Old Feb 05, 2013, 06:56 AM
aleXtino is offline
Find More Posts by aleXtino
dumbthumb
aleXtino's Avatar
World's Ass - Chile
Joined Dec 2004
Replace Switch F Aurora
Is possible to replace switch F (two points) with this?
http://www3.towerhobbies.com/cgi-bin...?&I=LXCLP3&P=7
At least the switch are the same length
aleXtino is offline Find More Posts by aleXtino
Old Feb 05, 2013, 11:55 AM
aleXtino is offline
dumbthumb
aleXtino's Avatar
World's Ass - Chile
Joined Dec 2004
Any on this?
Old Feb 05, 2013, 12:23 PM
fcbflyer is offline
Find More Posts by fcbflyer
Sloping the Financial Cliff
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
I think they are all the same thread size. I opened mine up, de-soldered the switch and went with it to radio shack and picked up a suitable replacement.
fcbflyer is offline Find More Posts by fcbflyer
Old Feb 05, 2013, 01:54 PM
lougedo is offline
Find More Posts by lougedo
lougedo's Avatar
Spain, GA, Corunna
Joined Jan 2011
Yes! they are compatible, i replaced the G and H on mine
Perfect and smooth now
lougedo is offline Find More Posts by lougedo
Old Feb 16, 2013, 10:46 AM
RookieAv8r is offline
Find More Posts by RookieAv8r
United States, TN, Knoxville
Joined Mar 2012
Are the switches soldered directly to the board or wired to the board? I just broke switches G & H when I dropped my less than 24 hours old Aurora 9.
RookieAv8r is offline Find More Posts by RookieAv8r
Old Feb 16, 2013, 11:45 AM
fcbflyer is offline
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
There are little wires soldered to the switch. Easy fix.
Old Feb 16, 2013, 02:19 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
As in previous post, wires soldered on. Make and use a DIY
. Bezel Wrench to avoid damage to case.
. Hitec - Switch Part Numbers - Replace Broken Switches.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Feb 20, 2013, 10:03 PM
Joined Mar 2012
[QUOTE=A.T.;24154723]As in previous post, wires soldered on. Make and use a DIY
Hitec Switch Part Number link is broken. Can you please repost the link?
Thanks.
Old Feb 20, 2013, 11:35 PM
A.T. is offline
Joined Aug 2002
[QUOTE=RookieAv8r;24200649]
Thanks.
Repeat of the post:http://www.rcgroups.com/forums/showp...18&postcount=8
Originally Posted by the pope View Post
I added the all bets are off because its not the radios fault but I know of 3 people that have broken switches and in 7 yrs of doing this I havent heard of anybody else doing this with other brands . Cheers the pope
A very common problem, near the top of reasons for all known brands of Tx, referred here.
"I havent heard of anybody else doing this with other brands "
Simply some appear more readily on retail shelves and web searches e,.g.
http://www.futaba-rc.com/parts/futm3676.html
Hitec switches readily available here and in some other countries, part numbers:
59003 3 Position Switch (Long Lever)
59004 2 Position Switch (Short Lever)
59005 Trainer Switch 9005
59006 2 Position Switch (Long Lever) - Eclipse
59007 3 Position Switch (Short Lever)
59008 Toggle Switch MS-550 C-L
ECLDRSW Eclipse Dual rate switch
ECLFLTSW Eclipse Flight Mode Switch
ECLRUDSW Eclipse Rudder Dual Rate Switch
54303 Trainer Plug & switch Accessory for Neon SS FM
54304 CH 1 & 2 Dual rate switch for Neon SS FM (Must Use #54302 ATV BOARD)
Aurora 9 Switches: (First digit may vary from country to country)
70017 "Toggle Switch 2-Position (Long)" SW-B / SW-F
70018 "Toggle Switch 2-Position (Short)" SW-A / SW-D / SW-G
70019 "Toggle Switch Trainer (Long)" SW-H
70020 "Toggle Switch 3-Position (Long)" SW-C
70021 "Toggle Switch 3-Position (Short)" SW-E
Alan T.
Discussion Source For Replace TRN / THR Cut Switch on 9x? Milktruck Radios 5 Feb 05, 2013 09:23 PM
Discussion Aurora 9 - Broken (F) and (C) Switch Handles WEREE Hitec/Multiplex USA 1 Dec 09, 2011 04:33 PM
Discussion Aurora Sparepart, broken switch Kimi Hitec/Multiplex USA 1 Apr 11, 2011 12:50 PM
Question Can I replace the trainer toggle switch with a DPDT toggle switch in a Futaba EX6AP? shawn595 Radios 2 Jan 01, 2011 04:50 PM
Discussion RVOSD & Aurora 9 - Program Switch for Autopilot AdamChicago FPV Talk 11 Oct 09, 2010 12:33 AM
