bulesz is offline
bulesz's Avatar
Hungary EU
Joined May 2007
Originally Posted by Daryoon View Post
The bigger Hobby King QBot looks to be a v929 rebrand. I wonder if this holds true for this smaller version as well? If so, what other aircraft does that module bind with?
Does the module remind you guys of any other brand that has a similar module? Walkera? hiSky?
The module itself is like the AnyLink module, but the RX board is not familiar to me...
Old Feb 06, 2013, 11:02 AM
muck76 is offline
Find More Posts by muck76
muck76's Avatar
Joined Mar 2006
hmmm
muck76 is offline Find More Posts by muck76
Old Feb 06, 2013, 11:22 AM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
The curiosity of what protocol that module binds to may be enough to get me. Also the promise of loops and rolls as well.
I don't own a quad in this size range yet.
Daryoon is online now Find More Posts by Daryoon
Old Feb 06, 2013, 11:50 AM
bulesz is offline
bulesz's Avatar
Hungary EU
Joined May 2007
Due I was disappointment with the H36 and the V939 Frankenquad (the V939 frame was crappy) I need a microquad with good flying characteristics (gyro+accelerometer), so I gave a shot for this lil QBOT.
I'm very curious about it, so when it will be arrived my Legofriends and me will examine it deeeeeeply...
I will be curious about the RX board and the TX module as well, because it might be a kind of MagicCube+AnyLink combo...
Originally Posted by zippiz View Post
Yeah, it does... and the manual page 10 conflicts to this... right?
http://www.hobbyking.com/hobbyking/s...19X53414X0.pdf
Regarding to the manual, it flips if you set the endpoints to 100%+...
Old Feb 06, 2013, 01:48 PM
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
The module looks like a HiSky unit to me. Plus, we know that HobbyKing already has a working relationship in that they rebranded the HiSky FBL100 as the Turnigy FBL100.
And here it is more evidence:
Existing thread:
http://www.rcgroups.com/forums/showthread.php?t=1750198
Old Feb 06, 2013, 02:12 PM
blackmoon is offline
Find More Posts by blackmoon
flying beam
blackmoon's Avatar
through the Looking Glass
Joined Apr 2008
yup Hisky quad with the new V3 module.
http://www.hobbyeurope.com/rc/helico...copter-2-4-ghz
Same price shipped but V2 module.
blackmoon is offline Find More Posts by blackmoon
Old Feb 06, 2013, 02:19 PM
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
I was wondering which version of the module that is. I know it's at least a version 2 because it uses a battery. (HobbyKing say it's a rechargeable battery)
If a v3, then that's the first place that I have seen the v3 module available.
Now, if only Banggood would finish listing the v922 BNF. Aaron mention that's what he's working on.
Old Feb 06, 2013, 02:37 PM
bulesz is offline
bulesz's Avatar
Hungary EU
Joined May 2007
hm, nice catch guys! the HK is about 15% cheaper than the HiSky version....(shipped 44USD vs shipped 51USD). The keyfactor is the multi compatibility and the gyro + accelerometer combo for me...
Old Feb 06, 2013, 03:08 PM
flying beam
blackmoon's Avatar
Joined Apr 2008
mmm I don't think the V2 has the battery included but only the V3.
If I remember correctly a post from one of the guys at hobbyeurope.
Edit:
Found it : http://www.rcgroups.com/forums/showp...&postcount=385
Old Feb 06, 2013, 03:23 PM
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
No flight report from the other thread. So it's pretty much dead and useless.
Sounds like there's more interest now that HK made that HiSky quad available.
So, I am not clear if this is the HT8 v3 module? I remember reading that the V2 had the battery? But I could be mistaken.
Old Feb 06, 2013, 03:37 PM
neobot is offline
Find More Posts by neobot
Joined Jun 2012
Heres a couple of vids
http://v.youku.com/v_show/id_XNDU3MzAyMjgw.html
http://v.youku.com/v_show/id_XNDgyMDcwMzM2.html
and hobbyking staff flying one
HobbyKing Product Video - Q BOT Micro (1 min 36 sec)
lol last link worked fine maybe hobbyking think they are smart?
neobot is offline Find More Posts by neobot
Reply With Quote  (Disabled)
New Product BNF Spectrum/JR DSM2-DMSS compatible REDCON HiBiRD Mini 120mm Quadcopter richos Mini Multirotors 37 Oct 25, 2014 05:20 AM
Sold $60 Shipped -- FlySky CT-6B Tx and Six 6-Channel Rx's (Compatible with 9X) Cobra68 Aircraft - General - Radio Equipment (FS/W) 2 Feb 09, 2013 11:00 AM
Sold Hobby King 2.4 ghz Spektrum compatible Receiver = $18 shipped shawn595 Aircraft - General - Radio Equipment (FS/W) 3 Aug 07, 2010 02:35 PM
