Old Feb 04, 2013, 12:40 PM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
New big four strokes spotted at Nuremberg
Looks like a 70cc from NGH, and I am guessing this is the new OS 40cc.
Kmot is online now Find More Posts by Kmot
Old Feb 04, 2013, 04:08 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
That 70cc NGH engine is interesting. I can see it being a substitute for using a 50cc two stroke engine. I guess they are using some imagination and creativity as I don't see OS as having ever made a engine with anything using upper end parts at around 70cc in size before. So they had to scale up the design to 70cc then.
The OS engine does look pretty good too.
earlwb is offline Find More Posts by earlwb
Old Feb 04, 2013, 04:26 PM
Patxipt is offline
Find More Posts by Patxipt
engine-a-holic
Portugal, Lisbon
Joined Jun 2007
Nice one Tom
Lovely engines, but I'd still like the OS to also have beam mounting.
Patxipt is offline Find More Posts by Patxipt
Old Feb 04, 2013, 09:17 PM
williame3590 is offline
Find More Posts by williame3590
williame3590's Avatar
Canada, ON, Caledonia
Joined Aug 2007
Any pricing on these guy's? I think we are seeing just the beginning of something extremely cool!
Bill
williame3590 is offline Find More Posts by williame3590
Old Feb 05, 2013, 12:27 AM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
Originally Posted by Patxipt View Post
Nice one Tom
Yes they do remind me of the K&B sport engine, but a bit fragile in case of a crash no ?
Reginald is offline Find More Posts by Reginald
Old Feb 05, 2013, 01:44 AM
turk1 is offline
Find More Posts by turk1
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
I have heard some rumours that NGH has some new developments .Such as using composite on 4 strokes.Also heard about a 38CC 4 str. pro version.
turk1 is offline Find More Posts by turk1
Old Feb 05, 2013, 11:00 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Bill
Looking at the Japanese information about the OS 40cc four stroke engine has the price at around $800 US or so maybe more by the time it gets in the USA. I would guess that the NGH 70cc four stroke engine is probably priced under $500 maybe. The NGH 38cc four stroke engine is going for $369 at this time.
Old Feb 05, 2013, 12:17 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Nothing wrong with a composite used in the right application like a valve cover or back plate. The automotive industry has been using them for a while now on engines.
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: A letter from my other senator
Old Feb 05, 2013, 05:11 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I could see a composite crankcase in some cases as working OK too. If the crankshaft has ball bearings or roller bearings, then it isn't putting wear into the crankcase anyway. If the engine has a bolt on cylinder/head unit then there shouldn't be too much heat getting down into the crankcase to cause problems. Or they could put in some extra cooling fins or something to help out as well. Same for a four stroke engine where the camshaft would ride on ball bearings or roller bearings too. But with a four stroke engine, the temperature differences could affect the valve gap, but maybe not enough to be a problem.
Old Feb 05, 2013, 05:32 PM
ZAGNUT is online now
Find More Posts by ZAGNUT
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
manufacturers have been trying and failing at it for years, by the time you get it strong enough you're back up to the weight of cast aluminium but with added manufacturing complexity that costs more than what you would save on raw materials. of course i'm talking about regular old cheap stuff like glass filled nylon, not some exotic composite.
ZAGNUT is online now Find More Posts by ZAGNUT
Old Feb 05, 2013, 06:02 PM
the pope is online now
Find More Posts by the pope
Australia, SA, Adelaide
Joined Sep 2007
If I was NGH I would worry about getting their engines running reliably first and not worry about gimmicks and pretty anodising just to get sales etc . There not the only ones like magnum who machine the outside of the engine to look pretty but not the inside where the bearings sit . Cheers the pope
the pope is online now Find More Posts by the pope
Reply With Quote  (Disabled)
Old Feb 05, 2013, 09:51 PM
turk1 is offline
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
Hi ANZAC,NGH 's are good engines. Running well,simple,reliable(Except GT9).Some slight flaws(like easy stripping muffler bolts) are fixing immediately also.
Michael is now very busy to develop new engines.I believe they will be all good engines too.
Old Feb 06, 2013, 12:24 AM
Joined Sep 2007
Howdy there Turk I read somewhere that some were having problems with there 38cc 4 stroke . I wonder if the 9cc will make a reappearance other than at hobby king ? I pulled the trigger on evolutions new 10cc gasser as the reviews seem to be all good . Not being familer with petrol engines I cant afford to have to tinker with these babies but lets hope Michaels engines will be ok in the long run .Do we really need to have parts that could shatter with a little whopsey or melt with a lean run ? Just give me good quality alloy thats fit for its job anyday . Cheers the pope
Old Feb 07, 2013, 03:49 AM
turk1 is offline
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
Howdy ANZAC.Also NGH GT9 is a good engine(fixed con rod) but regulator system misfit.
I solve it by removing regulator(only pump function),adding a return line from carb inlet and some profile changed LSN. LSN is the key factor here.I informed Michael for it but he is so busy to develop new engines, he said no time to spare for GT9.
Believe me the simple design of NGH engines(no reed valves,seperate liner,front carb.) makes it worth to buy.I dont know any 4 str. problems except mounting strut conflict on something.
Old Feb 07, 2013, 07:54 PM
karl k is offline
Find More Posts by karl k
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
Neat engines. I'd love to hear them in the air.
karl k is offline Find More Posts by karl k
Off Site New Saito FA-91S Four Stroke Engine (NIB) acehiggy Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 28, 2013 05:35 PM
For Sale Custom Sig Four Star w/ 91 Four stroke Hemet,CA palmsp9 Aircraft - Fuel - Airplanes (FS/W) 0 Jan 27, 2013 07:06 PM
Sold New Never Fueled Thunder Tiger 91 FS Four Stroke Nice! $115.00 FREE SHIPPED!!! stevster Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 19, 2013 08:50 PM
For Sale .52 asp four stroke chickenstick29 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jan 02, 2013 09:04 AM
Discussion Four Stroke Recommendation for WM Spot On 50 dtm360 Engines 1 Mar 26, 2007 10:52 PM
