Old Feb 04, 2013, 12:20 PM
BulletRS is offline
Find More Posts by BulletRS
Joined Feb 2013
Help!
Boat ESc Burned Out
Hi Guy's Hope Some one can Help me with this Problem , I have been Burning Out ESC every weekend and starting to feel the cost now.my latest Setup is as Follows:
29" Cat (Mystic)Made From Balsa and Plywood
ADS300XL Water-cooled Brushless Outrunner 3000kv 400w
40A Water Cooled Brushless Boat ESC
45mm Prop
3Cell 11.1V
Run the Boat for about 10 sec and Bob's my Uncle stopped .when I got it out of the water about 30 min later everything was Cool but nothings Working Must have Poped it again.
BulletRS is offline Find More Posts by BulletRS
Old Feb 04, 2013, 11:40 PM
CornelP is offline
Find More Posts by CornelP
CornelP's Avatar
Bucharest, RO
Joined May 2009
Welcome to the forums,
Well, you have a small issue here... The ADS motor is on the tiny side for this boat (more like a 20" boat motor) and the prop is way too big for it. On 30" you should go for a motor starting from 3674 upwards, esc around 120A, batteries 4-5S 5000mAh, with props around 40mm. Some pictures of the boat will always help.
CornelP is offline Find More Posts by CornelP
Old Feb 05, 2013, 08:43 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
There's 3 or 4 threads for the same thing... no need to post the same thing over and over again.
wparsons is offline Find More Posts by wparsons
Old Feb 05, 2013, 09:31 AM
BulletRS is offline
Joined Feb 2013
Thanks .. Sorry these Might be Dum Questions but this is my first Rc boat I have Done and never been Into this .... I'm Sure I have a Problem with the Prop.. on the Motor You recommended i had a Look on the Hobby king web but this is not water cooled or do You get a Jacket for it ?.
another Question how much higher can You go with the ESC?
Old Feb 11, 2013, 01:39 PM
hemiblas is offline
Find More Posts by hemiblas
United States, CO, Aurora
Joined May 2009
I have a couple boats and can tell you that the esc is too small and the prop is too big for that much kv. You can do a couple things.
You can put a much much much smaller prop.
You can buy a bigger ESC, as big as you want. A 120A might be good.
That motor is too small for a boat that big. Once you stop smoking your esc with a bigger one, and you run the motor for a couple minutes, you will probably smoke the motor.
That motor will push 33,000 rpm. My boat pushes 22,000 rpm with a much bigger motor and a much smaller prop.
boats will pull a lot of current at startup before you reach "the plane". Because you have too much kv and too big of a prop the speed control is seeing current spikes that are very large and that is why they are smoking.
You could also keep the setup the same and try a 2S battery. 7.4V. It still might be pulling too much current though, but the esc's will last longer.
Boats are tricky to figure out especially when you are trying to come up with your own combination. I spoked lots of speed controls like you until I figured this out.
Keep in mind, the esc only stays cool when the boat is going very fast so that the water can actually cool it. If you are doing a lot of start and stopping even a good setup will overheat.
hemiblas is offline Find More Posts by hemiblas
Old Feb 11, 2013, 01:52 PM
hemiblas is offline
Joined May 2009
I saw from your other post that you are going to get a smaller prop. That should fix the problem. If you want to get more than 20-25 mph out of it then consider another bigger motor, but you can get that motor to work, it just may not give you the speed you want.
I always like to buy as big an esc as I can which is why I said 120A. if you buy a quality speed control a 60A would work, a non quality one then go 120A.
Old Feb 12, 2013, 08:21 AM
highflyerbill is offline
Find More Posts by highflyerbill
Gordonsville,Virginia
Joined Nov 2009
Make sure your batteries are adequite .More ESC are burned up because of poor batteries then most people think .
highflyerbill is offline Find More Posts by highflyerbill
Old Feb 12, 2013, 09:39 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
It's a tiny outrunner (~450 heli sized, about what I run in my 16" jet boat) with a big prop and small ESC, I don't think the batteries are to blame right now.
Help! Burned out tantalum capacitor - RMRC 480 - help? Mochaboy FPV Talk 4 Aug 30, 2013 12:49 AM
Help! Burned out 12v Camera while connecting to 12v Source? 0zerosum0 Power Systems 3 Jan 27, 2013 09:28 PM
Help! I am Military burned out. cyclops2 Scale Kit/Scratch Built 3 Jan 18, 2013 09:22 PM
Discussion Motors Keep burning out (MSR) anonymoustache Micro Helis 0 Jan 06, 2013 02:41 PM
Discussion Burn out when connecting battery to ESC derp express Power Systems 7 Jan 03, 2013 04:44 AM
