Old Feb 04, 2013, 03:12 PM
gavib is offline
Find More Posts by gavib
Joined Feb 2013
Help!
DC motor transmission puzzler
Hi all,
I have a small model design problem which I 'm hoping you may be able to assist with resolving.
I 'm a software developer by trade and so am quite inexperienced in the engineering/build area of a project, though pretty good at complex Arduino coding!
In its simplest form, my issue is this;
I have a fairly high-torque 12v DC motor driving a basic pulley and belt transmission in both clockwise and counter-clockwise directions.
What the design requires is that the motor shaft be automatically disconnected from rest of the system when there is no current being supplied to the motor, in order that the pulley may be freely rotated by hand.
Some kind of clutch would seem to be the answer but I am unaware of any which would suit this purpose. Most are built for large industrial purposes and are far too large for hobby modelling designs.
I have investigated spring, electo-magnetic and centrifugal types on the internet but am no closer to a solution... so I thought I 'd ask some experts!
Any help or advice you could give would be VERY much appreciated.
TIA
Gav
gavib is offline Find More Posts by gavib
Old Feb 07, 2013, 01:27 AM
Dcope17 is online now
Find More Posts by Dcope17
Co-heir with Christ
Dcope17's Avatar
United States, CA, San Juan Capistrano
Joined Feb 2013
RC heli centrifugal clutch possibly...
Weed eater clutch or if needed a scooter or motorcycle centrifugal clutch.
All depending on RPMs and torque.
Dcope17 is online now Find More Posts by Dcope17
Old Feb 07, 2013, 03:14 AM
gavib is offline
Joined Feb 2013
Thanks for your reply - much appreciated!
Torque is 0.14 Nm (1482 g.cm)
RPM is around 200-250 rpm
As you can see, these figures are quite typical of a 12v DC motor, but not in the same ball-park as that required by scooter/motorcycle clutches.
Never heard of a 'weed eater clutch'! Will investigate
Gav
Old Feb 11, 2013, 07:20 PM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
I low cogging (detent) motor might be an alternative.
Roto Rob is offline Find More Posts by Roto Rob
Old Feb 18, 2013, 12:29 AM
Co-heir with Christ
Dcope17's Avatar
Joined Feb 2013
The clutch on my weed eater works on a 1.1HP engine. It has a spring that holds the friction things in and when the RPMs are high enough, the friction parts start touching the bell and gets everything spinning. The advantage to this is you can test different springs to get it to act how you want it to...
Old Feb 22, 2013, 04:06 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
He wanted to drive the motor in both directions. Most clutches don't work well in reverse. So if going that route would probably need two clutches.
Discussion Large Brushless DC Motor Suggestion KM.Racing Racing Boats - Electric 12 Feb 03, 2013 08:16 AM
Sold Johnson DC Brushed HC970 Motor For Sale (NEW) PittSpecial Boats (FS/W) 4 Jan 31, 2013 07:41 PM
Sold PITTMAN BRUSH DC MOTOR 14204 24-Volt PittSpecial Boats (FS/W) 3 Jan 21, 2013 02:03 PM
Sold Very Nice Paddle Wheel Boat Motor/Transmission Drive Assy 200:1 Ratio $65.00 SHIPPED! stevster Boats (FS/W) 4 Jan 20, 2013 06:34 PM
Sold Traxxas revo 3.3 2 speed tranny transmission with internal gears adamssonny007 Cars - Trucks and Parts (FS/W) 0 Jan 11, 2013 08:00 AM
