Old Feb 15, 2013, 02:02 AM
doonunder is offline
Find More Posts by doonunder
New Zealand, Auckland, Waiau Pa
Joined Dec 2006
Well got one coming via singpost so I figure I've got pleeeeeeeeeenty of time to mull over a set up.
Using my 3300mah 4s lipos and if AUW won't exceed 1200gm I am looking at a NTM prop drive approx 1300kv and http://www.hobbyking.com/hobbyking/s...6_Pusher_.html
which if is anything like the 5x5 version will more than stand up to any abuse.
Should be a good compromise between efficiency and performance I am hoping, thoughts?
Edit; 28mm motor if weight is under 1200gms?
doonunder is offline Find More Posts by doonunder
Old Feb 15, 2013, 06:26 AM
NutBag is online now
Find More Posts by NutBag
NutBag's Avatar
Australia, QLD, Brisbane
Joined Oct 2005
Originally Posted by HappySundays View Post
Cool video, but do you mean Z-84? I couldn't find any info about Z-86s...
Yeah I meant the little wingwing Z-84.
Here's a new one I just threw together as the old one was a bit battle scarred.
Video Inverted V in a fin, uhf dipole in wing and cut the wingtip skids off to clean it up a bit more and it was a little yawry in wind.
NutBag is online now Find More Posts by NutBag
Old Feb 15, 2013, 08:24 AM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Has anybodies shipped from Hobby King yet? Placed my order 8 days ago and it still says Received in the status. Guess chinese new year is still in effect.
blueprint is offline Find More Posts by blueprint
Old Feb 15, 2013, 08:27 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Same here although an order (that didn't include this wing) I placed the same day after this one shipped this morning.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Feb 15, 2013, 10:35 AM
hammer833 is offline
Find More Posts by hammer833
Rick
hammer833's Avatar
Canada, MB, Winnipeg
Joined Apr 2007
I placed an order 10 days ago and it just shipped today. HK has been on holidays for 2 weeks for Chinese New Years. Be prepared for a delay in shipping with the Chinese post office as well. After New Years they have a huge backlog. I had an order last year at this time that took 3weeks for shipping.
hammer833 is offline Find More Posts by hammer833
Old Feb 15, 2013, 10:38 AM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
bummer.... was hoping to have it by the end of the month.
Old Feb 15, 2013, 06:55 PM
HappySundays is online now
Find More Posts by HappySundays
OpenAeroVTOL developer
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
Thanks nutbag,
Can you post a list of all the components you use to make up your FPV setup?
From camera to TX and also at your end.
I'm a bit surprised it all fits in the Z-84.
My model is now listed as "in Queue" but not shipped.
HappySundays is online now Find More Posts by HappySundays
Old Feb 15, 2013, 08:06 PM
NutBag's Avatar
Joined Oct 2005
Thanks nutbag,
It fits in... Just takes a little work, some soldering skills and imagination.
- ezuhf 8ch lite rx with dipole, skylark tiny 3 osd with 10hz GPS and current sensor, 2x hs56 servos, castle Phoenix 10esc, axi 2204-54 motor w/6x5, 5a ubec, mickeymouse lc filter, superhad600 pz0420 cam, 300mw vtx and a zippy1300 15c 3s Lipo.
Old Feb 15, 2013, 11:49 PM
gke is offline
gke
Find More Posts by gke
gke
Australia, VIC, Ringwood
Joined Feb 2008
Motocalc says 90min at 35% throttle optimum airspeed 11M/S. I don't have the NTM params so I used a Hyperion 2213-24 1337K/V. It also predicts 260C motor temp at full throttle!
I will probably run a "toy" Turnigy 2213-20 1050Kv with a 9x6 folder with a 3s 4900 pack. Prediction is 120min at 52%. A 3s 2200 pack shows 70min. I tend to use the 2213-20s and the 2200 packs on must of my under 1Kg aircraft - not rocket ships but good enough.
My order has progressed to the warehouse .
gke is offline Find More Posts by gke
Old Feb 15, 2013, 11:55 PM
Joined Dec 2006
Thanks... is that good or bad
Old Feb 16, 2013, 12:16 AM
gke is offline
gke
gke
Joined Feb 2008
The full throttle temperature prediction is bad if you use it for more than a very short burst - the magnets cook!
There are an almost unlimited number of motor/prop combinations out there.
For 1300K/V the pitch probably should be closer to 4. If the motor is this one they recommend 8x3.8.
http://www.hobbyking.com/hobbyking/s...50KV_310W.html
6.5x4 still seems to give 84min as and the motor efficiency is 79% which is OK.
http://www.hobbyking.com/hobbyking/s...4_Pusher_.html
Buy and try I guess.
Motocalc is not a perfect predictor but it gets close.
Old Feb 16, 2013, 03:41 AM
Joined Dec 2006
Thanks gke, couldn't find any info on the hyperion one but that ntm you linked looks a little small, i have a proven setup with a ntm 2200KV 28-36 and 6 inch prop but would be nice to have a quieter and as many say more efficient low kv setup on this one.
Old Feb 16, 2013, 06:12 AM
gke is offline
gke
gke
Joined Feb 2008
All good. The 28-36 would certainly take it out vertically but as you say a bit noisy!
I will do some endurance times when I get it in the air and post the results. For interest and only slightly off topic my UAV efforts back a bit - a bit grainy.
Aerobotics - UAV Duigan Fly By (0 min 50 sec)
Cheers
Greg
Old Feb 16, 2013, 03:14 PM
Blue Flyer is offline
Find More Posts by Blue Flyer
happy when flying
Blue Flyer's Avatar
United Kingdom, England, North Yorkshire
Joined Dec 2010
I have a few 2200mah 4S here I'll use in parallel. with my 3542 NTM 1000kv motor I had on my skywalker and a 9x6 prop. Boscam HD cam already on my Funjet Ultra but a bit too heavy for that... looks Ideal for the little hole in the bottom of this though, with a wdr600 on the top motor mount. I've been piddling around for ages in FPV and only recently started to get any success. will convert my Bixler 2 back to LOS and just have 2 x FPV planes.... Funjet Ultra and Phantom FX61
Blue Flyer is offline Find More Posts by Blue Flyer
Old Feb 16, 2013, 03:25 PM
Joined Dec 2006
Hi CorporalB, did you have any problems with the MG90s in your Bixler2? I had 2 burn out whilst in stabilization.
New Product NEW flying wings from HObbyking - good for FPV ? i3dm FPV Talk 16 May 12, 2015 02:29 PM
Discussion Starting FPV with a flying wing? JYVAI UAV - Unmanned Aerial Vehicles 3 Mar 23, 2014 09:49 PM
Discussion The Fury Flyer- 54" Scratch build FPV Flying Wing Bixler13 FPV Talk 7 Mar 10, 2013 11:00 PM
Help! As3x and flying wing airplanes Jyester Scratchbuilt Indoor and Micro Models 17 Jan 22, 2013 08:29 PM
Discussion HobbyKing - Fox 2.32m EPO Glider for FPV Cralis FPV Talk 19 Sep 14, 2011 03:24 AM
