Old Feb 05, 2013, 08:26 AM
martig is offline
Find More Posts by martig
Estonia, Harju, Tallinn
Joined May 2012
Idea
Sanding foam cores
Yesterday i discovered a great way of sanding off the "orange peel skin" or whiskers that form while cutting with a hot wire. Before I have sanded cores with worn out sandpaper, but I've always managed to damage the cores. Even if I was extra careful some foam dust still balled up and made a crease in the foam.
So yesterday I found a pack of sanding wool (scuff pads) lying on a shelf and decided to give it a try. This stuff is great. It's almost impossible to damage the cores. You still have to be careful at the leading edge, but you can sand any way you want in other areas. Because the material is like a mesh the foam dust stays in the mesh and won't ball up.
Here's the stuff I use tried --> http://www.amazon.com/Mirka-18-118-4...dp/B001BKW03S/
I hope I'm not the first person who discovered this, but I haven't heard about people using scuff pads to sand their cores.
martig is offline Find More Posts by martig
Old Feb 06, 2013, 07:02 PM
leleopard is offline
Find More Posts by leleopard
United Kingdom, England, London
Joined Feb 2010
you can also try the sponge sanding blocks, something like this:
http://www.diy.com/nav/decor/decorat...Medium-9254890
because they are not fully rigid they tend to be easier to control whilst still retaining a flatish surface which helps with sanding accuracy. + they are thick so you have a good grip/control
leleopard is offline Find More Posts by leleopard
Old Feb 07, 2013, 12:45 AM
martig is offline
Joined May 2012
I think the main benefit of scuff pads is that you don't have to be so careful when sanding. If you're using reasonable pressure on the pad it's almost impossible to create creases in the foam. Also, scuff pads only take off a very thin layer of foam. You can't use them for reshaping the airfoil or anything like that.
When I used regular sanding blocks or sandpaper I always managed to create some creases in the foam. Then I had to use spackle to fill the creases and sand again.
Old Feb 07, 2013, 07:35 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
I have used grey (800 grit) scotchbrite pads for a couple years to clean the ridges off of CNC milled cores. Works great.
tom43004 is offline Find More Posts by tom43004
Discussion Liquid Sheeting over Foam Wing Cores??!!!?? chilipecker Giant Scale Airplanes 12 May 12, 2013 02:08 PM
For Sale +++ Foam core GRYPHON kit +++ oldscooler Aircraft - Sailplanes (FS/W) 3 Feb 05, 2013 01:52 PM
Help! To sand, or not to sand...wing cores that is. Jason Courville Hand Launch 8 May 04, 2009 04:24 PM
Question Sanding airfoils into sheet balsa stabs? Or, foam core tail surface? Sled Driver Slope 11 Nov 25, 2005 07:14 PM
Sanding Foam Core / Skin Layup Air Head Composites Fabrication 7 Mar 07, 2005 06:27 PM
