Feb 06, 2013, 06:19 PM
Joined Apr 2011
Well - there is one traditional R/C gasser that I know of that is fuel injected. Cloud Cap Technology distributes an injector system for the 3w 28i and they have it as an option in one (or several?) of the UAV's they sell. I believe the system was actually developed by Currawong Engineering, which claims to have developed fuel injection for small 2-stroke and 4-stroke gas and "heavy fuel" engines. I got really excited until I contacted them and found out that the whole system (ecu, injectors, pump, engine, etc...) would run about ohhh... $15-20k! So yeah.... no.... not on my budget...
Tuning can be a bit of an issue if you are wanting to make big changes in altitude, but flying under 1000 feet and crop dusting should not warrant a closed-loop system like what you are wanting. I have seen people fix a servo arm to the high-speed needle of 20-30cc gassers and tune by sound and temp (mostly cylinder head temp) with a knob on the transmitter. I would like to do this some day, but I just do not have a need for it right now because as Chill said, they pretty much stay more or less in tune.
Closed loop systems can be done with carbs as I understand it, but I never read far enough into it because I soon realized that I would never actually do it.
