Old Feb 08, 2013, 12:07 AM
doonunder is offline
Find More Posts by doonunder
New Zealand, Auckland, Waiau Pa
Joined Dec 2006
Thanks Nutbag! Yes weighing up whether it's worth it, most of the time I can get it out of the way with throttle management and the brake on, and the only nag is sometimes if it shifts in the collet you lose your balance.
doonunder is offline Find More Posts by doonunder
Old Feb 08, 2013, 11:51 PM
HappySundays is offline
Find More Posts by HappySundays
OpenAeroVTOL developer
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
I bet it'll come with the HK standard HTX-900 clone servos which I have no faith in whatsoever.
I have some DS-329 MG or even DS-919 MG to use if they don't fit.
I was just watching a Zephyr II video on Youtube where they were using full-size (yep I mean FULL sized) servos and what looked to be 1/4" monster hollow carbon fiber tube control rods. Possibly a little over-the-top
The manual indicates Z-bend wire control rods but lately I've been a fan of solid 2mm CF rods that HK sell.
Anybody have any plans to mod theirs?
HappySundays is offline Find More Posts by HappySundays
Old Feb 09, 2013, 12:23 AM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
I have a pair of Hitec HS65MG servos i plan on using. Going to use steel rods with dubro ez connectors. Turnigy Plush 60a esc with an NTM 3536 1800kv motor. If that motor wont fit i have a 2830 1800kv. Dragonlink.
As for fpv gear i plan on using a 800mw 1.3ghz vtx, RMRC 540 camera, dragonosd and maybe an FY30.
We'll see. Hopefully i get it at the end of the month. Currently busy building a zephyr.
blueprint is offline Find More Posts by blueprint
Old Feb 09, 2013, 06:23 AM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
It says 800kv motor on showcase HK page?
Is it possible to use 4s-5000mah, APCe 12x8 prop. (or too heavy?).
I have this motor:
http://epbuddy.com/index.php?main_pa...roducts_id=187
I use this same setup on my SkyHunter and SkyWalker 2013 Carbon Boom version.
My SkyHunter has unlimiter verticals using this setup....
rclab1 is offline Find More Posts by rclab1
Old Feb 09, 2013, 06:45 AM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Link to the manual:
http://www.hobbyking.com/hobbyking/s...X460617X41.pdf
Order one to try out. Hopefully it will be a nice slower speed FPV wing.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Feb 09, 2013, 08:28 PM
Joined Feb 2011
Originally Posted by flitelab View Post
Link to the manual:
That's the manual I uploaded to HK.
There's a size-reduced one in the first post of this thread.
Old Feb 10, 2013, 05:28 AM
gke is online now
gke
Find More Posts by gke
gke
Australia, VIC, Ringwood
Joined Feb 2008
Originally Posted by doonunder View Post
Can someone help my unlogical brain, if I buy a folding prop set, to convert to pusher I'd just unscrew the props and switch 180 degrees?
Order placed as well .
I use folders on my flying wings. The main thing you need to be careful of is to make sure the blades do not crossover when they trail otherwise the motor can spin up with both blades on one side. This can rip the motor right out of the aircraft really quickly. I make a rectangular plate (~7x20x1.5mm aluminium) that fits on the collet bolt as an additional washer and touches the base of the inside face of the blades.
The reduction in drag is quite significant if you are gliding a lot - I use my wings for sloping and thermal work. The autopilot I have uses a boost glide strategy as well in altitude hold.
The Aeronaut props are also more efficient I believe than most fixed "electric" props. At the K/V for this motor it will probably pull a 10x6 folder if you are just cruising. No point in tuning the prop for max throttle work if you are interested in endurance.
Greg
gke is online now Find More Posts by gke
Old Feb 10, 2013, 05:33 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Ok thanks. Just figured I'd post a link to the PDF as well for those wanting it all in one file to print. Guess I missed the PDF link in the first post.
Site Sponsor
Old Feb 10, 2013, 07:43 AM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Disappointed in the plastic motor mount. Hopefully it holds up.
Old Feb 10, 2013, 11:38 AM
Dogdude is offline
Find More Posts by Dogdude
Joined Aug 2012
It will probably be fine fi used for it's intended purpose, i.e. the standard power set up, but I'm sure people will be fitting much more powerfull motors with matching props that are going to put considerably more stress on the mount
If you're going to do that then re inforce the mount before hand
Dogdude is offline Find More Posts by Dogdude
Old Feb 13, 2013, 03:01 PM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
Do you have a link to those rods?
epyonxero is offline Find More Posts by epyonxero
Old Feb 13, 2013, 06:05 PM
Joined Feb 2011
Yep. Here you go.
I recently tried using them on another foamie for short (100mm) pushrods and apart from being a bit of a challenge to cut (roll a very sharp knife over them) cyano into plastic clevises nicely.
http://www.hobbyking.com/hobbyking/s...idproduct=6731
Old Feb 13, 2013, 08:06 PM
Joined Feb 2012
Yep. Here you go.
Old Feb 13, 2013, 10:57 PM
NutBag is offline
Find More Posts by NutBag
NutBag's Avatar
Australia, QLD, Brisbane
Joined Oct 2005
And for anyone wondering what it's like to FPV a little WingWing here's a quick vid, not my vid.. I'm the other one in there.
Both wingwings Z-86's
Chris.
Wing Wing FPV. (3 min 7 sec)
NutBag is offline Find More Posts by NutBag
Old Feb 14, 2013, 02:32 PM
Joined Feb 2011
Cool video, but do you mean Z-84? I couldn't find any info about Z-86s...
New Product NEW flying wings from HObbyking - good for FPV ? i3dm FPV Talk 16 May 12, 2015 02:29 PM
Discussion Starting FPV with a flying wing? JYVAI UAV - Unmanned Aerial Vehicles 3 Mar 23, 2014 09:49 PM
Discussion The Fury Flyer- 54" Scratch build FPV Flying Wing Bixler13 FPV Talk 7 Mar 10, 2013 11:00 PM
Help! As3x and flying wing airplanes Jyester Scratchbuilt Indoor and Micro Models 17 Jan 22, 2013 08:29 PM
Discussion HobbyKing - Fox 2.32m EPO Glider for FPV Cralis FPV Talk 19 Sep 14, 2011 03:24 AM
