Old Feb 07, 2013, 03:51 PM
Tharr62 is offline
Find More Posts by Tharr62
Joined Oct 2005
Thanks MC. On your DJI ESC's do you in fact use the bullets, or do you direct solder? Do you feel the bullets can lead to a failure, and is better to go direct?
Tharr62 is offline Find More Posts by Tharr62
Old Feb 07, 2013, 04:00 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
I check to make sure the bullets are tight from time to time, but that's it. The problem lies in the solder on the male end of the bullet to the motor wire on DJI motors. Their QC seemed to be lacking for quite some time causing motor failure when it heated up and for the lucky ones it was just a slight half second glitch in the motor.
Some people have said they don't like the quality of the bullets themselves but I haven't experienced any problems and I have unplugged them almost a dozen times now.
I know you are scared now, that feeling you had has been experienced by all of us at least once. Remember even the finest car in the world will have a mechanical problem, these flying contraptions are the same. Buy the best of the best and you aren't guaranteed to have trouble free flights.
Here is my scare! I still haven't got over this and anytime I hear something weird from my hex while in the air my heart drops. Typically it's just my GPS kicking up the motors to correct for wind... but I die a little everytime
DJI F550 Naza GPS - Lost a prop midflight (2 min 0 sec)
MCrites is offline Find More Posts by MCrites
Old Feb 07, 2013, 04:08 PM
Tharr62 is offline
Joined Oct 2005
WOW! GREAT JOB! Thank god you were able to control it. At least in your case you knew what it was right away! In mine, there is always that unknown.. was it a motor, was it the ESC, was it the FC, was it the RX? <sigh>. So, do you still use the DJI motors, or something better now?
Old Feb 07, 2013, 04:14 PM
MCrites is offline
Joined Jan 2012
Still using DJI motors and I am 6lbs AUW. I won't be able to use them when ambient temperatures are above 80-90F and living in Texas that is right around the corner. It's just too much weight on 4S with 10in Graupners.
Old Feb 07, 2013, 04:18 PM
Tharr62 is offline
Joined Oct 2005
Ah I see! Good point.. same deal here in Miami.. So, what motor are your going to replace with? I assume you will still keep your DJI ESC's?
Old Feb 07, 2013, 04:22 PM
MCrites is offline
Joined Jan 2012
I actually think I will be building and new Y6 rig from scratch for my high end camera/gimbal and make my F550 a hard mounted GoPro fun-fly machine.
I will be building a parts list soon, will probably try some SimonK ESCs because I keep hearing good things. I need to figure out if I am staying 4S or moving to 5S/6S before picking motors.
Old Feb 07, 2013, 04:40 PM
Tharr62 is offline
Joined Oct 2005
Cool! Ah, thats right the SimonK is not on the DJI ESC's.. but, I guess they must perform fine so who cares then right? Perhaps it was the fimware that caused my nasty fall.. I read that the SimonK pushes both the ESC and the motor to the limits..
Old Feb 07, 2013, 09:33 PM
Tharr62 is offline
Joined Oct 2005
Another thing I thought of in terms of what may have caused the issue... was perhaps the ESC was over amped? The T-motor website says the motors I have are 18A max... and the ESC I have are 20A. Could that do it?
Old Feb 08, 2013, 06:01 AM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
The actual current depends on your setup i.e. prop size and cell count. Ideally you want to check this (I use a Quanum telemetry system that's pretty cheap but works fine). In reality though it's very unlikely this is your problem. The 2216 motors on my hexa are pulling around 4A each in the hover (at 2.1 kg AUW).
Also the vast majority of ESCs will easily handle currents higher than their rating, short duration. I use lightweight 8A ESCs on all my 3D foamies ... most are set up to pull 10-12A on full throttle. Never had any issues.
Bill Glover is online now Find More Posts by Bill Glover
Old Feb 19, 2013, 08:52 PM
Tharr62 is offline
Joined Oct 2005
Happy to report that this quad has been completely rebuilt.. and flys great again (for now). I replaced all ESC's, all motors, and upgraded to UHF. I rebuild using the F450 frame, and I really love it. It is MUCH better then the crappy HT-FPV frame!
Old Feb 20, 2013, 08:09 AM
Kenpilot is offline
Find More Posts by Kenpilot
Kenpilot's Avatar
Joined May 2006
What UHF system are you using now?
All this talk of failing bullet connectors has me thinking, double check everything. Flying over a neighborhood with questionable solder joints is a potential tragedy waiting to happen. Sobering thought isnt it?
I just built a new F550 and had a motor start to fail after a 3 minute hover in my garage. Wonder if a solder joint may be bad on that ESC or motor lead. Sounds like it could be that.
Kenpilot is offline Find More Posts by Kenpilot
Old Feb 20, 2013, 08:16 AM
MCrites is offline
Joined Jan 2012
Flying over a neighborhood is sobering WITHOUT thinking about a failure. Sh-tuff happens no matter how much maintenance you perform. Do not fly over people or property that isn't yours.
EDIT** See my video above actually. I wasn't over a neighborhood but a failure put me there. Failure is impossible to predict and will happen.
Old Feb 20, 2013, 02:25 PM
Tharr62 is offline
Joined Oct 2005
Well, then I guess you were.. as you said, stuff can happen. Your's could have gone in the highway and caused a car accident! Even worse.
Look, I already got the point.. I don't need someone telling me this now. Especially someone with a similar video!
I have done the responsible thing and replaced everything on this quad.. in fact, I have replaced the entire thing now.. As you can see this park I fly at is very big.. even then.. a failure "could" cause it to go off course as yours did.. and guess what? Hit a house?
So the only place suitable to fly quads then.. is.. in the middle of nowhere!
Old Feb 20, 2013, 03:01 PM
Tharr62 is offline
Joined Oct 2005
EzUHF
Yes, this is why I built my own this time, and *know* the solder joints are good. I think we have ALL flown over a house or two in our travels.. and in my case 90% of my flight was over park, and near by golf course.. but, to re-enter the park I have to pass over three houses. OF COURSE thats when it will fail as you saw in the video.
AND in MCrites situation (which was worse then mine, and could have done a ton more damage to others as they highway was RIGHT NEXT TO HIM!) could have hit an on coming car! In Miami they would have gotten out and shot you dead!
We both have learned.. and need to find better flying spots.. because even if our intentions are good stuff happens..
Discussion Bumblebee 550 Naza GPS Aerial Video Build michael1980123 Multirotor Talk 6 Jan 29, 2013 10:21 PM
Discussion Naza Fail Safe with Corona Module michael1980123 Multirotor Electronics 4 Jan 29, 2013 04:43 PM
Sold Naza w/GPS with gps protector Scotth72 Aircraft - Electric - Multirotor (FS/W) 2 Jan 14, 2013 01:25 PM
Sold Naza m autopilot/stabilization with GPS/compass Strikerbusa FPV Equipment (FS/W) 13 Jan 11, 2013 04:47 PM
Help! Naza gps fail safe crash Pgear99 Multirotor Electronics 8 Jul 20, 2012 04:19 PM
