Old Feb 04, 2013, 09:40 AM
Wullie1967 is offline
Find More Posts by Wullie1967
V911 newbie
Wullie1967's Avatar
United Kingdom, Scotland, Glasgow
Joined Feb 2013
champ plane
Hi thinking of buying the champ airplane from hobbyzone can anyone tell me if you can charge the plane up from the wall or does it have to be with the AA batteries thanks
Wullie1967 is offline Find More Posts by Wullie1967
Old Feb 04, 2013, 09:50 AM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Here is the manual.
http://www.hobbytown.com/uploadedFil...Town/Champ.pdf
Kimber is offline Find More Posts by Kimber
Eclipse_7 is offline
Find More Posts by Eclipse_7
Eclipse_7's Avatar
United States, TX, Houston
Joined Nov 2003
There is an optional 6v power adapter that you can buy from Horizon. It will let you charge your battery from a wall socket.
Eclipse_7 is offline Find More Posts by Eclipse_7
Old Feb 04, 2013, 09:52 AM
Eclipse_7's Avatar
Joined Nov 2003
http://www.horizonhobby.com/products...upply-EFLC1005
I've not bought a Champ, so someone should confirm if its charger has the 6v port on it.
Old Feb 04, 2013, 10:16 AM
V911 newbie
Wullie1967's Avatar
Joined Feb 2013
Thanks guys think someone said you could buy the little power plug with the different ends and adjustable volts
Old Feb 04, 2013, 10:19 AM
yorkiepap is online now
Find More Posts by yorkiepap
yorkiepap's Avatar
SW PA
Joined Aug 2010
Hey Wullie,
I have both the Champ & the T28 & use several capacity(Mah) so I can have longer flight times. I recently acquired (3) 500Mah for some serious flight time(25+min.). I have modified the battery area so the different sizes fit easily & have a very thin plastic(my welding helmet lense covers) cut to fit so they hold the batteries in place in flight. Never had one come loose with this setup.
You have to be quite careful to insure your CG is correct & placement of the different batteries can be marked with a felt pen. I use my regular charger with a pigtail that has (6) Champ battery connectors so I can do (6) batteries at a time. Here are some pics.... hope they help you.
Denny
yorkiepap is online now Find More Posts by yorkiepap
Old Feb 04, 2013, 02:38 PM
V911 newbie
Wullie1967's Avatar
Joined Feb 2013
Thanks yorkiepap but it looks good but still don't no if I can charge the original champ charger with the wall socket
Old Feb 04, 2013, 03:43 PM
interscape is offline
Find More Posts by interscape
Joined Jan 2007
wall charger
Yes you can. I have never put batterys in my charger. I just use a 5.5 volt charger I had.
interscape is offline Find More Posts by interscape
Old Feb 04, 2013, 03:49 PM
Joined Jan 2007
edit - I use a 5.5 volt power supply and the original Champ charger..
Old Feb 04, 2013, 05:01 PM
V911 newbie
Wullie1967's Avatar
Joined Feb 2013
Thanks iterscape I have a one of thos plugs with the voltage mover and the different ends would that work or could you tell me where you got your charger from
Old Feb 04, 2013, 08:09 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
I have several Champs and I use this AC adapter to plug into the stock charger that comes with the Champ. It saves on having to buy batteries for the charger.
Butch777 is offline Find More Posts by Butch777
Old Feb 04, 2013, 09:05 PM
Pete Miller is offline
Find More Posts by Pete Miller
Beaumont, TX
Joined Feb 2007
Yes, IF the selectable voltage has a voltage that matches the voltage required by the Champ charger and a plug that matches the receptacle on the Champ charger (Size and pin polarity).
The voltage and pin polarity are embossed on the charger next to the receptacle.
Pete Miller is offline Find More Posts by Pete Miller
Old Feb 05, 2013, 07:50 AM
V911 newbie
Wullie1967's Avatar
Joined Feb 2013
Thanks again guys for your time
Discussion Which plane after Hobyzone CHAMP (micro plane) Steamroller14 Electric Plane Talk 11 Jul 07, 2011 05:45 AM
Discussion What plane is this? Debolt Livewire Champ-w/short video reacher10 The Builders Workshop 48 Mar 29, 2011 03:20 PM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
