PNP/NPN only applies to bipolar junction transistors. MOSFETs have no junctions, so they are either P channel or N channel.
Code:
C VAR WORD ; Variable to store individual readings from ADC
C1 VAR WORD ; Variable to store combined readings from ADC
GEARUP:
LOW PORTA.0
HIGH PORTA.1
RUNUP:
For X = 1 to 10
C1 = 0
ADCIN 0, C
C1 = C1 + C
PAUSE 10
NEXT X
IF C1 > 10 (or whatever the right number turns out to be) GOTO BRAKE
GOTO RUNUP
BRAKE:
LOW PORTA.0
LOW PORTA.1
Thanks again! |
When you start the motor there will be an initial current spike as it gets up to speed. Your code handles this well because it collect 10 samples before thinking about braking. However it then takes another 10 samples before making the next decision, so the response to the motor stalling while running is slower that it could be. If you modify the code to take a running average then it can respond faster. To do this, store the samples in a buffer array. After the first 10 samples have been summed and tested for over-current, subtract the oldest sample from the total so it now consists of samples 2-10. Then read the ADC again, store the new sample over the oldest one in the buffer, and add it to the total. You now have the sum of samples 2-11. Keep doing that (stepping through the buffer array to get to the next oldest sample) until you sense a current overload indicating that the motor has stopped. The code below should work, but I don't have PIC Basic Pro so I can't guarantee there are no errors! Code:
AMPS VAR WORD[10] ; buffer to store ADC samples
OC CON 1234 ; over-current threshold value
GEARUP:
LOW PORTA.0
HIGH PORTA.1
RUNUP:
For X = 0 to 9
C1 = 0
ADCIN 0, AMPS[X]
C1 = C1 + AMPS[X]
PAUSE 2 ; wait 2mS between samples
NEXT X
IF C1 > OC THEN GOTO BRAKE
X=0 ; point to oldest sample in buffer
WAIT_STALL:
C1=C1-AMPS[X] ; subtract oldest sample from total
ADCIN 0,AMPS[X] ; get new sample (overwriting oldest sample)
C1=C1+AMPS[X] ; add new sample to total
IF C1 > OC THEN GOTO BRAKE ; exit if over-current
X=X+1 ; point to next-oldest sample in buffer
IF X > 9 THEN X=0 ; circular buffer
PAUSE 2 ; pause 2mS between samples
GOTO WAIT_STALL ; continue checking for over-current
BRAKE:
LOW PORTA.0
LOW PORTA.1
I'm getting real close, Bruce! The way you arranged that variable array, entering the newest measurements into it while replacing the oldest is something I would never have dreamed of doing. Very clever, and it taught me a lot about how you can use an array, I've never seen anything like that done before.
Here's where I'm at now: I tried the variable resistors, and I was mistaken, they would only go as low as ~1 ohm. So I scrounged around in an old charger I had and found a 1/10 ohm 1 watt precision resistor, and inserted it into the circuit. I connected the sources of both of the N-channel FETs together to one side of the resistor, and connected that junction to the input channel of the ADC. (I used channel 7 because I was already using the pin for channel 0 for something else) .The other side of the resistor went to ground. I have the threshhold for OC set to 3000. I also added a 2 second pause at the beginning of the RUNUP section to allow the motor to get moving before it began taking measurements. Finally, I added a 10k resistor in series with a .01uf ceramic disc cap to the input pin of the ADC. I'm not sure if that's how you meant for the filter, but that's the best I could figure looking at other circuits. OK, if I remove the motor from the circuit completely, the program runs and does what it's supposed to do. I've put some LEDs on the outputs to the FETs so I can see which output pins are high and which are low. If I connect the motor, it runs until the 2 second delay is over and goes to BRAKE. (I also have a blue led that comes on once the program goes to the BRAKE section.) If I start the program with the motor disconnected, and then plug the motor up, it runs until it hits the end but never goes to BRAKE. If I remove the sense wire, the program runs continuously, and never goes to BRAKE, not matter what I do, so it seems that the sense circuit is doing something, but not consistently, and not predictably, either. I'm not sure if I should keep increasing the OC value, or if my current sensing resisitor is the wrong size, or if the code isn't quite right. I don't know how to calculate what size resistor I should be using, or how to determine what number the OC constant should be set to. If the ADC were returning the maximum number every time, it looks to me like C1 should never get bigger than 255 * 10, so I don't think making OC threshold larger than 3000 will solve anything. I'm posting the code, the bridge circuit is the one from the link you posted to your website. My PIC is a 16F684, I have the MCLR pin pulled high with a 10K ohm. Any ideas? Code:
;***** Set Configuration Fuses *****
__CONFIG
_INTRC_OSC_NOCLKOUT
_WDT_ON
_PWRTE_OFF
_MCLRE_OFF
_CP_OFF
_BODEN_ON
@ errorlevel -302 ; Suppress message 302
;DEFINE OSC4 ; Sets up 4MHz internal oscillator
;DEFINE OSCCAL_1K 1 ; Use stored OSCCAL Value - REQUIRED -
DEFINE PULSIN_MAX 3000 ; Maximum waiting time for PULSIN
ANSEL = 0 ; Set all inputs/outputs to digital
CMCON0 = 7 ; Analog comparators
ADCON0 = %10011101 ; Sets ADC inputs, Vref, and ouput
ADCON1.7 = 1
TRISA = 0 ; Set PortA outputs EXCEPT A.3 input
TRISC = 1 ; Set PortC to inputs
DEFINE ADC_BITS 10
DEFINE ADC_CLOCK 3 ; Sets ADC clock frequency
LOGICA VAR PORTA.5 ; Output A to H Bridge
LOGICB VAR PORTA.0 ; Output B to H Bridge
LOGICC VAR PORTA.4 ; Output C to H Bridge
LOGICD VAR PORTA.1 ; Output D to H Bridge
SW VAR PORTC.0 ; Reversing switch or jumper
RX VAR PORTC.1 ; Input from receiver
P VAR WORD ; Variable to store pulse width
PP VAR WORD ; Variable to store previous pulse width
R var WORD ; Variable to store reversing state (0 or 1)
X var byte ; Variable for loops
AMPS VAR WORD[10] ; Buffer to store ADC samples
OC CON 3000 ; Over-current threshold value
INITIALIZE:
PAUSE 1000 ; Wait for PIC to stabilize
R = 1
IF SW = 1 then GOTO MAIN ; Check for reversing switch closed
R = 0
MAIN:
LOW LOGICA
LOW LOGICB
LOW LOGICC
LOW LOGICD ; Turn all outputs to motor off and Brake
RXIN:
PULSIN RX,1,P ; Input From Rx
GOSUB REVRSE ; Check reversing switch/jumper
IF (P < 90) THEN GOTO RXIN ; Wait for Tx ON
IF (P > 90) AND (P < 145) THEN GOTO GEARUP ; Check gear switch on RX
GEARDOWN:
HIGH LOGICB
HIGH LOGICC
GOTO MOTOR_RUN
GEARUP:
HIGH LOGICA
HIGH LOGICD ; Outputs to rotate motor
MOTOR_RUN:
PAUSE 2000
For X = 0 to 9
C1 = 0
ADCIN 7, AMPS[X]
C1 = (C1 + AMPS[X])
PAUSE 5 ; wait 2mS between samples
NEXT X
X = 0 ; point to oldest sample in buffer
WAIT_STALL:
C1 = (C1 - AMPS[X]) ; subtract oldest sample from total
ADCIN 7, AMPS[X] ; get new sample (overwriting oldest sample)
C1 = (C1 + AMPS[X]) ; add new sample to total
X = (X + 1) ; point to next-oldest sample in buffer
IF X > 9 THEN X = 0 ; circular buffer
REVRSE:
IF SW = 1 THEN ; Check reversing switch/jumper state
RETURN
ELSE
P = (300 - P) ; Toggle value of pulse width if reversed
ENDIF
RETURN
BRAKE:
LOW LOGICA
LOW LOGICB
LOW LOGICC
HIGH PORTA.2
END
Simple RC Filter Calculator |
My mistake, I meant to say it is a .1uf cap.
I think I've found a (the?) problem. In the code you posted, there is a line inside the RUNUP section that sets the variable C1 to 0. The For/Next loop is supposed to get a measurement, then add it to C1 before comparing the result to the OC variable. But the C1=0 staement is inside the loop, and if I'm looking at it right, every time the loop comes back around C1 is re-set to 0 again. I moved it to right before the loop, and I think it's working now. A value of 100 for the OC variable causes it to go to BRAKE as soon as I connect the motor, but a value of 1000 allows it to run and it never goes to BRAKE. So like a Navy ship that's been "bracketed" by gunfire, I think I have it in my sights. I'm going to shrink the gap between those two numbers now and see what happens. I'll let you know. |
OK, I'll change it. However, the good news is that it's working very well like it is!
No telling how much better it will work once I fix the filter.It allows the motor to run in either direction, and when it comes to the end it only takes it a fraction of a second to cut off. If I hold the gear with my hand while it's moving, it only takes a second or so to cut off, and I don't have to put too much pressure on it, either. I'm very happy with how that part of it is working. Now I'm adding the rest of the code to move the gear door servo(s), and I think I'm going to try to add a trim pot connected to the comparator to give us some speed reduction for the door servos. Man, I've learned a lot about every part of it, from the circuit itself, to how to set up the PIC's registers, to using the ADC, and even how to put variables in an array. I can't thank you enough, Bruce. Hope I can return the favor someday, somehow. I'll post a video of the whole shebang once I get it all polished up. |
| Thread Tools | |
| Discussion Wiring/soldering help with 900mhx system | pete914 | Video Piloting (FPV/RPV) | 11 | Jan 20, 2013 03:20 PM |
| Discussion dual h-bridge breakout board | rocky79 | DIY Electronics | 0 | Jan 19, 2013 12:50 PM |
| Help! need some electronic wiring help | abletowinginc | DIY Electronics | 0 | Jan 14, 2013 07:12 AM |
| Discussion Quad Wiring Diagram (Terminal Bridge) | spackletoe | Multirotor Talk | 5 | Nov 15, 2011 01:50 PM |
| Question H-Bridge circuit to dual polarity convertion help | Angry_Monk | Indoor and Micro Models | 6 | Aug 09, 2005 10:15 PM |
