Old Feb 05, 2013, 02:22 PM
Skylex is offline
Find More Posts by Skylex
United Kingdom, England, Birmingham
Joined Jan 2013
Help!
Grump Screws Not Giving Enough Grip
Hey RC-Friends,
I just got these screw propeller adapters, but when I tighten them the propeller is still not fastened 100%. Is this normal ? Should I get a better screw-driver? Should I soak it in THREADLOCKER ? here a vid.
still turns
MOVI0063 (0 min 20 sec)
Skylex is offline Find More Posts by Skylex
Old Feb 05, 2013, 02:39 PM
ripmax is offline
Find More Posts by ripmax
ripmax's Avatar
uk. northampton
Joined May 2009
Those grub screws have to bite on the shaft so the prop does not twist on the shaft at all, thread lock will only stop the grub screw loosening during flight, if the grub is as tight as it will go then it suggests the thread in the prop adaptor is knackered.
ripmax is offline Find More Posts by ripmax
Old Feb 05, 2013, 02:44 PM
ripmax is offline
ripmax's Avatar
uk. northampton
Joined May 2009
You would be better off with something like this
http://www.giantshark.co.uk/317mm-pr...-p-407670.html
make sure u get the right size for the shaft of your motor
Old Feb 05, 2013, 04:41 PM
Skylex is offline
Joined Jan 2013
I lifted off anyway ... Im tired of all this fiddelydiddely. Got problems lifting off. I decided to hold it and it attacked me. Im bleeding. Three cuts right into my forearm. Why is it lifting off like this ? :
FREAKINCOPTER (0 min 33 sec)
nom nom nom
Old Feb 05, 2013, 06:32 PM
a9amg is offline
Find More Posts by a9amg
a9amg's Avatar
Manchester, UK
Joined Sep 2008
**** WARNING **** You are going to injure yourself more
Stop trying to fly it indoors! What if it hits your face.... Eye....
Its flying like that probably because a prop is slipping on the shaft.
Your lack of care will make this hobby very difficult for you..
Get the props correct so they don't slip anymore, then try it again OUTSIDE!
a9amg is offline Find More Posts by a9amg
Old Feb 05, 2013, 06:37 PM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
Adapter below with no grub screw works perfectly.
Mortimer is offline Find More Posts by Mortimer
Old Feb 06, 2013, 01:44 PM
ripmax is offline
ripmax's Avatar
uk. northampton
Joined May 2009
Agree, sort the props before you do anything else, it will not fly unless props are solid on the motor shafts. Test outside well away from u and any other obstacles.
With the props off make sure motors are reacting in the correct way, if u drop an arm on the quad that motor should speed up.
Old Feb 07, 2013, 08:54 AM
skizziks is offline
Find More Posts by skizziks
United States, NJ, Manville
Joined May 2006
If you are having problems with grub screws slipping on the motor shafts you must use a dremel and grind down a flat spot on each motor shaft...
skizziks is offline Find More Posts by skizziks
Help! Futaba 8FG Beeper Not Loud Enough BigTradioman Radios 6 Feb 02, 2013 06:04 PM
Help! Nano CP X Not Enough Negative Pitch DX5e Pacman82 Micro Helis 2 Jan 22, 2013 07:50 PM
Help! Screw sheared off in CB100 blade grip eyemdee Micro Helis 6 Jan 22, 2013 11:30 AM
Question Why is the ESC not giving enough power? RC_Bob Power Systems 13 Apr 03, 2012 12:51 AM
