Feb 05, 2013, 06:22 PM
United States, WA, Port Angeles
Joined Dec 2009
is your plan, to be strictly IMAC, cuase I was just watching the troybuilt guys set-up vidz, for IMAC and 3D!
you basicaly set-up for 3d, then you set the duel rates at what they call IMAC settings, which is abou 12* ta 15* on the elevator and ailerons, and around 25* ta 30* on the rudder! with about 30% expo on duel, and 65 ta 70% on full!
and I also saw somewhere, that if you don't plan on flying 3D, then don't set your plane up for it! you are wasting set-up! if you set a plane up for 3D and never use high rates, you are wasting upto are more then 1/2 your servo movement!
