Old Feb 04, 2013, 10:11 PM
Milktruck is offline
Find More Posts by Milktruck
Flying Bucks
United States, PA, Bucks
Joined Oct 2011
Source For Replace TRN / THR Cut Switch on 9x?
I broke the TRN switch on my Flysky 9x. Can someone point me to a source to replace it? I've tried searching for hours...
TIA - Milktruck
Milktruck is offline Find More Posts by Milktruck
Old Feb 05, 2013, 06:25 AM
SwiftingSpeed is offline
Find More Posts by SwiftingSpeed
Sweden
Joined Oct 2010
Search eBay for "momentary toggle switch" and you'll find some that will fit, the ones that say OFF-(ON) will behave as the original trainer switch and spring back to the off position.
SwiftingSpeed is offline Find More Posts by SwiftingSpeed
Old Feb 05, 2013, 09:02 PM
Flying Bucks
Joined Oct 2011
I looked on ebay, but I'm not any closer to finding one to order
Old Feb 05, 2013, 09:13 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
The first one is most likely what you are looking for and only took couple of keystroke and couple minutes to find.
Toggle Switch SPST (Momentary) On-(Off) - After looking twice this one might be the opposite.
http://www.ebay.com/itm/Metal-Bat-To...d01fda&vxp=mtr
http://www.ebay.com/itm/Miniature-SP...item460c401619
http://www.ebay.com/itm/Momentary-mi...item41707d4d3a
RadioShack might surprise you as well.
freechip is offline Find More Posts by freechip
Old Feb 05, 2013, 09:14 PM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
Do you have a local Radio Shack? Or do a search for electronics supply in your local area. Even many auto parts places have a selection of generic switches.
Unless your hopelessly out in the sticks Id say something like this you should be able to pick up locally.You get the right thing and got it in your hand today.
If you want to order online I would look at www.radiosouthrc.com
If you cant figure out exactly what you need you can give Tony a call and he will know exactly what will work for you.
aerocal is offline Find More Posts by aerocal
Old Feb 05, 2013, 09:23 PM
Flying Bucks
Joined Oct 2011
Thanks for those links, but I'm looking to get closer to the switch that was there. Long and flat. This is the best I can find so far: http://www.infinity-hobby.com/main/p...d=6832&osCsid=
Discussion Thr-cut for electric motor on FF7 Skyshield Radios 2 Oct 24, 2008 06:27 AM
Discussion moving thr hold on dx6i to rudd switch windisevil!! Radios 2 Feb 28, 2008 05:36 AM
Question TRN switch on CX2 transmitter grapeflyer Coaxial Helicopters 1 Mar 01, 2007 10:45 PM
What is the TRN switch for on the HoneyBee CP2 transmitter? pimpybra Micro Helis 4 Sep 09, 2005 06:45 PM
