Old Feb 08, 2013, 09:47 PM
slotracer577 is offline
Find More Posts by slotracer577
Joined Jan 2006
I have gone to gorilla tough for sheets. 50 lb test. It is supple and holds knots well.
slotracer577 is offline Find More Posts by slotracer577
Old Feb 08, 2013, 10:08 PM
bigpat is offline
Find More Posts by bigpat
Love RC Yachts!!!
Australia, VIC, Melbourne
Joined Aug 2012
I use the tiny SailsEtc stainless bowsies with 20lbs for toppling lifts, no problems.
I use 50 & 80lbs with standard bowsies no prob, but I believe in using a purchase system in high tension applications, such as backstay, jib halyard ( though I use holes in the mast to adjust rake), and jib luff tension.
There is a fantastic quality 130lbs line, as thin as 80lbs. But is really expensive.... Varivas GT Max PE10. 600 yards is $299...
Failing that, PowerPro is affordable, but for applications where you'd use. 130lbs, suppleness s not required ....
bigpat is offline Find More Posts by bigpat
Old Feb 09, 2013, 12:43 AM
willey is offline
Find More Posts by willey
warbirds
willey's Avatar
United States, PA, Waterford
Joined Jul 2007
OOOOoooooooohhhhhhh......Mmmmyyyyy ......I have alot to learn
The Good Ol'Days!!
willey is offline Find More Posts by willey
Old Feb 09, 2013, 07:38 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
I run a sailsetc bowsie 130lb test on the booms leading to a hair bead which will not slip for adjustment,then there is a loop spliced in the end of both sheets that slips over the bead this way you can use any weight sheet you so care with no slipping,the big plus here is when derigging the sheet adjustment remains on the booms after slipping off the sheet loop,when popping different rigs as in the IOM class the sheet settings are already there on every rig.If you like how the boat sailed last week well the trim is there.
The Tug is offline Find More Posts by The Tug
Old Feb 09, 2013, 11:51 AM
jimhurley is offline
Find More Posts by jimhurley
jimhurley's Avatar
Sequim, WA
Joined Jan 2004
Failing that, PowerPro is affordable, but for applications where you'd use. 130lbs, suppleness s not required ....[/QUOTE]
Here is a link to my CJ #503 page http://www.rcgroups.com/forums/showt...1727959&page=4 which shows some line I purchased for my new boat. It was very inexpensive and the line for the standing rigging is very supple. I put a knot in it to test it and had no problems tying the knot or with the strength of the knot. The line for the standing rigging is used on downriggers for fishing, it mics out at .0215 inch.
jimhurley is offline Find More Posts by jimhurley
Last edited by jimhurley; Feb 09, 2013 at 12:27 PM. Reason: Added measurement of line.
Old Feb 13, 2013, 09:46 PM
willey is offline
warbirds
willey's Avatar
Joined Jul 2007
thank you guys for all the options, looking forward to hearing what others use, very interesting.
Old Feb 15, 2013, 08:49 AM
The Tug is offline
Barbados
Joined Jan 2011
Type dynema fishing line Ebay,colours free shipping any weight you want $15.Even multi coloured spools.
Old Feb 15, 2013, 03:52 PM
bigpat is offline
Love RC Yachts!!!
Joined Aug 2012
Remember that you get what you pay for...
Some of that Ebay stuff is cheap qulity, with rough opdn weave, and quite stiff, not what you want for sheets.
Best value for money in my opinion is Sunline Super PE. Smooth, supple, relatively thin, and hydrophobic. A 150mtr spool costs $35. You could buy a spool of 40 or 50lbs and use it for everything if you wanted.
I use 15, 20, 50, and 80lbs on my boats( yes i have a lot of boats.... )
Discussion !/2 a spectra lines rcflyer-rick Control Line 9 Jan 27, 2012 05:51 PM
Help! Spectra Mod Thrust-line? N9DP Electric Sailplanes 3 Oct 10, 2007 11:04 AM
"Spectra line" hinge system. Anybody? mdlifcrisis 3D Flying 7 Jul 19, 2005 10:53 AM
