Old Feb 06, 2013, 01:59 AM
Australia, VIC, Croydon
Joined Dec 2012
lipo swelling
hi,
I have some turnigy lipos from hobbyking that i have used about 4 times.
one is slightly swollen (if i push on the middle of the side it makes a pop when the heatshrink springs back)
Cycle:
balance charge at 2.2amps (for 2200mah) with turnigy accucel 6.
Fly with my bixler fpv.
Take home and charge to storage and leave them untill i need them.
i keep them in my room. It is summer so there is verying temperature but i havent found anything that suggests this could damage them.
in my room ranges from about 25 to 40 degrees celcius.
I have moved them down stairs where it is a more constant, cooler temp.
any explenation as to why this has happened would be much appreciated as i have just recieved 2 zippy 3000mah 3s batterys and dont want to damage them.
thanks.
lucamoharram is offline Find More Posts by lucamoharram
Old Feb 06, 2013, 02:28 AM
Letchworth, Great Britain (UK)
Joined Jul 2004
You say you've only used them four times, but how old are they? How long have they been stored at temperatures up to 40 degrees?
Storing at a cooler temperature can only help.
abenn is offline Find More Posts by abenn
Old Feb 06, 2013, 02:31 AM
Joined Dec 2012
thanks.
can you tell me the minimum and maximum voltage per cell for lipos?
and is it okay to charge at 2.2amps? could i go higher?
Old Feb 06, 2013, 06:57 AM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
LiPo cell volts:
4.2V = full charge
3.85V = 50% charge (storage level)
3.7V = minimum at rest voltage
3.3V = minimum loaded voltage
3.0V = 0% charge. Never go below
2.2 amp charge is fine. Many, including myself, feel it would be OK to go as high as 6.6 amps.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Feb 07, 2013, 01:47 AM
Joined Dec 2012
thanks glen,
How long do your turnigy lipos last at high charge rate?
And what is the C of a pack and how do you work it out?
Old Feb 07, 2013, 05:39 AM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Perhaps this will prove helpful.
http://www.rcgroups.com/forums/showp...61&postcount=1
Charles
Old Feb 08, 2013, 03:25 AM
Joined Dec 2012
Thanks charles!
Do LiPos always swell before exploding/burning? HankF Batteries and Chargers 16 Sep 04, 2005 12:16 PM
Help! Slight swelling on lipo pack Tengler Batteries and Chargers 1 Jul 20, 2005 04:24 PM
TP Lipo's In Parallel swell. :( Arctic@1M Batteries and Chargers 11 Apr 06, 2005 09:39 PM
Question Do Lipos Always Swell Dan Baldwin Batteries and Chargers 3 Aug 12, 2004 06:20 PM
Tanic Lipo pack swells Caveman Batteries and Chargers 24 Mar 29, 2004 07:52 AM
