Feb 04, 2013, 11:52 AM
Malaysia, Selangor, Kajang
Joined Jun 2009
Next is to install the ruler on to the stripper. I eyeballed the cutting blades through the guide hole to figure out the approximate center and installed the ruler to the left of the center. The reason for that is so that we can install a cursor tick mark above it. Otherwise, if the ruler is installed with it's zero exactly at the blade center, you'd have to use the edge of the plastic guide as the cursor. But on my stripper, the guide holes didn't have good, definite edges. So a separate cursor was needed.
I simply used double sided tape to stick the ruler on. Align the ruler carefully so that the top is flush with the top of the metal bracket holding the plastic guides.
BTW, all through this procedure I used my phone camera as a magnifying glass. Didn't have anything on hand that was as powerful. I did have to tape my phone to some bits of wood to hold it in place. Couldn't get my hands steady enough to get clear images at this level of magnification.
