Old Feb 05, 2013, 08:32 PM
jonspot25 is offline
Find More Posts by jonspot25
jonspot25's Avatar
Joined Jan 2013
Question
C ratings ?????
If the factory recommended battery for my plane is a 14.8v 2200mah 25c and I use a 14.8v 2200mah 45c battery. Will the difference in C ratings cause any problems ?
I'm using a 50amp esc, a 650kv 12pole motor, with a 13x6 prop.
jonspot25 is offline Find More Posts by jonspot25
Old Feb 05, 2013, 09:21 PM
CiprianGugu is offline
Find More Posts by CiprianGugu
Look Up
CiprianGugu's Avatar
United States, TN, Jamestown
Joined Nov 2003
It will work fine.
CiprianGugu is offline Find More Posts by CiprianGugu
Old Feb 05, 2013, 09:39 PM
whitecrest is offline
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
With the 45C battery, you will probably have a higher loaded voltage. Normally, this will not cause any problems. However, if your power system is already being pushed, the extra loaded voltage and increased power available can result in component overloading. It is a good idea to comfortably overrate power system components to accommodate intermittent power surges.
whitecrest is offline Find More Posts by whitecrest
Old Feb 05, 2013, 09:59 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
If you are concerned about over taxing your system with the higher C battery get a watt meter and see for yourself if it causes a problem.
I do not think the additional C rating will be a problem.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Discussion Relationship between C rating and amps you can charge at? cloud_9 Batteries and Chargers 33 Feb 04, 2013 09:29 PM
Discussion Need Advise on what C rating for this system set up! chopper52 Electric Ducted Fan Jet Talk 1 Jan 12, 2013 01:09 PM
Wanted 4s 2350-2700 mAh with high C rating and Deans clip TheMagician007 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 08, 2013 11:24 PM
Help! Need help understanding Discharge rate/ Charge rates, C ratings fltekdiver Batteries and Chargers 10 Oct 02, 2010 09:29 AM
Discussion Lipo C-ratings puzzle: what's most important, C-rating or mAh capacity?? Merlin45 Batteries and Chargers 18 Apr 03, 2010 04:45 PM
