Old Feb 04, 2013, 03:15 PM
Jimob23 is offline
Find More Posts by Jimob23
United Kingdom, England, Ware
Joined Aug 2012
Venom Charge Box
I see Venom are offering an alternative to the safe sack for Lipo charging .
The descriptive blurb attached to the picture mentions that there is a clear polycarbonate cover for easy observation .
No doubt they have done extensive product testing where I am aware of the impact strength of polycarb but has anyone got comments as to the fire resistant properties ?
Jim
Jimob23 is offline Find More Posts by Jimob23
Old Feb 05, 2013, 05:41 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
linky?
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Feb 05, 2013, 05:47 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Jim
I haven't found any test videos. Anybody see one?
hoppy is offline Find More Posts by hoppy
Old Feb 07, 2013, 10:14 PM
Fly Wheel is offline
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
Some of my first jobs involved working with polycarbonates (A.K.A. Lexan) it does burn. not violently, but much like any other carbon based plastic, like PlexiGlass or styrene. Worse it melts as it burns, creating drops of liquid fire. I would replace the Lexan with metal if I were you. Why anyone would have a need to watch their expensive lipos go up in smoke anyway I have no idea.
Fly Wheel is offline Find More Posts by Fly Wheel
Old Feb 07, 2013, 10:58 PM
Jimob23 is offline
Joined Aug 2012
I have no intention in purchasing one but exactly like you said why the clear viewing top
Not as if you are watching a cake bake in the oven !
Old Feb 13, 2013, 04:55 AM
ltc is online now
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
Originally Posted by cryhavoc38 View Post
linky?
http://www.venom-group.com/Stronghol...mpaign=Feb2013
Video is on same page
ltc is online now Find More Posts by ltc
Old Feb 13, 2013, 08:14 AM
reptileman is online now
Find More Posts by reptileman
nj
Joined Jan 2004
In the video they say 60 watt max for battery size is the limit anything larger it won't contain the fire... so that will be a 2S 8000 pack for it's limit.
seems pretty good.
reptileman is online now Find More Posts by reptileman
Old Feb 13, 2013, 08:22 AM
ltc is online now
ltc
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
I believe they probably mean 60 watts electrical size (capacity), not physical size.
First order approximation ... take the battery voltage and multiply it by the capacity.
For example, a common 3S (11.1V) 2200mAH pack would be 11.1 * 2.2 = 24Watts
They must have decided how much energy can be handled by the enclosure based on a battery pack of a fixed "size" having an uncontained thermal event, based on the amount of lithium that would be present in the pack and the oxygen in the enclosure.
Old Feb 13, 2013, 09:58 AM
nj
Joined Jan 2004
From the web info for the venom box shows how large of lipos you can use up to 60watts.
The Venom Stronghold Solo is rated for Lithium Polymer batteries up to 60-Watt Hours:
Cells
Voltage
Maximum Capacity
Watt Hours
2S
7.4V
8000mAh
59.20
3S
11.1V
5400mAh
59.94
4S
14.8V
4000mAh
59.20
5S
18.5V
3200mAh
59.20
6S
22.2V
2700mAh
59.94
Old Feb 13, 2013, 10:04 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Let's see a video of a 2s 8000mah pack igniting in one.
Old Feb 13, 2013, 12:10 PM
Jimob23 is offline
Joined Aug 2012
A man with the same thinking as myself !
With a flow remperature of 155 C (311 F). along with the earlier comments by Fly Wheel it would be an interesting event .
On the other hand one cannot see a concern like Venom not conducting tests to ensure they were not faced with a rush of claims following fire damage
Old Feb 13, 2013, 06:30 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
You'd think so, but I wouldn't buy one without seeing the test results.
Old Mar 10, 2013, 01:27 PM
speed2004 is offline
Find More Posts by speed2004
United States, IL, Peoria
Joined May 2003
Polycarb window is to see a lipo puffing before an event-This is not a device for charging lipo's unattended! It's a good safety item -you can shut down charger power if you see puffing and it has a handle so you can safely move it away from burnable items.
speed2004 is offline Find More Posts by speed2004
Old Mar 11, 2013, 07:54 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
It's the perfect marketing ploy. If your battery goes up throw the whole thing out the window and let the charger get incinerated too. Now you can buy a new charger
Or use a lipo sack and yank the wires and throw that out the window and still have a charger afterwards, well that is unless the charger caused the fire.
grimbeaver is offline Find More Posts by grimbeaver
Discussion Venom 1800 nicd wont charge slappyy2000 Off-road Cars 9 Jan 31, 2010 10:02 PM
Discussion Venom Parallel Charging Question lillard2 Batteries and Chargers 2 Jul 22, 2009 01:07 AM
Discussion Charging a Thunder Power 2cell lipo with a Venom 3cell charge port and 4 wire adapter modfly Batteries and Chargers 0 Jun 22, 2008 11:49 AM
Question Rapid-charging the Venom 5000mah (7 cell) enoctis Batteries and Chargers 2 Jun 06, 2008 05:02 AM
Question Charge time for Venom 5000mah 8.4v enoctis Batteries and Chargers 1 Jun 02, 2008 01:04 PM
