Old Feb 04, 2013, 07:55 PM
lardo5150 is offline
Find More Posts by lardo5150
United States, MO, St Charles
Joined Jan 2013
Homemade Stand / workbench
I get so much help here, I thought I would throw this out there.
I found this video when looking for a stand.
DIY: Make Your own RC Airplane work stand from PVC pipe, cheap! (3 min 22 sec)
after three crashes already, I got sick of working on this thing on my computer desk so I actually went out and bought a cheap work bench.
Workbench
http://www.homedepot.com/h_d1/N-5yc1...1#.URBlNx3Ae8A
So I followed the guy in the video and built something almost identical, except I made it taller so that when I am out at my flying spot I dont have to constantly bend over and such. Same for when I am working on it at home.
I also painted it. I usually like color schemes with red/black/white or something like that, but for some reason I went with yellow and black. I did not realize it was the same as my plane until I sat the plane on it.
I also did not want to spend 30 bucks on a short box with the stand on it, needed it to be taller.
As you can see it is still to long, so I will just cut the pipe on the bottom a bit.
The form is in the plumbing section at home depot/lowes as well.
The guy in the video uses 1.5 inch. I used 1.5 inch on the bottom for a stronger base, then the rest 1 inch. Main reason i went with 1 inch on top is the end pieces I did not have to cut like he did, they are actually some sort of 90 degree angle slash Y fit adapter thingy. So no cutting involved.
So for all you new guys like me, figured I would throw this out there. Makes working on these easier.
lardo5150 is offline Find More Posts by lardo5150
Old Feb 04, 2013, 08:18 PM
mpatterson is offline
Find More Posts by mpatterson
portage la prairie,manitoba, canada
Joined May 2003
Great idea!
I've got most of the materials in my shed - will start on it tomorrow.
thanks!
Murray
mpatterson is offline Find More Posts by mpatterson
Old Feb 04, 2013, 08:29 PM
GhostStone is offline
Find More Posts by GhostStone
Soli Deo Gloria
GhostStone's Avatar
United States, IN, Fort Wayne
Joined Jan 2012
Thank you for sharing. I think this may be this weekends project.
GhostStone is offline Find More Posts by GhostStone
Old Feb 04, 2013, 08:38 PM
Joined Jan 2013
The work bench was super cheap, and is actually very good quality for 70 bucks.
Also, if you have a turnigy charger, like the one i bought, I found this video on youtube for a cheap power supply.
I am around computer parts all day, so I snagged one and did not have to spend another 20 bucks just for a power supply.
Ghetto, but it works
Use a Computer Power Supply For Your Turnigy Battery Charger (9 min 55 sec)
Old Feb 06, 2013, 03:39 AM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Cool stand! Thanks for sharing.
Recycled walkers work well also
ozmo01 is offline Find More Posts by ozmo01
Old Feb 06, 2013, 07:30 AM
touche is offline
Find More Posts by touche
Canada, MB, Winnipeg
Joined Jan 2006
As an addendum...Drill a few holes thru the base leg ends and carry some 10 in. spikes. The wind will affect the stand when a plane is in the cradle. Just an extra safety measure.
I made a stand for a sat dish from PVC piping and ended up using some wine bags filled with water for weight. We've all seen planes blown off the work table onto the ground.
Looks good.
touche is offline Find More Posts by touche
Old Feb 08, 2013, 09:56 PM
ozmo01 is offline
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Stabilizing a stand is just "plane safe" The heavy flight box does an excellent job though.
Old Feb 10, 2013, 08:05 AM
GrandpaInFlorida is offline
Find More Posts by GrandpaInFlorida
United States, FL, Floral City
Joined Dec 2012
Combo Stand
I saw designs for PVC stands and PVC balance testers so I thought why not combine them into one. The joint at the 45 is not glued so it articulates a little bit and I have a couple of elbow assemblies that I can put on it to move the balance points around for different planes.
GrandpaInFlorida is offline Find More Posts by GrandpaInFlorida
Old Feb 10, 2013, 02:26 PM
cervri is offline
Find More Posts by cervri
United States, NM, Deming
Joined Sep 2012
This looks very interesting to me. Got any more photos, close ups?
cervri is offline Find More Posts by cervri
Old Feb 10, 2013, 06:35 PM
Joined Dec 2012
I could but it's not a very complicated assembly. All 1/2" PVC with split foam pipe insulation. PVC Caps hold the insulation in place. The balance posts are 1/4-20 carriage bolts that are mounted in PVC caps drilled out with nuts on the top and bottom. The "X" pieces are standard fittings available in most hardware stores.
Old Feb 10, 2013, 08:57 PM
cervri is offline
Joined Sep 2012
Sorry about the mix up, I was referring to the Recycled walker picture..
Discussion Homemade boat stand rich1833 Sailboats 32 Jan 30, 2010 06:49 AM
Discussion heli workbench stand pewe The Builders Workshop 2 Dec 21, 2009 11:34 AM
Discussion Homemade Thrust stand.... It actually worked!! JTStone Electric Plane Talk 28 Feb 13, 2007 01:48 PM
Discussion Driver Stand for the Workbench F.Littleton The Builders Workshop 1 Dec 27, 2006 02:56 PM
Homemade plane stand? Pierre Audette Electric Plane Talk 11 May 21, 2002 03:38 AM
