Old Feb 04, 2013, 11:27 AM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Help!
one cell battery tester
Hi guys
What do you use to check the one cell batterys for parkzone micros to see what level of a charge they have?
Rich
rcrich is offline Find More Posts by rcrich
Old Feb 04, 2013, 11:44 AM
pohlmeyr is online now
Find More Posts by pohlmeyr
pohlmeyr's Avatar
United States, TX, Denton
Joined Sep 2001
http://www.hobbyking.com/hobbyking/s...l_checker.html
I use one of these with an appropriate adapter depending on the battery. It is pretty accurate for a go no go decision.
pohlmeyr is online now Find More Posts by pohlmeyr
Old Feb 04, 2013, 02:17 PM
scousethief is online now
Find More Posts by scousethief
scousethief's Avatar
United Kingdom, England, Redcar
Joined Jan 2006
for 1 cell i use a cheapo multimeter.
scousethief is online now Find More Posts by scousethief
Old Feb 04, 2013, 05:48 PM
Ginohio is offline
Find More Posts by Ginohio
Ginohio's Avatar
United States, OH
Joined Mar 2012
I have one similar to this but don't have an adapter for the 1s lipo did you get your adapter from hobby king?
Ginohio is offline Find More Posts by Ginohio
Old Feb 04, 2013, 05:59 PM
pohlmeyr's Avatar
Joined Sep 2001
no i just soldered one together for the 1s batteries
Old Feb 04, 2013, 06:14 PM
GooberSB is offline
Find More Posts by GooberSB
An Ordinary User
United States, VA, Fluvanna
Joined Jan 2011
Me too.
To make get a 2S balance extender and a UM battery connector (or a bag of 10 pico extenders from HK).
Cut the wires so that you have a battery connector that mates the UM battery and a 2S balance plug that mates with the battery tester.
Cut off the red wire from the 2S balance lead.
Solder black wires together and cover with heat shrink.
Solder the (white on mine) positive wire of the battery connector to the center wire (green on mine) of the balance lead and cover with heat shrink.
Connect to tester as usual, negative (black wire) on pin 1.
The tester must be able to check voltage for 1S though. Only half of the ones I've come across will check 1S. If it says it supports 2S-6S don't be surprised if it doesn't work.
GooberSB is offline Find More Posts by GooberSB
Old Feb 04, 2013, 06:30 PM
Ginohio is offline
Ginohio's Avatar
United States, OH
Joined Mar 2012
Originally Posted by GooberSB View Post
Me too.
I just looked I have extra battery connector and bad 2s battery so I could use that lead. Then looked an my tester says 2s-6s uggh.. I still gonna try it if nothing else some more soldering experience.. Thanks for the help guys. If mine doesn't work I will grab a 1S not like another one going to break the bank.
Old Feb 04, 2013, 06:40 PM
GooberSB is offline
An Ordinary User
Joined Jan 2011
Be sure to cut the balance lead one wire at a time. The shock wouldn't hurt but if it catches fire you have a bigger problem.
Old Feb 04, 2013, 07:24 PM
Ginohio is offline
Ginohio's Avatar
United States, OH
Joined Mar 2012
Thanks for the heads up!
Old Feb 04, 2013, 08:08 PM
356Jim is offline
Find More Posts by 356Jim
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
................ The shock wouldn't hurt but if it catches fire you have a bigger problem.
Shock??? You won't get a shock from a one cell LiPo!! Now, a 10s LiPo pack will cause a tingle...... (37 volts, which in the EU is considered a lethal voltage).. But thankfully, we in the US are a lot smarter. No one ever heard of anyone getting electrocuted from a LiPo pack. But wait as the herd thins............................
356Jim is offline Find More Posts by 356Jim
Old Feb 05, 2013, 07:19 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Most cheap testers won't work on less than 2S....but you can always just add two connectors and test two batteries at a time. That's what I do .
Steve
slipstick is offline Find More Posts by slipstick
Old Feb 05, 2013, 10:29 AM
GooberSB is offline
An Ordinary User
Joined Jan 2011
Steve
Yes, this one costs a little more (it's $5) http://www.hobbyking.com/hobbyking/s...ker_Alarm.html
I have one and use it sometimes. The alarm is so darn loud though,.
Sold Esky EK2-0906 Battery Tester N3SHXX Aircraft - Electric - Multirotor (FS/W) 2 Jan 20, 2013 11:47 AM
Sold Esky EK2-0906 Battery Tester N3SHXX Aircraft - Electric - Helis (FS/W) 3 Jan 20, 2013 11:46 AM
Sold Esky EK2-0906 Battery Tester SOLD....!!! N3SHXX Aircraft - General - Radio Equipment (FS/W) 0 Jan 20, 2013 10:01 AM
Sold rc parts, Battery connectors, low voltage buzzers servo tester more ronzer Cars - Trucks and Parts (FS/W) 5 Jan 18, 2013 10:49 PM
CBA battery tester -- Have you tested single cells? frederm2002 Batteries and Chargers 16 May 26, 2010 01:51 PM
