Old Feb 04, 2013, 03:49 PM
ajhockey55 is offline
Find More Posts by ajhockey55
ajhockey55
Joined Jan 2013
Help!
Spur Gear
I have a Helion Dominus 10TR 1/10 scale and my spur gear keeps stripping. I correctly mesh the pinion and spur gear together. I use the paper trick. Does anyone know why the gear keep stripping? My only guess is that the motor moves after jumps or crashes but the motor is still secure in the same spot. Again does anyone have any advice?
ajhockey55 is offline Find More Posts by ajhockey55
Old Feb 04, 2013, 05:01 PM
SoloProFan is offline
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Does your car have a slipper clutch installed? If it has, it can allow the spur to slip in case of extreme loads, saving the motor, and transmission. If it has one, chances are it's been too tight, and barely allows slip. While this gives max acceleration of grippy surfaces, it will also mean the pinion/spur get every single added load transferred directly.
SoloProFan is offline Find More Posts by SoloProFan
Old Feb 04, 2013, 05:11 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Is the bearing/bushing that supports the spur gear wobbling or loose at all?
wparsons is offline Find More Posts by wparsons
Old Feb 05, 2013, 12:25 PM
ajhockey55
Joined Jan 2013
They dont have a slipper clutch that fits the Dominus TR. The slipper clutch made is only for the SC version. I tried to put one on already. So the slipper clutch is out of the question. And there is nothing that is loose. Everything is tight.
Old Feb 05, 2013, 01:37 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
If you can't put a slipper clutch on it, you'll have to land with the power off unless you enjoy replacing gears. Landing under power without a slipper will make short life of any gears without a slipper.
For Sale traxxas 76tooth spur gear ED3 Cars - Accessories (FS/W) 0 Jan 21, 2013 09:12 PM
Question SC10 4x4 - 32 Spur gear / pinion selection?? Mad Matt Off-road Cars 2 Jan 21, 2013 10:27 AM
For Sale HPI Savage Flux motor mount and spur heavy duty spur gear metalhead1986 Cars - Cars and Parts (FS/W) 0 Jul 13, 2012 10:16 PM
Spur Gear / MEC Gear Box WellDriller Sport Planes 18 Nov 01, 2002 02:11 PM
