Old Feb 04, 2013, 05:05 PM
Sarboy is offline
Find More Posts by Sarboy
Sarboy's Avatar
Joined Mar 2010
Template material?
Hi all,
I've just started to cut my own foam cores but I'm getting poor results. Now some of this I'm sure is my own tequnique but probably not all.
I think I could give myself a better chance with some better materials. Currently I'm making my aerofoil templates from 1/16 ply. It's east to work but hard to get a good finish on and the hot wire easily snags causing hills and dips in the foam.
I've heard Formica is a good material, but I can't seem to find a source on the net in the uk? Are there other materials that I should be considering?
Cheers
Tom
Sarboy is offline Find More Posts by Sarboy
Old Feb 04, 2013, 05:43 PM
T.D. is offline
Find More Posts by T.D.
T.D.'s Avatar
Vancouver, Canada
http://www.topclasscarpentry.com/mak...ate%20Samples/
Buddy of mine lives in London buys his as samples and offcuts from Top Class.
T.D.
T.D. is offline Find More Posts by T.D.
Old Feb 04, 2013, 06:04 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Whichever material used, work hard to achieve a glass-smooth edge.
rick.benjamin is offline Find More Posts by rick.benjamin
Old Feb 05, 2013, 01:21 AM
ron gijzen is offline
Find More Posts by ron gijzen
ron gijzen's Avatar
Liempde, Netherlands
Joined Jul 2007
I used to sand the guide surfaces of the ply very smooth, sometimes paint it with a lacquer to fill the pores, then apply a thick coat of carbon (with a carpenters pencil) for the wire to slip over. And go easy on the wire-pressure (downwards). Had good results this way.
ron gijzen is offline Find More Posts by ron gijzen
Old Feb 05, 2013, 04:31 AM
john mc lucas is offline
Find More Posts by john mc lucas
Harrington N.S.W. Australia
Joined Jul 2006
Hi Sarboy
Originally Posted by Sarboy View Post
Hi all,
Cheers
Tom
Try thin Aluminium sheet 1/2mm thick works great for me..
John
john mc lucas is offline Find More Posts by john mc lucas
Old Feb 05, 2013, 05:20 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
A good option for"disposable" templates is 2mm cardboard from an arty/crafty shop.Sold as backing board.It cuts really well-with a good sharp exacto and a spray glued paper pattern it's possible to cut in one pass.The knife blade leaves a polished surface.
A good way to get a smooth surface on a ply template is double sided tape and thin strips of aluminium(kitchen)foil.Works a treat.
Do some trials- I like the carbon from a pencil idea,I'll probably give that a go.
Stuart A is offline Find More Posts by Stuart A
Old Feb 06, 2013, 11:27 AM
jhaywood is online now
Find More Posts by jhaywood
jhaywood's Avatar
United States, VA, Suffolk
Joined Nov 2007
I have used 1/16 ply with good results. I sand the edges with 400 grit paper then soak the edges with thin CA. After that I polish again with 400 and 600 paper until it I can run my finger nail along the edge without it hanging.
jhaywood is online now Find More Posts by jhaywood
Old Feb 06, 2013, 06:41 PM
leleopard is offline
Find More Posts by leleopard
United Kingdom, England, London
Joined Feb 2010
thick cardboard, soaked in thin CA, then sanded with 400 grit, another pass of thin CA and re sand.
Good thing with cardboard is you can cut it with a stanley knife accurately, so I have found that it is the most time efficient way to get templates cut.
You can re use them as well - probably not indicated for heavy usage but I have had no problems re using the same set 4/5 times which is probably enough for most of us
leleopard is offline Find More Posts by leleopard
Old Feb 07, 2013, 10:21 AM
ian murdock is offline
Find More Posts by ian murdock
ian murdock's Avatar
United States, NV, Carson City
Joined Jan 2007
Try brass once you have the foil shap and design you want. The resign being that brass has a natural lubricity to it, also take some 300 grit sand paper to the aluminum or brass and polish the edge and you should get a real nice cut. Thats just my two cents.
ian murdock is offline Find More Posts by ian murdock
Old Feb 07, 2013, 11:32 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Polish the ply with 400 grit, then CA if you want as shown above. Last (important) step, take a pencil and completely coat the surface that the wire will touch. You'll find that the graphite lubricates the ply very well and wire will NOT snag again.
Construction pencils (the big ones at HD or Lowes) that have rectangular lead are great for this and stupid cheap.
tom43004 is offline Find More Posts by tom43004
Old Feb 08, 2013, 12:32 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
New templates with new front design and using dremal in a piller attachment to sand. This allowed a high degree of control in the sanding process. I then coated them in pencil lead/graphite. This has now produced much better cores. Here are some pics.
Old template design.
Description: Old template design.
Old Feb 08, 2013, 12:37 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
The new templates. I know this is quite a common shape but until I'd made a couple of cores I hadn't appreciated the advantages.
Description: New template. Notice how the front of the template allows smooth transition around the leading edge.
Old Feb 08, 2013, 12:42 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
Here you might be able to see the carbon/graphite coating.
Description: Graphite coated top surface.
Old Feb 08, 2013, 12:44 AM
Sarboy is offline
Sarboy's Avatar
Joined Mar 2010
And the core this all produced. It's a vert stab.
Description: Vert stab for DLG.
Old Feb 08, 2013, 06:12 AM
tom43004 is offline
tom43004's Avatar
Joined May 2002
I recoat mine every few sets of cores. I've been cutting cores since the 80s using 1/16 ply and graphite... Always make your final sanding pass by hand chord wise so you take off any micro bumps or ridges you can't necessarily see.
Good stuff! What foam are you cutting?
Foam cutting templates - What material? tomlin Electric Plane Talk 14 Jun 28, 2016 09:55 AM
hot wire template material. DeaninMilwaukee Foamies (Kits) 12 Apr 23, 2014 03:00 PM
Template Material--Your Choices? Balsa Hound Foamies (Kits) 4 Aug 13, 2002 05:38 PM
wing cutting template material Vinnya42 Power Systems 10 Sep 19, 2001 12:01 AM
