Old Feb 06, 2013, 07:17 AM
Chuchuf is offline
Find More Posts by Chuchuf
Carboweave, Ask For It By Name
Chuchuf's Avatar
United States, GA, Atlanta
Joined Aug 2009
140-150 MPH for less than $150
Guy's and Gals,
I've got to tell you about our latest fun with making things go fast that look good and is inexpensive. If there is already a thread on this here I couldn't find it so here goes.
* HK Funfighter RareBear unfinished $51.78 http://hobbyking.com/hobbyking/store...ith_Motor.html
* NTN Prop Drive 28-36 2700KV $16.99 http://hobbyking.com/hobbyking/store...00KV_595W.html
* HD 2216 servos for the wings (run what you like I had these on hand) $17.88 each $35.76 http://hobbyking.com/hobbyking/store...1kg_16sec.html
* MG-14 servo for elevator (run what you like I had these on hand) $7.69 http://hobbyking.com/hobbyking/store...aft_servo.html
* Turnigy Trust 55A ESC with SBEC (or your choice) $21.55 http://hobbyking.com/hobbyking/store...ontroller.html
* 4S Nano 1000mA 45-90C $13.20 http://hobbyking.com/hobbyking/store...Lipo_Pack.html
* Receiver of your choice
Total ~$150.00
The modifications I did for my SpeedBear
* added some carbon fiber to the horizontal stabs
* Moved motor mount back 10mm so the motor would fit in the cowl
* Changed the clevis's to stronger ones.
* Supported the elevator push rod so it wouldn't flex in flight
* Used Welder Glue to build (strong stuff!!) and then used Hysold on all the horns to keep them in place
The amazing thing about this plane is not only is it fast, but it tracks and flys really good at speed and slows way down for landing. I'm running an APC 4.75 x 4.75 but we have tested up to a 5 x 5.5 without issue. I've ordered some more APC props up to 6.25 pitch that we will be shaping and trying in a week or so. Turns about 33K RPM now
Terry
Chuchuf is offline Find More Posts by Chuchuf
Old Feb 06, 2013, 10:59 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Very nice pocket racer!
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Feb 06, 2013, 01:01 PM
Quadmad is offline
Find More Posts by Quadmad
Joined Jul 2012
Been around a long time now, bone stock would do 120mph+ out of the box on 4s
with a bit of carving a 1300mAh 45-90c 6s will fit no problem
here is a 6s one with Turnigy 2826 2200kv motor and upgraded esc
J Power Mini Rare Bear on 6S (0 min 54 sec)
Mine been sitting in my garage for the last year gathering dust might be time to get carving
Quadmad is offline Find More Posts by Quadmad
Reply With Quote  (Disabled)
Old Feb 06, 2013, 02:39 PM
Jwmflying14 is offline
Find More Posts by Jwmflying14
United States, CA, Lompoc
Joined Nov 2010
hmm i'd like to get a doppler! Fly closer and lower, lets see what this can really do!
Jwmflying14 is offline Find More Posts by Jwmflying14
Old Feb 06, 2013, 03:58 PM
volsanslimit is offline
Find More Posts by volsanslimit
fun 'n fly
volsanslimit's Avatar
Switzerland
Joined Oct 2012
Hello
That's a quiet interesting setup for small racers.
One setup that fits good too is a Turnigy 2836 Brushless EDF Motor 3200kv with an 4.1*4.1 turnigy prop on a 4S 1800mah Battery.
I measured a Speedy racer at 240km/h (150mph) and it draws only 54amps.
I hope, a video will come soon of this little racer.
Have a nice fly
(Sorry for my afull english )
volsanslimit is offline Find More Posts by volsanslimit
Old Feb 07, 2013, 03:31 AM
Sunfire is offline
Find More Posts by Sunfire
Sunfire's Avatar
Joined Jul 2007
good one, guys, chufchuf
nice to see fellow countrymen here
Sunfire is offline Find More Posts by Sunfire
Old Feb 07, 2013, 03:47 AM
Chuchuf is offline
Chuchuf's Avatar
Joined Aug 2009
Flew this pocket rocket again yesterday and what a hoot. Man it gets small fast.
BTW the way we estimated speed was to time the amout of time it took to run the length of the runway. Not perfect but close. I'll try and get someone to shoot video of it for me.
We also run stock setups and pylon race them on a 75m 2 pole course on 3S and I'm gonna tell you it's a hoot on that tight course.
On 4S stock motor we get 110 or so. So pretty quick and fun but not near as fast as the setup above. Probably a little faster that an EF-1 plane.
Terry
Old Feb 07, 2013, 05:20 PM
rhelgeson is offline
Find More Posts by rhelgeson
United States, WA, Sammamish
Joined May 2007
Cool Paint job
Nice looking plane. What paint did you use and did you do any prep work for the paint job?
rhelgeson is offline Find More Posts by rhelgeson
Old Feb 08, 2013, 04:31 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Quadmad, Do you know anymore info of that Bear on 6s?
Prop, ESC, How fast is that?
Thanks, Walter
TripleW is offline Find More Posts by TripleW
Old Feb 08, 2013, 04:36 PM
Chuchuf is offline
Chuchuf's Avatar
Joined Aug 2009
Krylon paint. Just sanded the surfaces with 1500 and water but more to knock the dimples off that I assume are create in the molding process.
Terry
Old Feb 08, 2013, 07:01 PM
Quadmad is offline
Joined Jul 2012
Thanks, Walter
This is what I found on that setup
2x3s 1000mah in series. Prop 5x5. Motor, Turnigy 2826 2200kv 56A =1243.2 Watts
Old Feb 09, 2013, 11:07 AM
hakank is offline
Find More Posts by hakank
Sweden (┼kersberga)
Joined Nov 2004
Ordered one with a NTN Prop Drive 28-36 3000KV and a couple of 4s 45C 1300mAh nano.
hakank is offline Find More Posts by hakank
Old Feb 10, 2013, 04:49 AM
Chuchuf is offline
Chuchuf's Avatar
Joined Aug 2009
Let us know how that 3000 kv motor works with those batteries ie RPM, amps, battery??.
I have one but haven't tried it yet.
Terry
Old Feb 10, 2013, 04:51 AM
Chuchuf is offline
Chuchuf's Avatar
Joined Aug 2009
Flew the pocket rocket again yesterday on a 5 x 5.5 apc. This prop pulls it the best so far.
Terry
Old Feb 24, 2013, 08:45 AM
hakank is offline
Sweden (┼kersberga)
Joined Nov 2004
Hmmm....Purchased NanoTec 1300 (4 cell): Seems like I have to do a major cut session to get it to fit somewhere..And, it will get heavy in the nose. Or that's maybe cured if I move the motor back 10mm?
Discussion FC Plane,140 MPH On 10% Nitro How Would You Do It? tigreflyer Control Line 32 Feb 25, 2013 11:46 AM
Discussion My NTM 3000kv motor seems to have a ton less power than it used to. Why? Koo Power Systems 23 Jan 11, 2013 10:12 PM
Sold RC logger eye one less than month old abletowinginc Aircraft - Electric - Multirotor (FS/W) 1 Jan 11, 2013 10:02 AM
Wanted uhf for less than $140 chatch15117 FPV Equipment (FS/W) 16 Jan 31, 2012 06:26 AM
