Old Feb 04, 2013, 04:53 PM
addictedtoplanes is offline
Find More Posts by addictedtoplanes
and helis!
addictedtoplanes's Avatar
Canada, ON, Guelph
Joined Jun 2012
Question
Is it possible to build a sub with out a pump and ballast tanks??
I was wondering if it would be possible to build a sub with slightly positive buoyancy, so it floats r e a l l y s l o w l y too the surface if it isn't moving, and have the diving planes controll the depth, like in a blimp or plane?
addictedtoplanes is offline Find More Posts by addictedtoplanes
Old Feb 04, 2013, 07:59 PM
thunderguts is offline
Find More Posts by thunderguts
Joined Nov 2010
Do a search for dynamic diving submarines
thunderguts is offline Find More Posts by thunderguts
Old Feb 04, 2013, 10:43 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
Dumas AKULA and USS BLUEFISH are two models designed as dynamic diving subs. The Graupner SHARK is another dynamic diver.
CG Bob is offline Find More Posts by CG Bob
Old Feb 05, 2013, 12:41 AM
tchalfant is offline
Find More Posts by tchalfant
tchalfant's Avatar
United States, NV, Las Vegas
Joined Aug 2011
The short answer is yes. Here is my Gato that is a dynamic diving sub. http://www.rcgroups.com/forums/showthread.php?t=1675545
It can be any sub you want, depends on the dive system you put in, if you do not want to go with one of the fine kits already listed.
tchalfant is offline Find More Posts by tchalfant
Old Feb 05, 2013, 07:25 AM
Carcharadon is offline
Find More Posts by Carcharadon
Joined Sep 2004
A 4ft version of a dynamic diver
http://home.comcast.net/~ryourk/2.wmv
Additional info
http://groups.yahoo.com/group/Jetnautilus/message/23
Carcharadon is offline Find More Posts by Carcharadon
Old Feb 05, 2013, 01:46 PM
and helis!
Canada, ON, Guelph
Joined Jun 2012
I would like to keep it simple and cheap, would it work if I used a water bottle for the hull? Or are there any cheap sub kits out there? How easy would it be to convert a small plastic model kit, like 20"-25" long?
Old Feb 05, 2013, 02:08 PM
tchalfant's Avatar
Joined Aug 2011
That is a dream for all of us, cheap and simple. I have seen WTCs (Water Tight Containers) made with simple devices and common materials. My Aluminaut is using less-expensive parts (ESC-Electronic Speed Controller for ~$7 US), the most expensive part is the receiver (~$40 US), but there are receivers out there for about ~$20 US - You get sometimes what you pay for.
Browse some of the works in progress at this site and others. You will see it can be done.
Old Feb 07, 2013, 11:00 PM
Subdave is offline
Find More Posts by Subdave
Semi-Official Tinkerer
Subdave's Avatar
Rochester NY
Joined Mar 2005
My favorite sub to run is my Delphin which is a dynamic diver.
It's not usually done for a scale boat but there is no law against it.
Simple easy and safe to run, unless you get snagged. Dave.
Subdave is offline Find More Posts by Subdave
Question Water pump for sealed ballast tank; Bogdan.Manole Submarines 7 Feb 06, 2015 07:09 AM
Rant Heng Long Bulldog tank (and possibly other stuff) trekker107 RC Tanks 3 Feb 11, 2013 04:26 PM
For Sale closed whytlotus Aircraft - Electric - Helis (FS/W) 1 Jan 09, 2013 09:30 PM
I'll trade my 2.5 gallon gas tank (built in hand pump) for a 1 gallon tank w/pump PontiusPilate Non R/C Items (FS/W) 0 Oct 31, 2012 02:40 PM
Ballast Tank Pumps Tregurtha1013 Dock Talk 5 Dec 10, 2004 07:29 AM
