Old Feb 06, 2013, 06:24 AM
mudcow007 is offline
Find More Posts by mudcow007
Liverpool, UK
Joined Jul 2006
HK50A esc?
morning all
i have just bought a replacement esc for my bixler as it was not arming the motor - so i thought it would be a perfect time to upgrade my motor an esc.
i bought one of these
and also one of these
but, just noticed the esc will require a power supply
my old esc just got its power from the receiver. (this one)
can anyone explain what i need please
thanks
mudcow007 is offline Find More Posts by mudcow007
Old Feb 06, 2013, 06:47 AM
matthew_herbe is offline
Find More Posts by matthew_herbe
United Kingdom, England, Crawley
Joined Nov 2011
that ESC plugs into your throttle channel on the receiver. you then plug your main lipo on the ESC so your motor only gets power from your main lipo. you will need an extra battery pack to power the receiver and all the servos but you have to watch the voltage its usually 6V max. it is a good system to have two separate packs because if you run out of power in your main lipo you will still have control of your plane as there is an external power source. many larger models work on this system
matthew_herbe is offline Find More Posts by matthew_herbe
Old Feb 06, 2013, 09:08 AM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Originally Posted by mudcow007 View Post
morning all
thanks
yea you bought the Opto , i got this one here,notice the 4amp sbec built in. http://www.hobbyking.com/hobbyking/s...dProduct=24716
fastfwd is offline Find More Posts by fastfwd
Old Feb 06, 2013, 09:13 AM
Liverpool, UK
Joined Jul 2006
ahh crap, thanks for the reply
would you try an replace the one i bought with a built in Sbec?
or just use two lipo's?
Old Feb 06, 2013, 09:46 AM
Jim Buzzeo is offline
Find More Posts by Jim Buzzeo
Jim Buzzeo's Avatar
Willmar, Minnesota, United States
Joined Sep 2004
you can either get a different ESC (one with the bec built in)
OR get a separate BEC (what is designed to go along with the ESC you purchased)
http://www.hobbyking.com/hobbyking/s...V_5A_UBEC.html
no need to use 2 lipos.
Jim Buzzeo is offline Find More Posts by Jim Buzzeo
Old Feb 06, 2013, 10:35 AM
Liverpool, UK
Joined Jul 2006
thansk jim
would this be suitable
its in the UK warehouse, the one you linked to was not
Old Feb 06, 2013, 10:47 AM
Jim Buzzeo's Avatar
Joined Sep 2004
yup, that one should work fine for you
Old Feb 06, 2013, 12:49 PM
Liverpool, UK
Joined Jul 2006
when i went back on the one that i had linked too had gone too!!
so i luckily found the one you linked to on eBay
thanks for your help!
Old Feb 08, 2013, 06:03 AM
Liverpool, UK
Joined Jul 2006
Hello all
sorry for sounding dumb but...
i managed to find a HK ubec
so now i have all of this
how do i go about connecting it all up?
I guess the 3 wires from esc go to motor
red & black wires from esc go to lipo
now im stumped!
thanks
Old Feb 08, 2013, 06:13 AM
John S. is offline
Find More Posts by John S.
United States, NY, Center Moriches
Joined Feb 2012
Thats correct. Just make sure the motor is spinning in the right direction. If not just change a wire from the esc to the motor. In other words swap wires. That will change the direction the motor spins.
John S. is offline Find More Posts by John S.
Old Feb 08, 2013, 07:01 AM
Liverpool, UK
Joined Jul 2006
thanks John
what about the ubec though?!
Old Feb 08, 2013, 08:33 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Solder the two bare wires on the ubec to the batt. connector when you solder it to the ESC. You can plug the ubec into any of the open connectors on the rcvr. Of course the ESC plugs into the throttle channel of the rcvr.
Hope this helps
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Feb 08, 2013, 08:42 AM
Liverpool, UK
Joined Jul 2006
Mr Flypaper, that is marvelous!
thank you kindly
Old Feb 08, 2013, 04:06 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Might be worth noting that your ESC is way overkill. This isn't a bad thing in itself, but you're paying a rather significant weight penalty with the oversized ESC and that BEC, not to mention the extra "stuff" adding potential failure points to your system. You could easily shed a lotta grams with this ESC, which has its own built-in BEC and is more than suitable for your motor.
Piece is online now Find More Posts by Piece
Alert Fake Hobbywing Skywalker 20A ESCs from TomTop - "SCUMWALKER ESCs" Soma Multirotor Electronics 78 Feb 16, 2016 12:39 AM
Wanted need x6 ESC's or a few Mystery 30A ESC's zestyzsauce Aircraft - Electric - Multirotor (FS/W) 1 Jan 23, 2013 12:26 PM
Sold HobbyWing Flyfun ESC 80A High Voltage ESC jgalexander Aircraft - Electric - Power Systems (FS/W) 1 Jan 19, 2013 12:19 PM
2 NIB Turnigy Plush 30 amp + 30 amp turnigy ESC for 60-80amp ESC Koo Non R/C Items (FS/W) 1 Jan 15, 2013 11:31 PM
Sold Trade 2 NIB Turnigy Plush 30 amp + 30 amp turnigy ESC for 60-80amp ESC Koo Aircraft - Electric - Power Systems (FS/W) 1 Jan 15, 2013 10:55 PM
